7.2
Iterative linear solvers.
For Krylov space solvers, default preconditioning is based on a Neumann polynomial of degree poly_degree, with a negative value meaning no preconditioning, and 0 diagonal preconditioning.
For positive values of poly_degree, the preconditioning is explained here: D being the diagonal part of matrix A and X its extra-diagonal part, it can be written $A=D(Id+D^{-1}X)$. Therefore $A^{-1}=(Id+D^{-1}X)^{-1}D^{-1}$. A series development of $Id+D^{-1}X$ can then be used which yields, symbolically,
\[ Id+\sum\limits_{I=1}^{poly\_degree}\left(-D^{-1}X\right)^{I} \]
The efficiency of the polynomial preconditioning will vary depending on the system type. In most cases, diagonal or degree 1 provide best results. Each polynomial preconditioning degree above 0 adds one matrix-vector product per inital matrix-vector product of the algorithm. Switching from diagonal to polynomial degree 1 often divides the number of required iterations by approximately 2, but each iteration then costs close to 2 times that of diagonal preconditioning (other vector operations and reductions are not doubled), so the net gain is often about 10%. Higher degree polynomials usually lead to diminishing returns.
