7.3
cs_io.h
1 #ifndef __CS_IO_H__
2 #define __CS_IO_H__
5  * Low level file I/O utility functions for Preprocessor and restart files
30 #include "cs_defs.h"
33  * Local headers
36 #include "cs_base.h"
37 #include "cs_file.h"
38
44  * Local Macro Definitions
46
47 #define CS_IO_NAME_LEN 32 /* Section header name length */
48
49 #define CS_IO_ECHO_NONE -2 /* No verbosity at all */
50 #define CS_IO_ECHO_OPEN_CLOSE -1 /* Echo open or close operations */
51 #define CS_IO_ECHO_HEADERS 0 /* Echo headers */
52
54  * Type definitions
56
57 /* Input or output mode */
58
59  typedef enum {
60
63
64 } cs_io_mode_t;
65
66 /* Structure associated with opaque pre-processing structure object */
67
68 typedef struct _cs_io_t cs_io_t;
69
70 /* Structure used to save section header data, so as to simplify
71  passing this data to various functions */
72
73 typedef struct {
74
75  const char *sec_name; /* Pointer to section name */
76  cs_file_off_t n_vals; /* Number of associated values */
77  size_t location_id; /* Id of associated location, or 0 */
78  size_t index_id; /* Id of associated index, or 0 */
79  size_t n_location_vals; /* Number of values per location */
80  cs_datatype_t elt_type; /* Type if n_elts > 0 */
81  cs_datatype_t type_read; /* Type in file */
82
84
85 /*=============================================================================
86  * Global variables
87  *============================================================================*/
88
89 /* Default hints for files using this API (for MPI-IO) */
90
91 extern int cs_glob_io_hints;
92
93 /*============================================================================
94  * Public function prototypes
95  *============================================================================*/
96
97 /*----------------------------------------------------------------------------
98  * Initialize a kernel IO file structure.
99  *
100  * The magic string may be NULL only in read mode;
101  *
102  * If the position of section bodies is already known (after initial
103  * analysis for example), the file may be opened for reading section bodies
104  * only by using "seek_read_section_bodies_only" as a magic string. This may
105  * be used to map another type of file to kernel io files, if header data is
106  * different but body data is similar (binary, using the same datatypes).
107  *
108  * parameters:
109  * name <-- file name
110  * magic_string <-- magic string associated with file type
111  * mode <-- read or write
112  * method <-- file access method
113  * echo <-- echo on main output (< 0 if none, header if 0,
114  * n first and last elements if n > 0)
115  * hints <-- associated hints for MPI-IO, or MPI_INFO_NULL
116  * block_comm <-- handle to MPI communicator used for distributed file
117  * block access (may be a subset of comm if some ranks do
118  * not directly access distributed data blocks)
119  * comm <-- handle to main MPI communicator
120  *
121  * returns:
122  * pointer to kernel IO structure
123  *----------------------------------------------------------------------------*/
124
125 #if defined(HAVE_MPI)
126
127 cs_io_t *
128 cs_io_initialize(const char *file_name,
129  const char *magic_string,
130  cs_io_mode_t mode,
131  cs_file_access_t method,
132  long echo,
133  MPI_Info hints,
134  MPI_Comm block_comm,
135  MPI_Comm comm);
136
137 #else
138
139 cs_io_t *
140 cs_io_initialize(const char *file_name,
141  const char *magic_string,
142  cs_io_mode_t mode,
143  cs_file_access_t method,
144  long echo);
145
146 #endif /* HAVE_MPI */
147
148 /*----------------------------------------------------------------------------
149  * Initialize a kernel IO file structure in read mode, building an index.
150  *
151  * The magic string may be NULL, if we choose to ignore it.
152  *
153  * parameters:
154  * name <-- file name
155  * magic_string <-- magic string associated with file type
156  * method <-- file access method
157  * echo <-- echo on main output (< 0 if none, header if 0,
158  * n first and last elements if n > 0)
159  * hints <-- associated hints for MPI-IO, or MPI_INFO_NULL
160  * block_comm <-- handle to MPI communicator used for distributed file
161  * block access (may be a subset of comm if some ranks do
162  * not directly access distributed data blocks)
163  * comm <-- handle to main MPI communicator
164
165  * returns:
166  * pointer to kernel IO structure
167  *----------------------------------------------------------------------------*/
168
169 #if defined(HAVE_MPI)
170
171 cs_io_t *
172 cs_io_initialize_with_index(const char *file_name,
173  const char *magic_string,
174  cs_file_access_t method,
175  long echo,
176  MPI_Info hints,
177  MPI_Comm block_comm,
178  MPI_Comm comm);
179 #else
180
181 cs_io_t *
182 cs_io_initialize_with_index(const char *file_name,
183  const char *magic_string,
184  cs_file_access_t method,
185  long echo);
186
187 #endif /* HAVE_MPI */
188
189 /*----------------------------------------------------------------------------
190  * Free a preprocessor output file structure, closing the associated file.
