Introduction
This page provides examples of code blocks that may be used to define physical variable laws.
- Warning
It is forbidden to modify turbulent viscosity visct here (a specific subroutine is dedicated to that: usvist)
- icp = 1 must have been specified in usipsu if we wish to define a variable specific heat cpro_cp (otherwise: memory overwrite).
- the kivisl field integer key (diffusivity_id) must have been specified in usipsu if we wish to define a variable viscosity
viscls.
- Warning
- : if the scalar is the temperature, cpro_vscalt corresponds to its conductivity (Lambda) in W/(m K)
The types of boundary faces at the previous time step are available (except at the first time step, where arrays itypfb and itrifb have not been initialized yet)
It is recommended to keep only the minimum necessary in this file (i.e. remove all unused example code)
Molecular viscosity varying with temperature
The values of the molecular viscosity are provided as a function of the temperature. All variables are evaluated at the cell centers.
ivart = isca(itempk)
call field_get_val_s(ivarfl(ivart), cvar_scalt)
call field_get_val_s(iviscl, cpro_viscl)
varam = -3.4016d-9
varbm = 6.2332d-7
varcm = -4.5577d-5
vardm = 1.6935d-3
do iel = 1, ncel
xvart = cvar_scalt(iel)
cpro_viscl(iel) = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm
enddo
Molecular volumetric viscosity varying with temperature
The values of the molecular volumetric viscosity are provided as a function of the temperature. All variables are evaluated at the cell centers.
if (iviscv.ge.0) then
call field_get_val_s(iviscv, cpro_viscv)
else
cpro_viscv => null()
endif
if (iviscv.lt.0) then
write(nfecra,2000) iviscv
endif
varam = -3.4016d-9
varbm = 6.2332d-7
varcm = -4.5577d-5
vardm = 1.6935d-3
do iel = 1, ncel
cpro_viscv(iel) = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm
enddo
Isobaric specific heat varying with temperature
The values of the isobaric specific heat values are provided as a function of the temperature. All variables are evaluated at the cell centers.
if (icp.ge.0) call field_get_val_s(icp, cpro_cp)
if (icp.lt.0) then
write(nfecra,1000) icp
endif
if (icv.lt.0) then
write(nfecra,1001) icv
endif
varac = 0.00001d0
varbc = 1000.0d0
do iel = 1, ncel
cpro_cp(iel) = varac*xvart + varbc
enddo
call field_get_val_s(icv, cpro_cv)
call field_get_val_s(igmxml, mix_mol_mas)
Molecular thermal conductivity varying with temperature
The values of the molecular thermal conductivity are provided as a function of the temperature. All variables are evaluated at the cell centers.
call field_get_key_int(ivarfl(isca(itempk)), kivisl, ifcvsl)
if (ifcvsl.ge.0) then
call field_get_val_s(ifcvsl, cpro_vtmpk)
else
cpro_vtmpk => null()
endif
if (ifcvsl.lt.0) then
write(nfecra,1010) itempk
endif
varal = -3.3283d-7
varbl = 3.6021d-5
varcl = 1.2527d-4
vardl = 0.58923d0
do iel = 1, ncel
cpro_vtmpk(iel) = (xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl)
enddo
Molecular diffusivity of user-defined scalars varying with temperature
The molecular diffusivity can be set for all the user-defined scalars except:
- temperature and enthalpy (already dealt with above: for these variables, the 'diffusivity' is the thermal conductivity)
- variances of the fluctuations of another scalar variable (the diffusivity is assumed to be equal to that of the associated scalar) The values of the molecular diffusivity are provided as a function of the temperature. All variables are evaluated at the cell centers.
do iscal = 1, nscaus
ith = 0
if (iscal.eq.itempk) ith = 1
if (ith.eq.0.and.iscavr(iscal).le.0) then
call field_get_key_int(ivarfl(isca(iscal)), kivisl, ifcvsl)
call field_get_val_s(ifcvsl, cpro_vscal)
else
cpro_vscal => null()
endif
write(nfecra,1010) iscal
endif
varal = -3.3283d-7
varbl = 3.6021d-5
varcl = 1.2527d-4
vardl = 0.58923d0
do iel = 1, ncel
cpro_vscal(iel) = (xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl)
enddo
endif
enddo
