7.3
cs_1d_wall_thermal.h
1 #ifndef __CS_1D_WALL_THERMAL_H__
2 #define __CS_1D_WALL_THERMAL_H__
5  * Modelling the thermal wall with 1D approach
35  * Local headers
38 #include "cs_base.h"
45  * Macro definitions
49  * Type definitions
51
52 /*----------------------------------------------------------------------------
53  * 1D Wall Thermal local model type (local to a coupled boundary face)
54  *----------------------------------------------------------------------------*/
55
56 typedef struct {
57
58  int nppt1d; /* Number of discretisation cells in the 1D wall
59  * at a given boundary face which is coupled
60  * with a 1D wall thermal module.*/
61
62  int iclt1d; /* Boundary condition type at the external (pseudo)
63  * wall:
64  - 1: Dirichlet,
65  - 2: Flux condition. */
66
67  cs_real_t eppt1d; /* Thickness of the 1D wall for the nfpt1d boundary faces
68  * which are coupled with a 1D wall thermal module. */
69
70  cs_real_t rgpt1d; /* Geometry of the pseudo wall mesh (refined as a fluid
71  * if rgt1d is smaller than 1.*/
72
73  cs_real_t tept1d; /* External temperature of the pseudo wall in the Dirichlet
74  * case. */
75
76  cs_real_t hept1d; /* External coefficient of transfer in the pseudo wall
77  * under Dirichlet conditions, in W.m^-2.K. */
78
79  cs_real_t fept1d; /* External heat flux in the pseudo wall under the flux
80  * conditions (in W.m^-2, negative value for energy
81  * entering the wall). */
82
83  cs_real_t xlmbt1; /* Thermal diffusivity. */
84
85  cs_real_t rcpt1d; /* Volumetric heat capacity rho C_p of the wall uniform
86  * in thickness (in J.m^-3.K^-1). */
87
88  cs_real_t dtpt1d; /* Physical time step associated with the solved 1D equation
89  * of the pseudo wall (which can be different from the time
90  * step of the calculation). */
91
92  cs_real_t *z; /* Discretization points coordinates. */
93
94  cs_real_t *t; /* Temperature at each point of discretization. */
95
97
98 /*----------------------------------------------------------------------------
99  * 1D Wall Thermal module type
100  *----------------------------------------------------------------------------*/
101
102 typedef struct {
103
104  cs_lnum_t nfpt1d; /* Number of boundary faces which are coupled
105  * with a 1D wall thermal module. */
106
107  cs_gnum_t nfpt1t; /* Global number of boundary faces which are coupled with
108  * a 1D wall thermal module, i.e. sum of nfpt1d over all
109  * ranks */
110
111  int nmxt1d; /* Maximum number of discretization cells in 1d wall */
112
113  cs_lnum_t *izft1d; /* Zones of t1d, dimensioned with nfabor */
114
115  cs_lnum_t *ifpt1d; /* Array allowing to mark out the numbers of
116  * the nfpt1d boundary faces which are coupled with
117  * a 1D wall. */
118
119  cs_real_t *tppt1d; /* Initialisation temperature of the wall (uniform in
120  * thickness). During the calculation, the array stores
121  * the temperature of the solid at the fluid/solid
122  * interface. */
123
124  cs_1d_wall_thermal_local_model_t *local_models; /* Array of structures */
125
127
128 /*============================================================================
129  * Static global variables
130  *============================================================================*/
131
132 /* Pointer to the 1D wall thermal structure */
133
135
136 /*============================================================================
137  * Public function prototypes
138  *============================================================================*/
139
140  /*----------------------------------------------------------------------------*/
144 /*----------------------------------------------------------------------------*/
145
146 void
148
149 /*----------------------------------------------------------------------------*/
153 /*----------------------------------------------------------------------------*/
154
155 void
157
158 /*----------------------------------------------------------------------------*/
162 /*----------------------------------------------------------------------------*/
163
164 void
166
167 /*----------------------------------------------------------------------------*/
176 /*----------------------------------------------------------------------------*/
177
178 void
180  cs_real_t tf,
181  cs_real_t hf);
182
183 /*----------------------------------------------------------------------------*/
187 /*----------------------------------------------------------------------------*/
188
189 void
191
192 /*----------------------------------------------------------------------------*/
196 /*----------------------------------------------------------------------------*/
197
198 void
200
201 /*----------------------------------------------------------------------------*/
205 /*----------------------------------------------------------------------------*/
206
207 void
209
210 /*----------------------------------------------------------------------------*/
214 /*----------------------------------------------------------------------------*/
215
216 void
218
219 /*----------------------------------------------------------------------------*/
223 /*----------------------------------------------------------------------------*/
224
227
228 /*----------------------------------------------------------------------------*/
232 /*----------------------------------------------------------------------------*/
233
234 void
236
237 /*----------------------------------------------------------------------------*/
238
240
241 #endif /* __CS_1D_WALL_THERMAL_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
cs_lnum_t * izft1d
Definition: cs_1d_wall_thermal.h:113
Definition: cs_1d_wall_thermal.h:56
Definition: cs_defs.h:512
cs_real_t rcpt1d
Definition: cs_1d_wall_thermal.h:85
cs_real_t * z
Definition: cs_1d_wall_thermal.h:92
cs_real_t dtpt1d
Definition: cs_1d_wall_thermal.h:88
void cs_1d_wall_thermal_create(void)
Initialize the cs_glob_1d_wall_thermal structure.