191  *
192  * parameters:
193  * pp_io <-> kernel IO structure
194  *----------------------------------------------------------------------------*/
195
196 void
197 cs_io_finalize(cs_io_t **pp_io);
198
199 /*----------------------------------------------------------------------------
200  * Return a pointer to a preprocessor IO structure's name.
201  *
202  * parameters:
203  * pp_io <-- kernel IO structure
204  *----------------------------------------------------------------------------*/
205
206 const char *
207 cs_io_get_name(const cs_io_t *pp_io);
208
209 /*----------------------------------------------------------------------------
210  * Return the number of indexed entries in a kernel IO structure.
211  *
212  * parameters:
213  * inp <-- input kernel IO structure
214  *
215  * returns:
216  * size of index if present, 0 otherwise,
217  *----------------------------------------------------------------------------*/
218
219 size_t
221
222 /*----------------------------------------------------------------------------
223  * Return the name of an indexed section in a kernel IO structure.
224  *
225  * parameters:
226  * inp <-- input kernel IO structure
227  * id <-- id of section in index (0 to n-1 numbering)
228  *
229  * returns:
230  * pointer to section name if id in index range, NULL otherwise
231  *----------------------------------------------------------------------------*/
232
233 const char *
235  size_t id);
236
237 /*----------------------------------------------------------------------------
238  * Return header data for an indexed section in a kernel IO structure.
239  *
240  * parameters:
241  * inp <-- input kernel IO structure
242  * id <-- id of section in index (0 to n-1 numbering)
243  *
244  * returns:
245  * section header data (if id not in index range, fields set to zero)
246  *----------------------------------------------------------------------------*/
247
250  size_t id);
251
252 /*----------------------------------------------------------------------------
253  * Return a kernel IO structure's echo (verbosity) level.
254  *
255  * parameters:
256  * pp_io <-- kernel IO structure
257  *----------------------------------------------------------------------------*/
258
259 size_t
260 cs_io_get_echo(const cs_io_t *pp_io);
261
262 /*----------------------------------------------------------------------------
263  * Read a message header.
264  *
265  * parameters:
266  * pp_io <-- kernel IO structure
267  * header --> header structure
268  *
269  * returns:
270  * 0 if a header was read, 1 in case of error or end-of-file
271  *----------------------------------------------------------------------------*/
272
273 int
275  cs_io_sec_header_t *header);
276
277 /*----------------------------------------------------------------------------
278  * Set a kernel IO's state so as to be ready to read an indexed section.
279  *
280  * The header values and position in the file are set so as to be equivalent
281  * to those they would have if the corresponding header had just been read.
282  *
283  * parameters:
284  * inp <-> input kernel IO structure
285  * header --> associated header
286  * id <-- id of section in index (0 to n-1 numbering)
287  *
288  * returns:
289  * 0 in case of success, 1 in case of error
290  *----------------------------------------------------------------------------*/
291
292 int
294  cs_io_sec_header_t *header,
295  size_t id);
296
297 /*----------------------------------------------------------------------------
298  * Set a section's final data type to int.
299  *
300  * It the datatype is not compatible, throw an error.
301  *
302  * parameters:
303  * header <-- header structure
304  * cs_io --> kernel IO structure
305  *----------------------------------------------------------------------------*/
306
307 void
309  const cs_io_t *cs_io);
310
311 /*----------------------------------------------------------------------------
312  * Set a message's final data type to cs_lnum_t.
313  *
314  * It the datatype is not compatible, throw an error.
315  *
316  * parameters:
317  * header <-- header structure
318  * pp_io --> kernel IO structure
319  *----------------------------------------------------------------------------*/
320
321 void
323  const cs_io_t *pp_io);
324
325 /*----------------------------------------------------------------------------
326  * Set a message's final data type to cs_gnum_t.
327  *
328  * It the datatype is not compatible, throw an error.
329  *
330  * parameters:
331  * header <-> header structure
332  * pp_io <-- kernel IO structure
333  *----------------------------------------------------------------------------*/
334
335 void
337  const cs_io_t *pp_io);
338
339 /*----------------------------------------------------------------------------
340  * Check that a message's final data type corresponds to cs_real_t.
