7.3
cs_coolprop.hxx
1 #ifndef __CS_COOLPROP_HXX__
2 #define __CS_COOLPROP_HXX__
5  * Equation of state
35  * Local headers
38 #include "cs_physical_properties.h"
40 #include "cs_base.h"
45  * Local Macro Definitions
49  * Structure definition
51
53  * Global variables definition
55
56 /*============================================================================
57  * Public function prototypes
59
60 /*----------------------------------------------------------------------------*/
76 /*----------------------------------------------------------------------------*/
77
78 #ifdef __cplusplus
79 extern "C"
80 #endif
81 void
82 cs_phys_prop_coolprop(char *coolprop_material,
83  const char *coolprop_backend,
85  cs_phys_prop_type_t property,
86  const cs_lnum_t n_vals,
87  const cs_real_t var1[],
88  const cs_real_t var2[],
89  cs_real_t val[]);
90
91 /*----------------------------------------------------------------------------*/
92
93 #endif /* __CS_COOLPROP_HXX__ */
94
cs_phys_prop_type_t
Definition: cs_physical_properties.h:52
void cs_phys_prop_coolprop(char *coolprop_material, const char *coolprop_backend, cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Computes physical properties in (P,h,Yi) for compressible flow.
Definition: cs_coolprop.cxx:98
Definition: cs_defs.h:322
Definition: cs_physical_properties.h:40
Definition: cs_defs.h:316
