7.3
cs_block_dist.h
1 #ifndef __CS_BLOCK_DIST_H__
2 #define __CS_BLOCK_DIST_H__
5  * Definition of a block distribution.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /* Information structure for block size and entity range */
49
50 typedef struct {
51
52  cs_gnum_t gnum_range[2]; /* Start and past-the-end global numbers
53  associated with local block */
54  int n_ranks; /* Number of active ranks */
55  int rank_step; /* Step between active block ranks
56  (1 in basic case, > 1 if we seek to
57  avoid too small buffers and agglomerate
58  blocks on only a few ranks) */
59  cs_lnum_t block_size; /* Basic block size */
60
62
63 /*=============================================================================
64  * Public function prototypes
65  *============================================================================*/
66
67 /*----------------------------------------------------------------------------
68  * Compute block size and rank info for use with a block distribution.
69  *
70  * arguments:
71  * rank_id <-- id of local rank
72  * n_ranks <-- number of associated ranks
73  * min_rank_step <-- minimum rank step between blocks
74  * min_block_size <-- minimum number of entities per block
75  * n_g_ents <-- total number of associated entities
76  *
77  * returns:
78  * block size and range info structure
79  *----------------------------------------------------------------------------*/
80
82 cs_block_dist_compute_sizes(int rank_id,
83  int n_ranks,
84  int min_rank_step,
85  cs_lnum_t min_block_size,
86  cs_gnum_t n_g_ents);
87
88 /*----------------------------------------------------------------------------
89  * Compute block size and rank info for use with a block distribution
90  * for a new global number of entities with a given number of active
91  * ranks.
92  *
93  * arguments:
94  * rank_id <-- id of local rank (ignored in serial mode)
95  * n_ranks <-- number of associated ranks
96  * n_block_ranks <-- number of ranks associated with a block
97  * n_g_ents <-- total number of associated entities
98  *
99  * returns:
100  * block size and range info structure
101  *----------------------------------------------------------------------------*/
102
105  int n_ranks,
106  int n_block_ranks,
107  cs_gnum_t n_g_ents);
108
109 /*----------------------------------------------------------------------------*/
110
112
113 #endif /* __CS_BLOCK_DIST_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
cs_block_dist_info_t cs_block_dist_compute_sizes(int rank_id, int n_ranks, int min_rank_step, cs_lnum_t min_block_size, cs_gnum_t n_g_ents)
Definition: cs_block_dist.c:91
Definition: cs_defs.h:512
int n_ranks
Definition: cs_block_dist.h:54
int rank_step
Definition: cs_block_dist.h:55
cs_block_dist_info_t cs_block_dist_compute_sizes_nr(int rank_id, int n_ranks, int n_block_ranks, cs_gnum_t n_g_ents)
Compute block size and rank info for use with a block distribution for a new global number of entitie...
Definition: cs_block_dist.c:196
Definition: cs_defs.h:316
Definition: cs_defs.h:513
Definition: cs_block_dist.h:59