341  *
342  * parameters:
343  * header <-- header structure
344  * pp_io <-- kernel IO structure
345  *----------------------------------------------------------------------------*/
346
347 void
349  const cs_io_t *pp_io);
350
351 /*----------------------------------------------------------------------------
352  * Read a message body and replicate it to all processors.
353  *
354  * If the array intended to receive the data already exists, we pass an
355  * "elt" pointer to this array; this same pointer is then returned.
356  * Otherwise, if this pointer is passed as NULL, memory is allocated
357  * by this function, and the corresponding pointer is returned. It is
358  * the caller's responsibility to free this array.
359  *
360  * parameters:
361  * header <-- header structure
362  * elts <-> pointer to data array, or NULL
363  * pp_io --> kernel IO structure
364  *
365  * returns:
366  * elts if non NULL, or pointer to allocated array otherwise
367  *----------------------------------------------------------------------------*/
368
369 void *
371  void *elts,
372  cs_io_t *pp_io);
373
374 /*----------------------------------------------------------------------------
375  * Read a message body, assigning a different block to each processor.
376  *
377  * If location_id > 0 and header->n_location_vals > 1, then
378  * global_num_start and global_num_end will be based on location element
379  * numbers, so the total number of values read equals
380  * (global_num_end - global_num_start) * header->n_location_vals.
381  *
382  * If the array intended to receive the data already exists, we pass an
383  * "elt" pointer to this array; this same pointer is then returned.
384  * Otherwise, if this pointer is passed as NULL, memory is allocated
385  * by this function, and the corresponding pointer is returned. It is
386  * the caller's responsibility to free this array.
387  *
388  * parameters:
389  * header <-- header structure
390  * global_num_start <-- global number of first block item (1 to n numbering)
391  * global_num_end <-- global number of past-the end block item
392  * (1 to n numbering)
393  * elts <-> pointer to data array, or NULL
394  * pp_io --> kernel IO structure
395  *
396  * returns:
397  * elts if non NULL, or pointer to allocated array otherwise
398  *----------------------------------------------------------------------------*/
399
400 void *
402  cs_gnum_t global_num_start,
403  cs_gnum_t global_num_end,
404  void *elts,
405  cs_io_t *pp_io);
406
407 /*----------------------------------------------------------------------------
408  * Read a message body, assigning a different block to each processor,
409  * when the body corresponds to an index.
410  *
411  * In serial mode, this function behaves just like cs_io_read_block(),
412  * except that it allows only unsigned integer values (cs_gnum_t).
413  *
414  * In parallel mode, global_num_end should be set to the past-the-end value
415  * of the base data block, the same as for regular data (and not increased
416  * by 1 for the last rank, as this will be handled internally).
417  * On each rank, the buffer size should be:
418  * global_num_end - global_num_start + 1, as the past-the end index
419  * for the local block is added automatically.
420  *
421  * If the array intended to receive the data already exists, we pass an
422  * "elt" pointer to this array; this same pointer is then returned.
423  * Otherwise, if this pointer is passed as NULL, memory is allocated
424  * by this function, and the corresponding pointer is returned. It is
425  * the caller's responsibility to free this array.
426  *
427  * parameters:
428  * header <-- header structure
429  * global_num_start <-- global number of first block item (1 to n numbering)
430  * global_num_end <-- global number of past-the end block item
431  * (1 to n numbering)
432  * elts <-> pointer to data array, or NULL
433  * pp_io --> kernel IO structure
434  *
435  * returns:
436  * elts if non NULL, or pointer to allocated array otherwise
437  *----------------------------------------------------------------------------*/
438
439 void *
441  cs_gnum_t global_num_start,
442  cs_gnum_t global_num_end,
443  cs_gnum_t *elts,
444  cs_io_t *pp_io);
445
446 /*----------------------------------------------------------------------------
447  * Write a global section.
448  *
449  * Under MPI, data is only written by the associated communicator's root
450  * rank. The section data on other ranks is ignored, though the file offset
451  * is updated (i.e. the call to this function is collective).
452  *
453  * parameters:
454  * section_name <-- section name
455  * n_vals <-- total number of values
456  * location_id <-- id of associated location, or 0
457  * index_id <-- id of associated index, or 0
458  * n_location_vals <-- number of values per location
459  * elt_type <-- element type
460  * elts <-- pointer to element data
461  * outp <-> output kernel IO structure
462  *----------------------------------------------------------------------------*/
463
464 void
465 cs_io_write_global(const char *sec_name,
466  cs_gnum_t n_vals,
467  size_t location_id,
468  size_t index_id,
469  size_t n_location_vals,
470  cs_datatype_t elt_type,
471  const void *elts,
472  cs_io_t *outp);
473
474 /*----------------------------------------------------------------------------
475  * Write a section to file, each associated process providing a contiguous
476  * of the section's body.
