7.3
bft_mem_usage.h
1 #ifndef __BFT_MEM_USAGE_H__
2 #define __BFT_MEM_USAGE_H__
5  * Base memory usage information (System and Library dependent)
30 #include "cs_defs.h"
36 /*============================================================================
37  * Public types
41  * Public function prototypes
44 /*
45  * Initialize memory usage count depending on system.
46  *
47  * This functions checks if it has already been called, so
48  * it is safe to call more than once (though it is not
49  * thread-safe). Only the first call is effective.
50  */
51
52 void
53 bft_mem_usage_init(void);
54
55 /*
56  * End memory usage count depending on system.
57  */
58
59 void
60 bft_mem_usage_end(void);
61
62 /*
63  * Indicates if bft_mem_usage_...() functions are initialized.
64  *
65  * returns:
66  * 1 if bft_mem_usage_init has been called, 0 otherwise.
67  */
68
69 int
71
72 /*
73  * Return current process memory use (in kB) depending on OS.
74  */
75
76 size_t
78
79 /*
80  * Return maximum process memory use (in kB) depending on OS.
81  *
82  * The returned value is the maximum memory used during the program's
83  * lifetime.
84  *
85  * returns:
86  * maximum measured program size, or 0 if not available
87  */
88
89 size_t
91
92 /*
93  * Return maximum process virtual memory use (in kB) depending on OS.
94  *
95  * returns:
96  * maximum measured virtual memory usage, or 0 if not available
97  */
98
99 size_t
101
102 /*
103  * Return shared library memory use (in kB) depending on OS.
104  *
105  * returns:
106  * maximum measured shared library memory usage, or 0 if not available
107  */
108
109 size_t
111
112 /*
113  * Return counter to number of calls to malloc, realloc, and free.
114  *
115  * This function returns zeroes when the appropriate instrumentation
116  * is not available.
117  */
118
119 void
120 bft_mem_usage_n_calls(size_t count[3]);
121
123
125
126 #endif /* __BFT_MEM_USAGE_H__ */
size_t bft_mem_usage_pr_size(void)
Return current process memory use (in kB) depending on system.
Definition: bft_mem_usage.c:599
void bft_mem_usage_init(void)
Definition: bft_mem_usage.c:419
size_t bft_mem_usage_shared_lib_size(void)
Definition: bft_mem_usage.c:645
Definition: cs_defs.h:512
size_t bft_mem_usage_max_pr_size(void)
Definition: bft_mem_usage.c:616
size_t bft_mem_usage_max_vm_size(void)
Definition: bft_mem_usage.c:630
int bft_mem_usage_initialized(void)
Definition: bft_mem_usage.c:464
Definition: cs_defs.h:513
void bft_mem_usage_n_calls(size_t count[3])
Definition: bft_mem_usage.c:660
void bft_mem_usage_end(void)
Definition: bft_mem_usage.c:450
