7.2
fvm_to_cgns.h
1 #ifndef __FVM_TO_CGNS_H__
2 #define __FVM_TO_CGNS_H__
4 #if defined(HAVE_CGNS)
5
6 /*============================================================================
7  * Write a nodal representation associated with a mesh and associated
8  * variables to CGNS files
9  *============================================================================*/
11 /*
12  This file is part of code_saturne, a general-purpose CFD tool.
13
14  Copyright (C) 1998-2022 EDF S.A.
15
16  This program is free software; you can redistribute it and/or modify it under
17  the terms of the GNU General Public License as published by the Free Software
18  Foundation; either version 2 of the License, or (at your option) any later
19  version.
20
21  This program is distributed in the hope that it will be useful, but WITHOUT
22  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
23  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
24  details.
25
26  You should have received a copy of the GNU General Public License along with
27  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
28  Street, Fifth Floor, Boston, MA 02110-1301, USA.
29 */
30
31 /*----------------------------------------------------------------------------*/
32
33 #include "cs_defs.h"
34
36  * Local headers
38
39 #include "fvm_defs.h"
40 #include "fvm_nodal.h"
41 #include "fvm_writer.h"
46
48  * Macro definitions
50
52  * Type definitions
54
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------
60  * Returns number of library version strings associated with the CGNS format.
61  *
62  * returns:
63  * number of library version strings associated with the CGNS format.
64  *----------------------------------------------------------------------------*/
65
66 int
67 fvm_to_cgns_n_version_strings(void);
68
69 /*----------------------------------------------------------------------------
70  * Returns a library version string associated with the CGNS format.
71  *
72  * In certain cases, when using dynamic libraries, fvm may be compiled
73  * with one library version, and linked with another. If both run-time
74  * and compile-time version information is available, this function
75  * will return the run-time version string by default.
76  *
77  * Setting the compile_time flag to 1, the compile-time version string
78  * will be returned if this is different from the run-time version.
79  * If the version is the same, or only one of the 2 version strings are
80  * available, a NULL character string will be returned with this flag set.
81  *
82  * parameters:
83  * string_index <-- index in format's version string list (0 to n-1)
84  * compile_time <-- 0 by default, 1 if we want the compile-time version
85  * string, if different from the run-time version.
86  *
87  * returns:
88  * pointer to constant string containing the library's version.
89  *----------------------------------------------------------------------------*/
90
91 const char *
92 fvm_to_cgns_version_string(int string_index,
93  int compile_time_version);
94
95 /*----------------------------------------------------------------------------
96  * Initialize FVM to CGNS file writer.
97  *
98  * Options are:
99  * discard_bcs do not output boundary conditions
100  * discard_steady discard steady solution data
101  * (to avoid issues with some tools when both steady
102  * and unsteady data is present)
103  * discard_polygons do not output polygons or related values
104  * discard_polyhedra do not output polyhedra or related values
105  * divide_polygons tesselate polygons with triangles
106  * preserve_precision do not convert double precision to single
107  * precision types (leads to larger files)
108  * adf use ADF file type
109  * hdf5 use HDF5 file type (default if available)
110  * links split output to separate files using links
111  *
112  * As CGNS does not handle polyhedral elements in a simple manner,
113  * polyhedra are automatically tesselated with tetrahedra and pyramids
114  * (adding a vertex near each polyhedron's center) unless discarded.
115  *
116  * parameters:
117  * name <-- base output case name.
118  * options <-- whitespace separated, lowercase options list
119  * time_dependecy <-- indicates if and how meshes will change with time
120  * comm <-- associated MPI communicator.
121  *
122  * returns:
123  * pointer to opaque CGNS writer structure.
124  *----------------------------------------------------------------------------*/
125
126 #if defined(HAVE_MPI)
127
128 void *
129 fvm_to_cgns_init_writer(const char *name,
130  const char *path,
131  const char *options,
132  fvm_writer_time_dep_t time_dependency,
133  MPI_Comm comm);
134
135 #else
136
137 void *
138 fvm_to_cgns_init_writer(const char *name,
139  const char *path,
140  const char *options,
141  fvm_writer_time_dep_t time_dependency);
142
143 #endif
144
145 /*----------------------------------------------------------------------------
146  * Finalize FVM to CGNS file writer.
