1 #ifndef __CS_COMBUSTION_MODEL_H__ 2 #define __CS_COMBUSTION_MODEL_H__ 52 #define CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES 25 55 #define CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS 20 58 #define CS_COMBUSTION_MAX_COALS 5 61 #define CS_COMBUSTION_MAX_CLASSES_PER_COAL 20 64 #define CS_COMBUSTION_MAX_COAL_CLASSES CS_COMBUSTION_MAX_COALS \ 65 * CS_COMBUSTION_MAX_CLASSES_PER_COAL 68 #define CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS 1 71 #define CS_COMBUSTION_MAX_OXYDANTS 3 double h02fol
Definition: cs_combustion_model.h:151
double hinfue
Definition: cs_combustion_model.h:150
Definition: cs_combustion_model.h:68
int n_reactions
Definition: cs_combustion_model.h:169
Definition: cs_combustion_model.h:71
int n_atomic_species
Definition: cs_combustion_model.h:167
double cp2fol
Definition: cs_combustion_model.h:152
real(c_double), dimension(:), pointer, save rho2mn
Definition: cpincl.f90:196
Definition: cs_combustion_model.h:147
real(c_double), dimension(:), pointer, save xmp0
real(c_double), dimension(:), pointer, save rho20
Definition: cs_combustion_model.h:58
Definition: cs_defs.h:512
int nclacp
Definition: cs_combustion_model.h:113
double hinfue
Definition: cs_combustion_model.h:84
double precision, dimension(:,:), pointer, save compog
Definition: coincl.f90:56
integer(c_int), dimension(:), pointer, save ichcor
Definition: cpincl.f90:195
Definition: cs_combustion_model.h:110
real(c_double), dimension(:), pointer, save wmole
molar mass of an elementary gas component
Definition: ppthch.f90:134
void cs_combustion_log_setup(void)
Print the combustion module options to setup.log.
cs_combustion_model_t * cs_glob_combustion_model
Definition: cs_combustion_model.c:117
Definition: cs_combustion_model.h:80
double ckabs0
Definition: cs_combustion_model.h:179
int nclafu
Definition: cs_combustion_model.h:149
int in2
Definition: cs_combustion_model.h:175
int io2
Definition: cs_combustion_model.h:174
double hinoxy
Definition: cs_combustion_model.h:183
real(c_double), dimension(:), pointer, save oxyo2
Definition: ppcpfu.f90:180
real(c_double), dimension(:), pointer, save fs
Mixing rate at the stoichiometry.
Definition: ppthch.f90:147
real(c_double), dimension(:), pointer, save oxyco2
int ico2
Definition: cs_combustion_model.h:176
int n_coals
Definition: cs_combustion_model.h:112
int iic
Definition: cs_combustion_model.h:82
double xsoot
Definition: cs_combustion_model.h:86
Definition: cs_combustion_model.h:159
real(c_double), dimension(:), pointer, save oxyn2
real(c_double), dimension(:), pointer, save dia2mn
real(c_double), dimension(:), pointer, save wmolg
molar mass of a global species
Definition: ppthch.f90:137
int ih2o
Definition: cs_combustion_model.h:177
cs_combustion_gas_model_t gas
Definition: cs_combustion_model.h:161
real(c_double), dimension(:), pointer, save oxyh2o
double xco2
Definition: cs_combustion_model.h:181
real(c_double), dimension(:), pointer, save xashch
Definition: cpincl.f90:115
Definition: cs_defs.h:513
cs_combustion_coal_model_t coal
Definition: cs_combustion_model.h:162
double precision, dimension(:,:), pointer, save coefeg
Definition: coincl.f90:52
Definition: cs_combustion_model.h:64
Definition: cs_combustion_model.h:52
double xh2o
Definition: cs_combustion_model.h:182
cs_combustion_fuel_model_t fuel
Definition: cs_combustion_model.h:163
int isoot
Definition: cs_combustion_model.h:172
Definition: cs_combustion_model.h:55
real(c_double), dimension(:), pointer, save diam20
int n_gas_el_comp
Definition: cs_combustion_model.h:165
int n_gas_species
Definition: cs_combustion_model.h:166
double rosoot
Definition: cs_combustion_model.h:87