477  *
478  * Each process should provide a (possibly empty) block of the body,
479  * and we should have:
480  * global_num_start at rank 0 = 1
481  * global_num_start at rank i+1 = global_num_end at rank i.
482  * Otherwise, behavior (especially positioning for future reads) is undefined.
483  *
484  * If location_id > 0 and n_location_vals > 1, then global_num_start
485  * and global_num_end will be based on location element numbers, so the
486  * total number of values read equals
487  * (global_num_end - global_num_start) * header->n_location_vals.
488  *
489  * This function does not modify the values in its input buffer (notably,
490  * a copy is used to convert from little-endian to big-endian or vice-versa
491  * if necessary).
492  *
493  * parameters:
494  * section_name <-- section name
495  * n_g_elts <-- number of global elements (locations)
496  * global_num_start <-- global number of first block item (1 to n numbering)
497  * global_num_end <-- global number of past-the end block item
498  * location_id <-- id of associated location, or 0
499  * index_id <-- id of associated index, or 0
500  * n_location_vals <-- number of values per location
501  * elt_type <-- element type
502  * (1 to n numbering)
503  * elts <-- pointer to element data
504  * outp <-> output kernel IO structure
505  *----------------------------------------------------------------------------*/
506
507 void
508 cs_io_write_block(const char *sec_name,
509  cs_gnum_t n_g_elts,
510  cs_gnum_t global_num_start,
511  cs_gnum_t global_num_end,
512  size_t location_id,
513  size_t index_id,
514  size_t n_location_vals,
515  cs_datatype_t elt_type,
516  const void *elts,
517  cs_io_t *outp);
518
519 /*----------------------------------------------------------------------------
520  * Write a section to file, each associated process providing a contiguous
521  * of the section's body.
522  *
523  * Each process should provide a (possibly empty) block of the body,
524  * and we should have:
525  * global_num_start at rank 0 = 1
526  * global_num_start at rank i+1 = global_num_end at rank i.
527  * Otherwise, behavior (especially positioning for future reads) is undefined.
528  *
529  * If location_id > 0 and n_location_vals > 1, then global_num_start
530  * and global_num_end will be based on location element numbers, so the
531  * total number of values read equals
532  * (global_num_end - global_num_start) * header->n_location_vals.
533  *
534  * This function is intended to be used mainly on data that is already of
535  * copy of original data (such as data that has been redistributed across
536  * processors just for the sake of output), or that is to be deleted after
537  * writing, so it may modify the values in its input buffer (notably to
538  * convert from little-endian to big-endian or vice-versa if necessary).
539  *
540  * parameters:
541  * section_name <-- section name
542  * n_g_elts <-- number of global elements (locations)
543  * global_num_start <-- global number of first block item (1 to n numbering)
544  * global_num_end <-- global number of past-the end block item
545  * location_id <-- id of associated location, or 0
546  * index_id <-- id of associated index, or 0
547  * n_location_vals <-- number of values per location
548  * elt_type <-- element type
549  * (1 to n numbering)
550  * elts <-- pointer to element data
551  * outp <-> output kernel IO structure
552  *----------------------------------------------------------------------------*/
553
554 void
555 cs_io_write_block_buffer(const char *sec_name,
556  cs_gnum_t n_g_elts,
557  cs_gnum_t global_num_start,
558  cs_gnum_t global_num_end,
559  size_t location_id,
560  size_t index_id,
561  size_t n_location_vals,
562  cs_datatype_t elt_type,
563  void *elts,
564  cs_io_t *outp);
565
566 /*----------------------------------------------------------------------------
567  * Skip a message.
568  *
569  * parameters:
570  * header <-- header structure
571  * pp_io --> kernel IO structure
572  *----------------------------------------------------------------------------*/
573
574 void
575 cs_io_skip(const cs_io_sec_header_t *header,
576  cs_io_t *pp_io);
577
578 /*----------------------------------------------------------------------------
579  * Return the position of the file pointer for an open kernel IO file.
580  *
581  * parameters:
582  * inp <-- input kernel IO structure
583  *
584  * returns:
585  * offset in file
586  *----------------------------------------------------------------------------*/
587
590
591 /*----------------------------------------------------------------------------
592  * Set the position of the file pointer for an open kernel IO file.
