1 #ifndef __CS_BOUNDARY_CONDITIONS_H__ 2 #define __CS_BOUNDARY_CONDITIONS_H__ 97 const char *type_name);
166 ple_locator_t *locator,
202 int source_location_id,
275 for (
size_t i = 0; i < 3; i++) {
276 a[i] = -qimpv[i] /
fmax(hint, 1.e-300);
279 b[0][0] = 1., b[0][1] = 0., b[0][2] = 0.;
280 b[1][0] = 0., b[1][1] = 1., b[1][2] = 0.;
281 b[2][0] = 0., b[2][1] = 0., b[2][2] = 1.;
285 for (
288 for (
size_t j = 0; j < 3; j++)
331 *a = hext*pimp/(hint + hext);
332 *b = hint /(hint + hext);
366 for (
int isou = 0; isou < 3; isou++) {
370 a[isou] = pimpv[isou];
371 for (
int jsou = 0; jsou < 3; jsou++)
375 af[isou] = -hint*pimpv[isou];
376 for (
int jsou = 0; jsou < 3; jsou++) {
378 bf[isou][jsou] = hint;
384 cs_real_t heq = hint*hextv[isou]/(hint + hextv[isou]);
387 a[isou] = hextv[isou]*pimpv[isou]/(hint + hextv[isou]);
388 for (
390 b[isou][jsou] = hint/(hint + hextv[isou]);
396 af[isou] = -heq*pimpv[isou];
397 for (
399 bf[isou][jsou] = heq;
457 for (
459 a[isou] = pimpv[isou];
460 for (
471 for (
472 af[isou] = -af[isou];
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
static void cs_boundary_conditions_set_neumann_vector(cs_real_t a[3], cs_real_t af[3], cs_real_t b[3][3], cs_real_t bf[3][3], const cs_real_t qimpv[3], cs_real_t hint)
Set Neumann BC for a scalar for a given face.
Definition: cs_boundary_conditions.h:266
Definition: cs_field.h:130
cs_mesh_location_type_t
Definition: cs_mesh_location.h:60
void cs_boundary_conditions_free(void)
Free the boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.c:1280
Definition: cs_defs.h:512
void cs_boundary_conditions_compute(int itypfb[])
Update per variable boundary condition codes.
Definition: cs_boundary_conditions.c:1376
void cs_exit(int status)
Definition: cs_base.c:1505
void cs_boundary_conditions_complete(int itypfb[])
Automatic adjustments for boundary condition codes.
Definition: cs_boundary_conditions.c:1552
void cs_boundary_conditions_create(void)
Create the legacy boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.c:1240
const int * cs_glob_bc_face_zone
Definition: cs_defs.h:322
static void cs_boundary_conditions_set_dirichlet_scalar(cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t pimp, cs_real_t hint, cs_real_t hext)
Set Dirichlet BC for a scalar for a given face.
Definition: cs_boundary_conditions.h:309
void cs_boundary_conditions_set_convective_outlet_scalar(cs_real_t *coefa, cs_real_t *cofaf, cs_real_t *coefb, cs_real_t *cofbf, cs_real_t pimp, cs_real_t cfl, cs_real_t hint)
Set convective oulet boundary condition for a scalar.
Definition: cs_boundary_conditions.c:1307
double precision, save a
Definition: cs_fuel_incl.f90:148
integer, dimension(:), pointer, save itypfb
Definition: pointe.f90:100
double precision, save fmax
Definition: coincl.f90:182
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
static void cs_boundary_conditions_set_dirichlet_vector(cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_t hint, cs_real_3_t hextv)
Set Dirichlet BC for a vector for a given face.
Definition: cs_boundary_conditions.h:358
Definition: cs_defs.h:316
static void cs_boundary_conditions_set_dirichlet_vector_aniso(cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_6_t hintt, cs_real_3_t hextv)
Set Dirichlet BC for a vector for a given face with left anisotropic diffusion.
Definition: cs_boundary_conditions.h:448
Definition: cs_defs.h:513
double precision, dimension(nozppm), save qimp
Definition: coincl.f90:157
void cs_boundary_conditions_mapped_set(const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w)
Set mapped boundary conditions for a given field and mapping locator.
Definition: cs_boundary_conditions.c:1012
void cs_boundary_conditions_reset(void)
Prepare (reset) condition coefficients for all variable fields.
Definition: cs_boundary_conditions.c:1331
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:344
static void cs_math_sym_33_3_product(const cs_real_t m[6], const cs_real_t v[3], cs_real_t mv[restrict 3])
Compute the product of a symmetric matrix of 3x3 real values by a vector of 3 real values...
Definition: cs_math.h:616
void cs_boundary_conditions_error(const int *bc_type, const char *type_name)
Handling of boundary condition definition errors and associated output.
Definition: cs_boundary_conditions.c:806
static void cs_boundary_conditions_set_neumann_scalar(cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t qimp, cs_real_t hint)
Definition: cs_boundary_conditions.h:236
int cs_boundary_conditions_add_map(int bc_location_id, int source_location_id, cs_real_t coord_shift[3], double tolerance)
Add location of locate shifted boundary face coordinates on cells or boundary faces for automatic int...
Definition: cs_boundary_conditions.c:1207
const cs_real_t cs_math_infinite_r
ple_locator_t * cs_boundary_conditions_map(cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance)
Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later inter...
Definition: cs_boundary_conditions.c:860
const int * cs_glob_bc_type
double precision, save b
