7.3
cs_equation_system_param.h
1 #ifndef __CS_EQUATION_SYSTEM_PARAM_H__
2 #define __CS_EQUATION_SYSTEM_PARAM_H__
5  * Functions to handle a set of coupled equations hinging on the cs_equation_t
6  * structure
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
29 /*----------------------------------------------------------------------------
30  * Local headers
31  *----------------------------------------------------------------------------*/
32
33 #include "cs_equation_param.h"
34 #include "cs_iter_algo.h"
35 #include "cs_param_types.h"
36
38
42  * Macro definitions
46  * Type definitions
48
59 typedef enum {
60
62
64
66
71 typedef struct {
72
91  char *restrict name;
92
93  int verbosity;
94
96
98
115
117
119
125
126
156 typedef enum {
157
165
167
169
170 /*============================================================================
171  * Public function prototypes
172  *============================================================================*/
173 /*----------------------------------------------------------------------------*/
182 /*----------------------------------------------------------------------------*/
183
185 cs_equation_system_param_create(const char *name,
186  int block_var_dim);
187
188 /*----------------------------------------------------------------------------*/
196 /*----------------------------------------------------------------------------*/
197
200
201 /*----------------------------------------------------------------------------*/
207 /*----------------------------------------------------------------------------*/
208
209 void
211
212 /*----------------------------------------------------------------------------*/
221 /*----------------------------------------------------------------------------*/
222
223 void
226  const char *keyval);
227
228 /*----------------------------------------------------------------------------*/
229
231
232 #endif /* __CS_EQUATION_SYSTEM_PARAM_H__ */
#define restrict
Definition: cs_defs.h:142
Definition: cs_equation_system_param.h:166
cs_equation_system_sles_strategy_t
High-level information about the way of solving the system of equations.
Definition: cs_equation_system_param.h:59
int block_var_dim
Definition: cs_equation_system_param.h:97
Definition: cs_defs.h:512
Definition: cs_equation_system_param.h:162
Definition: cs_equation_system_param.h:158
void cs_equation_system_param_set(cs_equation_system_param_t *sysp, cs_equation_system_key_t key, const char *keyval)
Set a parameter related to a keyname in a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:208
cs_iter_algo_param_t linear_solver
Definition: cs_equation_system_param.h:118
List of available keys for setting the parameters of a system of equations.
Definition: cs_equation_system_param.h:156
bool sles_setup_done
Definition: cs_equation_system_param.h:114
Definition: cs_equation_system_param.h:163
int verbosity
Definition: cs_equation_system_param.h:93
Definition: cs_equation_system_param.h:161
Definition: cs_equation_system_param.h:63
cs_param_space_scheme_t
Definition: cs_param_types.h:207
Definition: cs_equation_system_param.h:159
Main structure storing the parameter settings.
Definition: cs_equation_system_param.h:71
char *restrict name
Definition: cs_equation_system_param.h:91
Definition: cs_equation_system_param.h:61
cs_equation_system_param_t * cs_equation_system_param_free(cs_equation_system_param_t *sysp)
Free a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:140
Definition: cs_equation_system_param.h:164
cs_param_space_scheme_t space_scheme
Definition: cs_equation_system_param.h:95
Definition: cs_equation_system_param.h:160
Definition: cs_defs.h:513
Definition: cs_iter_algo.h:53
void cs_equation_system_param_log(const cs_equation_system_param_t *sysp)
Log the setup gathered in the structure cs_equation_system_param_t.
Definition: cs_equation_system_param.c:161
cs_equation_system_param_t * cs_equation_system_param_create(const char *name, int block_var_dim)
Create and initialize a new cs_equation_system_param_t structure.
Definition: cs_equation_system_param.c:91
cs_equation_system_sles_strategy_t sles_strategy
Definition: cs_equation_system_param.h:116