593  *
594  * parameters:
595  * inp <-- input kernel IO structure
596  * offset <-- offset in file
597  *----------------------------------------------------------------------------*/
598
599 void
601  cs_file_off_t offset);
602
603 /*----------------------------------------------------------------------------
604  * Initialize performance logging for cs_io_t structures.
605  *----------------------------------------------------------------------------*/
606
607 void
609
610 /*----------------------------------------------------------------------------
611  * Finalize performance logging for cs_io_t structures.
612  *----------------------------------------------------------------------------*/
613
614 void
615 cs_io_log_finalize(void);
616
617 /*----------------------------------------------------------------------------
618  * Dump a kernel IO file handle's metadata.
619  *
620  * parameters:
621  * cs_io <-- kernel IO structure
622  *----------------------------------------------------------------------------*/
623
624 void
625 cs_io_dump(const cs_io_t *cs_io);
626
627 /*----------------------------------------------------------------------------*/
628
630
631 #endif /* __CS_IO_H__ */
integer, dimension(nclcpm), save inp
number of particles of the class icla per kg of air-coal mixture
Definition: ppincl.f90:463
const char * cs_io_get_indexed_sec_name(const cs_io_t *inp, size_t id)
Definition: cs_io.c:2031
void cs_io_skip(const cs_io_sec_header_t *header, cs_io_t *pp_io)
Definition: cs_io.c:3050
cs_datatype_t
Definition: cs_defs.h:275
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
cs_io_t * cs_io_initialize_with_index(const char *file_name, const char *magic_string, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_io.c:1882
void cs_io_dump(const cs_io_t *cs_io)
Definition: cs_io.c:3260
Definition: cs_io.h:80
Definition: cs_io.h:81
void cs_io_set_offset(cs_io_t *inp, cs_file_off_t offset)
Definition: cs_io.c:3121
void cs_io_set_int(cs_io_sec_header_t *header, const cs_io_t *cs_io)
Definition: cs_io.c:2398
void * cs_io_read_global(const cs_io_sec_header_t *header, void *elts, cs_io_t *pp_io)
Definition: cs_io.c:2541
cs_io_mode_t
Definition: cs_io.h:59
const char * cs_io_get_name(const cs_io_t *pp_io)
Definition: cs_io.c:1991
void cs_io_assert_cs_real(const cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.c:2506
Definition: cs_defs.h:512
size_t index_id
Definition: cs_io.h:78
size_t location_id
Definition: cs_io.h:77
const char * sec_name
Definition: cs_io.h:75
cs_io_t * cs_io_initialize(const char *file_name, const char *magic_string, cs_io_mode_t mode, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_io.c:1819
Definition: cs_io.h:62
void cs_io_log_initialize(void)
Definition: cs_io.c:3137
#define MPI_Info
Definition: cs_defs.h:93
Definition: cs_io.h:61
Definition: cs_io.h:68
Definition: cs_io.h:79
long long cs_file_off_t
Definition: cs_file.h:107
void cs_io_write_block_buffer(const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, void *elts, cs_io_t *outp)
Definition: cs_io.c:2976
Definition: cs_io.h:76
size_t cs_io_get_echo(const cs_io_t *pp_io)
Definition: cs_io.c:2101
cs_file_off_t cs_io_get_offset(cs_io_t *inp)
Definition: cs_io.c:3104
cs_io_sec_header_t cs_io_get_indexed_sec_header(const cs_io_t *inp, size_t id)
Definition: cs_io.c:2058
void cs_io_set_cs_gnum(cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.c:2472
void * cs_io_read_index_block(cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, cs_gnum_t *elts, cs_io_t *pp_io)
Definition: cs_io.c:2624
void cs_io_log_finalize(void)
Definition: cs_io.c:3154
int cs_io_set_indexed_position(cs_io_t *inp, cs_io_sec_header_t *header, size_t id)
Definition: cs_io.c:2334
void cs_io_write_block(const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
Definition: cs_io.c:2875
void * cs_io_read_block(const cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, void *elts, cs_io_t *pp_io)
Definition: cs_io.c:2575
cs_file_access_t
Shared file access methods.
Definition: cs_file.h:84
void cs_io_set_cs_lnum(cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.c:2435
Definition: cs_defs.h:513
void cs_io_write_global(const char *sec_name, cs_gnum_t n_vals, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
Definition: cs_io.c:2784
size_t cs_io_get_index_size(const cs_io_t *inp)
Definition: cs_io.c:2009
int cs_io_read_header(cs_io_t *inp, cs_io_sec_header_t *header)
Definition: cs_io.c:2123
Definition: cs_io.h:73
void cs_io_finalize(cs_io_t **pp_io)
Definition: cs_io.c:1953