Definition: cs_1d_wall_thermal.c:310
cs_lnum_t nfpt1d
Definition: cs_1d_wall_thermal.h:104
void cs_1d_wall_thermal_mesh_create(void)
Create the 1D mesh for each face and initialize the temperature.
Definition: cs_1d_wall_thermal.c:372
1D wall thermal module descriptor.
Definition: cs_1d_wall_thermal.h:102
cs_real_t tept1d
Definition: cs_1d_wall_thermal.h:73
Definition: cs_defs.h:322
const cs_1d_wall_thermal_t * cs_glob_1d_wall_thermal
void cs_1d_wall_thermal_read(void)
Read the restart file of the 1D-wall thermal module.
Definition: cs_1d_wall_thermal.c:596
void cs_1d_wall_thermal_free(void)
Free the array of structures local_models.
Definition: cs_1d_wall_thermal.c:1194
cs_lnum_t * ifpt1d
Definition: cs_1d_wall_thermal.h:115
cs_gnum_t nfpt1t
Definition: cs_1d_wall_thermal.h:107
cs_1d_wall_thermal_t * cs_get_glob_1d_wall_thermal(void)
Provide access to cs_glob_1d_wall_thermal.
Definition: cs_1d_wall_thermal.c:1223
void cs_1d_wall_thermal_log(void)
Print information about the 1d wall thermal computation.
Definition: cs_1d_wall_thermal.c:1235
int nmxt1d
Definition: cs_1d_wall_thermal.h:111
int nppt1d
Definition: cs_1d_wall_thermal.h:58
void cs_1d_wall_thermal_write(void)
Write the restart file of the 1D-wall thermal module.
Definition: cs_1d_wall_thermal.c:984
void cs_1d_wall_thermal_solve(cs_lnum_t ii, cs_real_t tf, cs_real_t hf)
Solve the 1D equation for a given face.
Definition: cs_1d_wall_thermal.c:429
void cs_1d_wall_thermal_local_models_create(void)
Allocate the array of structures local_models.
Definition: cs_1d_wall_thermal.c:333
cs_real_t eppt1d
Definition: cs_1d_wall_thermal.h:67
Definition: cs_defs.h:316
cs_real_t hept1d
Definition: cs_1d_wall_thermal.h:76
Definition: cs_defs.h:513
cs_real_t fept1d
Definition: cs_1d_wall_thermal.h:79
cs_real_t * t
Definition: cs_1d_wall_thermal.h:94
cs_1d_wall_thermal_local_model_t * local_models
Definition: cs_1d_wall_thermal.h:124
int iclt1d
Definition: cs_1d_wall_thermal.h:62
cs_real_t * tppt1d
Definition: cs_1d_wall_thermal.h:119
void cs_1d_wall_thermal_finalize(void)
Destroy the global 1d wall thermal structure.
Definition: cs_1d_wall_thermal.c:1210
cs_real_t rgpt1d
Definition: cs_1d_wall_thermal.h:70
cs_real_t xlmbt1
Definition: cs_1d_wall_thermal.h:83
