7.3
cs_gradient_priv.h
1 #ifndef __CS_GRADIENT_CUDA_H__
2 #define __CS_GRADIENT_CUDA_H__
5  * Private functions for gradient reconstruction.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_base_accel.h"
36 #include "cs_halo.h"
37 #include "cs_internal_coupling.h"
38 #include "cs_mesh.h"
39 #include "cs_mesh_quantities.h"
48  * Macro definitions
50
51 /*=============================================================================
52  * Local type definitions
54
55 /* Type for symmetric least-squares covariance matrices
56  as they are adimensional, single-precision should be usable here */
57
58 typedef cs_real_t cs_cocg_t;
59 typedef cs_real_t cs_cocg_6_t[6];
60 typedef cs_real_t cs_cocg_33_t[3][3];
61
62 /*============================================================================
63  * Global variables
64  *============================================================================*/
65
66 /*=============================================================================
67  * Semi-private function prototypes
68  *============================================================================*/
69
70 #if defined(HAVE_CUDA)
71
72 /*----------------------------------------------------------------------------
73  * Compute cell gradient using least-squares reconstruction for non-orthogonal
74  * meshes (nswrgp > 1).
75  *
76  * Optionally, a volume force generating a hydrostatic pressure component
77  * may be accounted for.
78  *
79  * cocg is computed to account for variable B.C.'s (flux).
80  *
81  * parameters:
82  * m <-- pointer to associated mesh structure
83  * fvq <-- pointer to associated finite volume quantities
84  * halo_type <-- halo type (extended or not)
85  * recompute_cocg <-- flag to recompute cocg
86  * inc <-- if 0, solve on increment; 1 otherwise
87  * coefap <-- B.C. coefficients for boundary face normals
88  * coefbp <-- B.C. coefficients for boundary face normals
89  * pvar <-- variable
90  * c_weight <-- weighted gradient coefficient variable,
91  * or NULL
92  * cocg <-> associated cell covariance array (on device)
93  * cocgb <-> saved boundary cell covariance array (on device)
94  * grad <-> gradient of pvar (halo prepared for periodicity
95  * of rotation)
96  *----------------------------------------------------------------------------*/
97
98 void
99 cs_gradient_scalar_lsq_cuda(const cs_mesh_t *m,
100  const cs_mesh_quantities_t *fvq,
101  cs_halo_type_t halo_type,
102  bool recompute_cocg,
103  cs_real_t inc,
104  const cs_real_t coefap[],
105  const cs_real_t coefbp[],
106  const cs_real_t pvar[],
107  const cs_real_t *restrict c_weight,
108  cs_cocg_6_t *restrict cocg,
109  cs_cocg_6_t *restrict cocgb,
110  cs_real_3_t *restrict grad);
111
112 #endif /* defined(HAVE_CUDA) */
113
116 /*----------------------------------------------------------------------------*/
117
119
120 #endif /* __CS_GRADIENT_CUDA_H__ */
#define restrict
Definition: cs_defs.h:142
Definition: cs_defs.h:512
Definition: cs_defs.h:322
Definition: cs_mesh.h:85
cs_halo_type_t
Definition: cs_halo.h:56
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
Definition: cs_defs.h:513
