7.2
fvm_box_priv.h
1 #ifndef __FVM_BOX_PRIV_H__
2 #define __FVM_BOX_PRIV_H__
5  * Handle bounding boxes.
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
37 #include "fvm_morton.h"
38
39 #include "fvm_box.h"
46  * Macro and type definitions
48
49 /* Structure use to manage box distribution on a tree structure */
50
51 #if defined(HAVE_MPI)
52
53 struct _fvm_box_distrib_t {
54
55  int n_ranks; /* Number of associated ranks */
56
57  cs_lnum_t n_boxes; /* Number of bounding boxes */
58
59  int max_level; /* Global max level used to compute the
60  distribution */
61  double fit; /* Evaluation of the distribution
62  (lower is better) */
63
64  /* Morton code array defining an index on ranks = resulting distribution */
65
66  fvm_morton_code_t *morton_index; /* size = n_ranks + 1 */
67
68  /* Indexed list on ranks to list related bounding boxes */
69
70  cs_lnum_t *index; /* Index on ranks (size = n_ranks + 1) */
71  cs_lnum_t *list; /* List of bounding boxes associated to each rank */
72 };
73
74 #endif /* defined(HAVE_MPI) */
75
76 /* Set of bounding boxes */
77
79
80  int dim; /* Spatial dimension (1, 2 or 3) */
81  int dimensions[3]; /* Only used in 1 or 2D: X = 0, Y = 1, Z = 2 */
82
83  cs_lnum_t n_boxes; /* Number of bounding boxes */
84  cs_gnum_t n_g_boxes; /* Global number of bounding boxes */
85
86  cs_gnum_t *g_num; /* Array of associated global numbers */
87  cs_coord_t *extents; /* Extents associated with each box:
88  * x_min_0, y_min_0, ..., x_max_0, y_max_0, ...
89  * x_min_n, y_min_n, ..., x_max_n, y_max_n,
90  * (size: n_boxes * dim * 2) */
91
92  cs_coord_t gmin[3]; /* Global minima of the coordinates */
93  cs_coord_t gmax[3]; /* Global maxima of the coordinates */
94
95 #if defined(HAVE_MPI)
96  MPI_Comm comm; /* Associated MPI communicator */
97 #endif
98
99 };
100
101 /*----------------------------------------------------------------------------*/
102
104
105 #endif /* __FVM_BOX_PRIV_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
int dim
Definition: fvm_box_priv.h:80
double cs_coord_t
Definition: cs_defs.h:320
cs_coord_t * extents
Definition: fvm_box_priv.h:87
Definition: fvm_morton.h:62
cs_gnum_t n_g_boxes
Definition: fvm_box_priv.h:84
Definition: fvm_box_priv.h:78
Definition: cs_defs.h:316
cs_gnum_t * g_num
Definition: fvm_box_priv.h:86
cs_lnum_t n_boxes
Definition: fvm_box_priv.h:83
