7.2
fvm_to_time_plot.h
1 #ifndef __FVM_TO_TIME_PLOT_H__
2 #define __FVM_TO_TIME_PLOT_H__
5  * Write a nodal representation associated with a mesh and associated
6  * variables to time plot (whitepace-separated or csv) files
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Local headers
35  *----------------------------------------------------------------------------*/
36
37 #include "fvm_defs.h"
38 #include "fvm_nodal.h"
39 #include "fvm_writer.h"
46  * Macro definitions
48
50  * Type definitions
52
53 /*=============================================================================
54  * Public function prototypes
56
58  * Initialize FVM to time plot file writer.
59  *
60  * Options are:
61  * csv output CSV (comma-separated-values) files
62  * dat output dat (space-separated) files
63  * use_iteration use time step id instead of time value for
64  * first column
65  * flush_wtime=<wt> flush output file every 'wt' seconds
66  * n_buf_steps=<n> write output to file every 'n' output steps
67  *
68  * parameters:
69  * name <-- base output case name.
70  * options <-- whitespace separated, lowercase options list
71  * time_dependecy <-- indicates if and how meshes will change with time
72  * comm <-- associated MPI communicator.
73  *
74  * returns:
75  * pointer to opaque time plot writer structure.
76  *----------------------------------------------------------------------------*/
77
78 #if defined(HAVE_MPI)
79
80 void *
81 fvm_to_time_plot_init_writer(const char *name,
82  const char *path,
83  const char *options,
84  fvm_writer_time_dep_t time_dependency,
85  MPI_Comm comm);
86
87 #else
88
89 void *
90 fvm_to_time_plot_init_writer(const char *name,
91  const char *path,
92  const char *options,
93  fvm_writer_time_dep_t time_dependency);
94
95 #endif
96
97 /*----------------------------------------------------------------------------
98  * Finalize FVM to time plot file writer.
99  *
100  * parameters:
101  * writer <-- pointer to opaque time plot writer structure.
102  *
103  * returns:
104  * NULL pointer.
105  *----------------------------------------------------------------------------*/
106
107 void *
109
110 /*----------------------------------------------------------------------------
111  * Associate new time step with a time plot geometry.
112  *
113  * parameters:
114  * writer <-- pointer to associated writer
115  * time_step <-- time step number
116  * time_value <-- time_value number
117  *----------------------------------------------------------------------------*/
118
119 void
120 fvm_to_time_plot_set_mesh_time(void *writer,
121  const int time_step,
122  const double time_value);
123
124 /*----------------------------------------------------------------------------
125  * Write nodal mesh to a time plot file
126  *
127  * parameters:
128  * writer <-- pointer to associated writer.
129  * mesh <-- pointer to nodal mesh structure that should be written.
130  *----------------------------------------------------------------------------*/
131
132 void
133 fvm_to_time_plot_export_nodal(void *writer,
134  const fvm_nodal_t *mesh);
135
136 /*----------------------------------------------------------------------------
137  * Write field associated with a nodal mesh to a time plot file.
138  *
139  * Assigning a negative value to the time step indicates a time-independent
140  * field (in which case the time_value argument is unused).
141  *
142  * parameters:
143  * writer <-- pointer to associated writer
144  * mesh <-- pointer to associated nodal mesh structure
145  * name <-- variable name
146  * location <-- variable definition location (nodes or elements)
147  * dimension <-- variable dimension (0: constant, 1: scalar,
148  * 3: vector, 6: sym. tensor, 9: asym. tensor)
149  * interlace <-- indicates if variable in memory is interlaced
150  * n_parent_lists <-- indicates if variable values are to be obtained
151  * directly through the local entity index (when 0) or
152  * through the parent entity numbers (when 1 or more)
153  * parent_num_shift <-- parent number to value array index shifts;
154  * size: n_parent_lists
155  * datatype <-- indicates the data type of (source) field values
156  * time_step <-- number of the current time step
157  * time_value <-- associated time value
158  * field_values <-- array of associated field value arrays
159  *----------------------------------------------------------------------------*/
160
161 void
162 fvm_to_time_plot_export_field(void *writer,
163  const fvm_nodal_t *mesh,
164  const char *name,
165  fvm_writer_var_loc_t location,
166  int dimension,
167  cs_interlace_t interlace,
168  int n_parent_lists,
169  const cs_lnum_t parent_num_shift[],
170  cs_datatype_t datatype,
171  int time_step,
172  double time_value,
173  const void *const field_values[]);
174
175 /*----------------------------------------------------------------------------*/
176
178
179 #endif /* __FVM_TO_TIME_PLOT_H__ */
cs_datatype_t
Definition: cs_defs.h:275
void * fvm_to_time_plot_init_writer(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
Definition: fvm_to_time_plot.c:427
Definition: fvm_writer.h:69
void fvm_to_time_plot_export_field(void *writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_to_time_plot.c:666
cs_interlace_t
Definition: cs_defs.h:482
Definition: fvm_writer.h:57
void fvm_to_time_plot_export_nodal(void *writer, const fvm_nodal_t *mesh)
Definition: fvm_to_time_plot.c:592
void * fvm_to_time_plot_finalize_writer(void *writer)
Definition: fvm_to_time_plot.c:544
Definition: cs_defs.h:316
void fvm_to_time_plot_set_mesh_time(void *writer, const int time_step, const double time_value)
Definition: fvm_to_time_plot.c:573
Definition: mesh.f90:26