147  *
148  * parameters:
149  * this_writer_p <-- pointer to opaque CGNS writer structure.
150  *
151  * returns:
152  * NULL pointer.
153  *----------------------------------------------------------------------------*/
154
155 void *
156 fvm_to_cgns_finalize_writer(void *this_writer_p);
157
158 /*----------------------------------------------------------------------------
159  * Associate new time step with a CGNS geometry.
160  *
161  * parameters:
162  * this_writer_p <-- pointer to associated writer
163  * time_step <-- time step number
164  * time_value <-- time_value number
165  *----------------------------------------------------------------------------*/
166
167 void
168 fvm_to_cgns_set_mesh_time(void *this_writer_p,
169  int time_step,
170  double time_value);
171
172 /*----------------------------------------------------------------------------
173  * Indicate if elements of a given type in a mesh associated with a given
174  * CGNS file writer need to be tesselated.
175  *
176  * parameters:
177  * this_writer_p <-- pointer to associated writer
178  * mesh <-- pointer to nodal mesh structure that should be written
179  * element_type <-- element type we are interested in
180  *
181  * returns:
182  * 1 if tesselation of the given element type is needed, 0 otherwise
183  *----------------------------------------------------------------------------*/
184
185 int
186 fvm_to_cgns_needs_tesselation(void *this_writer_p,
187  const fvm_nodal_t *mesh,
188  fvm_element_t element_type);
189
190 /*----------------------------------------------------------------------------
191  * Write nodal mesh to a CGNS file
192  *
193  * parameters:
194  * this_writer_p <-- pointer to associated writer.
195  * mesh <-- pointer to nodal mesh structure that should be written.
196  *----------------------------------------------------------------------------*/
197
198 void
199 fvm_to_cgns_export_nodal(void *this_writer_p,
200  const fvm_nodal_t *mesh);
201
202 /*----------------------------------------------------------------------------
203  * Write field associated with a nodal mesh to a CGNS file.
204  *
205  * Assigning a negative value to the time step indicates a time-independent
206  * field (in which case the time_value argument is unused).
207  *
208  * parameters:
209  * this_writer_p <-- pointer to associated writer
210  * mesh <-- pointer to associated nodal mesh structure
211  * name <-- variable name
212  * location <-- variable definition location (nodes or elements)
213  * dimension <-- variable dimension (0: constant, 1: scalar,
214  * 3: vector, 6: sym. tensor, 9: asym. tensor)
215  * interlace <-- indicates if variable in memory is interlaced
216  * n_parent_lists <-- indicates if variable values are to be obtained
217  * directly through the local entity index (when 0) or
218  * through the parent entity numbers (when 1 or more)
219  * parent_num_shift <-- parent number to value array index shifts;
220  * size: n_parent_lists
221  * datatype <-- indicates the data type of (source) field values
222  * time_step <-- number of the current time step
223  * time_value <-- associated time value
224  * field_values <-- array of associated field value arrays
225  *----------------------------------------------------------------------------*/
226
227 void
228 fvm_to_cgns_export_field(void *this_writer_p,
229  const fvm_nodal_t *mesh,
230  const char *name,
231  fvm_writer_var_loc_t location,
232  int dimension,
233  cs_interlace_t interlace,
234  int n_parent_lists,
235  const cs_lnum_t parent_num_shift[],
236  cs_datatype_t datatype,
237  int time_step,
238  double time_value,
239  const void *const field_values[]);
240
241 /*----------------------------------------------------------------------------
242  * Flush files associated with a given writer.
243  *
244  * parameters:
245  * this_writer_p <-- pointer to associated writer
246  *----------------------------------------------------------------------------*/
247
248 void
249 fvm_to_cgns_flush(void *this_writer_p);
250
251 /*----------------------------------------------------------------------------*/
252
254
255 #endif /* HAVE_CGNS */
256
257 #endif /* __FVM_TO_CGNS_H__ */
cs_datatype_t
Definition: cs_defs.h:275
Definition: fvm_writer.h:69
cs_interlace_t
Definition: cs_defs.h:482
Definition: fvm_writer.h:57
fvm_element_t
Definition: fvm_defs.h:48
Definition: cs_defs.h:316
Definition: mesh.f90:26
