7.2
fvm_nodal_append.h
1 #ifndef __FVM_NODAL_APPEND_H__
2 #define __FVM_NODAL_APPEND_H__
5  * Append sections to a nodal representation associated with a mesh
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
37 #include "fvm_nodal.h"
38
44  * Macro definitions
46
48  * Type definitions
50
51 /*=============================================================================
52  * Static global variables
54
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------
60  * Append a new section to an existing fvm_nodal mesh, and transfer
61  * ownership of the given connectivity and optional parent number arrays to
62  * that section.
63  *
64  * parameters:
65  * this_nodal <-> nodal mesh structure
66  * n_elements <-- number of elements to add
67  * type <-- type of elements to add
68  * face_index <-- polyhedron -> faces index (O to n-1)
69  * size: n_elements + 1
70  * face_num <-- polyhedron -> face numbers (1 to n, signed,
71  * > 0 for outwards pointing face normal
72  * < 0 for inwards pointing face normal);
73  * size: face_index[n_elements]
74  * vertex_index <-- polygon face -> vertices index (O to n-1)
75  * size: face_index[n_elements]
76  * vertex_num <-- element -> vertex connectivity
77  * parent_element_num <-- element -> parent element number (1 to n) if non
78  * trivial (i.e. if element definitions correspond
79  * to a subset of the parent mesh), NULL otherwise
80  *----------------------------------------------------------------------------*/
81
82 void
83 fvm_nodal_append_by_transfer(fvm_nodal_t *this_nodal,
84  cs_lnum_t n_elements,
85  fvm_element_t type,
86  cs_lnum_t face_index[],
87  cs_lnum_t face_num[],
88  cs_lnum_t vertex_index[],
89  cs_lnum_t vertex_num[],
90  cs_lnum_t parent_element_num[]);
91
92 /*----------------------------------------------------------------------------
93  * Append a new section to an existing fvm_nodal mesh, sharing the given
94  * given connectivity and optional parent number arrays with the caller.
95  *
96  * The caller should not destroy or modify the arrays passed to this
97  * function until the nodal mesh is destroyed.
98  *
99  * parameters:
100  * this_nodal <-> nodal mesh structure
101  * n_elements <-- number of elements to add
102  * type <-- type of elements to add
103  * face_index <-- polyhedron -> faces index (O to n-1)
104  * size: n_elements + 1
105  * face_num <-- polyhedron -> face numbers (1 to n, signed,
106  * > 0 for outwards pointing face normal
107  * < 0 for inwards pointing face normal);
108  * size: face_index[n_elements]
109  * vertex_index <-- polygon face -> vertices index (O to n-1)
110  * size: face_index[n_elements]
111  * vertex_num <-- element -> vertex connectivity
112  * parent_element_num <-- element -> parent element number (1 to n) if non
113  * trivial (i.e. if element definitions correspond
114  * to a subset of the parent mesh), NULL otherwise
115  *----------------------------------------------------------------------------*/
116
117 void
118 fvm_nodal_append_shared(fvm_nodal_t *this_nodal,
119  cs_lnum_t n_elements,
120  fvm_element_t type,
121  cs_lnum_t face_index[],
122  cs_lnum_t face_num[],
123  cs_lnum_t vertex_index[],
124  cs_lnum_t vertex_num[],
125  cs_lnum_t parent_element_num[]);
126
128
130
131 #endif /* __FVM_NODAL_APPEND_H__ */
void fvm_nodal_append_by_transfer(fvm_nodal_t *this_nodal, cs_lnum_t n_elements, fvm_element_t type, cs_lnum_t face_index[], cs_lnum_t face_num[], cs_lnum_t vertex_index[], cs_lnum_t vertex_num[], cs_lnum_t parent_element_num[])
Definition: fvm_nodal_append.c:260
fvm_element_t
Definition: fvm_defs.h:48
Definition: cs_defs.h:316
void fvm_nodal_append_shared(fvm_nodal_t *this_nodal, cs_lnum_t n_elements, fvm_element_t type, cs_lnum_t face_index[], cs_lnum_t face_num[], cs_lnum_t vertex_index[], cs_lnum_t vertex_num[], cs_lnum_t parent_element_num[])
Definition: fvm_nodal_append.c:335
