7.3
cs_cdofb_monolithic_sles.h
1 #ifndef __CS_CDOFB_MONOLITHIC_SLES_H__
2 #define __CS_CDOFB_MONOLITHIC_SLES_H__
5  * Functions dedicated to the linear algebra settings and operations in case
6  * of CDO face-based schemes with a monolithic velocity-pressure coupling
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
46
48  * Macro definitions
50
52  * Type definitions
54
55 /*============================================================================
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------*/
68 /*----------------------------------------------------------------------------*/
69
72  cs_lnum_t n_cells);
73
81
82 void
84
91 /*----------------------------------------------------------------------------*/
92
93 void
95
96 /*----------------------------------------------------------------------------*/
103 /*----------------------------------------------------------------------------*/
104
105 void
107  const cs_cdo_quantities_t *quant);
108
109 /*----------------------------------------------------------------------------*/
114 /*----------------------------------------------------------------------------*/
115
116 void
118
119 /*----------------------------------------------------------------------------*/
130 /*----------------------------------------------------------------------------*/
131
132 void
134  void *context);
135
136 /*----------------------------------------------------------------------------*/
151 /*----------------------------------------------------------------------------*/
152
153 int
155  const cs_equation_param_t *eqp,
156  const cs_cdo_system_helper_t *sh,
157  cs_param_sles_t *slesp,
159
160 /*----------------------------------------------------------------------------*/
176 /*----------------------------------------------------------------------------*/
177
178 int
180  const cs_equation_param_t *eqp,
181  const cs_cdo_system_helper_t *sh,
182  cs_param_sles_t *slesp,
184
185 /*----------------------------------------------------------------------------*/
199 /*----------------------------------------------------------------------------*/
200
201 int
203  const cs_equation_param_t *eqp,
204  const cs_cdo_system_helper_t *sh,
205  cs_param_sles_t *slesp,
207
208 /*----------------------------------------------------------------------------*/
225 /*----------------------------------------------------------------------------*/
226
227 int
229  const cs_equation_param_t *eqp,
230  const cs_cdo_system_helper_t *sh,
231  cs_param_sles_t *slesp,
233
234 /*----------------------------------------------------------------------------*/
249 /*----------------------------------------------------------------------------*/
250
251 int
253  const cs_equation_param_t *eqp,
254  const cs_cdo_system_helper_t *sh,
255  cs_param_sles_t *slesp,
257
258 /*----------------------------------------------------------------------------*/
259
261
262 #endif /* __CS_CDOFB_MONOLITHIC_SLES_H__ */
void cs_cdofb_monolithic_sles_finalize(void)
Free if needed structure(s) associated CDO face-based schemes with a monolithic velocity-pressure cou...
Definition: cs_cdofb_monolithic_sles.c:4190
int cs_cdofb_monolithic_krylov_block_precond(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Solve a linear system arising from the discretization of the Navier-Stokes equation with a CDO face-b...
Definition: cs_cdofb_monolithic_sles.c:4678
cs_cdofb_monolithic_sles_t * cs_cdofb_monolithic_sles_create(cs_lnum_t n_faces, cs_lnum_t n_cells)
Create an empty cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:4096
Definition: cs_defs.h:512
int cs_cdofb_monolithic_uzawa_al_incr_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the Uzawa algorithm with an Augmented Lagrangian (ALU) technique in an incremental way to solve t...
Definition: cs_cdofb_monolithic_sles.c:5402
Definition: cs_cdo_system.h:368
Definition: cs_navsto_param.h:604
Definition: cs_cdo_quantities.h:132
Definition: cs_cdofb_monolithic_priv.h:77
void cs_cdofb_monolithic_sles_init_sharing(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Set pointers to shared structures.
Definition: cs_cdofb_monolithic_sles.c:4173
void cs_cdofb_monolithic_set_sles(cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to couple the system...
Definition: cs_cdofb_monolithic_sles.c:4210
Definition: cs_defs.h:316
void cs_cdofb_monolithic_sles_clean(cs_cdofb_monolithic_sles_t *msles)
Free a part of the structure.
Definition: cs_cdofb_monolithic_sles.c:4128
Definition: cs_defs.h:513
int cs_cdofb_monolithic_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Definition: cs_cdofb_monolithic_sles.c:4469
int cs_cdofb_monolithic_gkb_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the GKB algorithm to solve the saddle-point problem arising from CDO-Fb schemes for Stokes and Na...
Definition: cs_cdofb_monolithic_sles.c:4888
Structures and function pointers useful to build and solve the Navier-Stokes equations with face-base...
Structure storing all metadata related to the resolution of a linear system with an iterative solver...
Definition: cs_param_sles.h:62
void cs_cdofb_monolithic_sles_free(cs_cdofb_monolithic_sles_t **p_msles)
Free memory related to cs_cdofb_monolithic_sles_t structure.
Definition: cs_cdofb_monolithic_sles.c:4146
int cs_cdofb_monolithic_uzawa_cg_solve(const cs_navsto_param_t *nsp, const cs_equation_param_t *eqp, const cs_cdo_system_helper_t *sh, cs_param_sles_t *slesp, cs_cdofb_monolithic_sles_t *msles)
Use the preconditioned Uzawa-CG algorithm to solve the saddle-point problem arising from CDO-Fb schem...
Definition: cs_cdofb_monolithic_sles.c:5059
