1 #ifndef __CS_CDOFB_AC_H__ 2 #define __CS_CDOFB_AC_H__ 169 void *scheme_context);
187 void *scheme_context);
void cs_cdofb_ac_init_common(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdofb_ac.c:905
time step descriptor
Definition: cs_time_step.h:64
int cs_boundary_type_t
Definition: cs_boundary.h:69
Definition: cs_advection_field.h:150
Definition: cs_defs.h:512
void cs_cdofb_ac_set_sles(const cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when an AC algorithm is used to couple the system...
Definition: cs_cdofb_ac.c:1101
static cs_real_t * cs_cdofb_ac_get_face_velocity(bool previous)
Retrieve the values of the velocity on the faces.
Definition: cs_cdofb_ac.h:78
Definition: cs_navsto_param.h:604
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
void * cs_cdofb_ac_init_scheme_context(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nsc_input)
Initialize a cs_cdofb_ac_t structure.
Definition: cs_cdofb_ac.c:932
void cs_cdofb_ac_compute_implicit_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibili...
Definition: cs_cdofb_ac.c:1325
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns...
Definition: cs_equation.c:3003
Definition: cs_defs.h:513
void cs_cdofb_ac_compute_implicit(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Definition: cs_cdofb_ac.c:1165
void * cs_cdofb_ac_free_scheme_context(void *scheme_context)
Destroy a cs_cdofb_ac_t structure.
Definition: cs_cdofb_ac.c:1064
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return NULL if not find.
Definition: cs_equation.c:474
