7.2
cs_part_to_block.h
1 #ifndef __CS_PART_TO_BLOCK_H__
2 #define __CS_PART_TO_BLOCK_H__
5  * Convert between general domain partition and block distribution.
30 #if defined(HAVE_MPI)
31 #include <mpi.h>
32 #endif
35  * Local headers
38 #include "cs_defs.h"
39 #include "cs_block_dist.h"
46  * Macro definitions
48
50  * Type definitions
52
53 /* Opaque general domain partitioning to block distribution structure */
54
55 #if defined(HAVE_MPI)
56
57 typedef struct _cs_part_to_block_t cs_part_to_block_t;
58
59 #endif
60
61 /*=============================================================================
62  * Public function prototypes
63  *============================================================================*/
64
65 #if defined(HAVE_MPI)
66
67 /*----------------------------------------------------------------------------
68  * Initialize partition to block distributor based on global entity numbers.
69  *
70  * arguments:
71  * comm <-- communicator
72  * bi <-- block size and range info
73  * n_ents <-- number of elements in partition
74  * global_ent_num <-- global entity numbers
75  *
76  * returns:
77  * initialized partition to block distributor
78  *----------------------------------------------------------------------------*/
79
83  cs_lnum_t n_ents,
84  const cs_gnum_t global_ent_num[]);
85
87  * Destroy a partition to block distributor structure.
88  *
89  * arguments:
90  * d <-> pointer to partition to block distributor structure pointer
91  *----------------------------------------------------------------------------*/
92
93 void
95
96 /*----------------------------------------------------------------------------
97  * Transfer ownership of global entity numbers to a block distributor.
98  *
99  * The global_ent_num[] array should be the same as the one used
100  * for the creation of the block distributor.
101  *
102  * arguments:
103  * d <-- distributor helper
104  * global_ent_num <-> global entity numbers
105  *----------------------------------------------------------------------------*/
106
107 void
109  cs_gnum_t global_ent_num[]);
110
111 /*----------------------------------------------------------------------------
112  * Return number of entities associated with local partition
113  *
114  * arguments:
115  * d <-- distribtor helper
116  *
117  * returns:
118  * number of entities associated with distribution receive
119  *----------------------------------------------------------------------------*/
120
121 cs_lnum_t
123
124 /*----------------------------------------------------------------------------
125  * Copy array data from general domain partition to block distribution.
126  *
127  * arguments:
128  * d <-- partition to block distributor
129  * datatype <-- type of data considered
130  * stride <-- number of values per entity (interlaced)
131  * part_values <-- values in general domain partition
132  * block_values --> values in block distribution
133  *----------------------------------------------------------------------------*/
134
135 void
137  cs_datatype_t datatype,
138  int stride,
139  const void *part_values,
140  void *block_values);
141
142 /*----------------------------------------------------------------------------
143  * Copy local index from general domain partition to block distribution.
144  *
145  * This is useful for distribution of entity connectivity information.
146  *
147  * arguments:
148  * d <-- partition to block distributor
149  * part_index <-- local index in general partition distribution
150  * (size: n_part_entities + 1)
151  * block_index --> local index in block distribution
152  * (size: n_block_entities + 1)
153  *----------------------------------------------------------------------------*/
154
155 void
157  const cs_lnum_t *part_index,
158  cs_lnum_t *block_index);
159
160 /*----------------------------------------------------------------------------
161  * Copy indexed data from general domain partition to block distribution.
162  *
163  * This is useful for distribution of entity connectivity information.
164  *
165  * arguments:
166  * d <-- partition to block distributor
167  * datatype <-- type of data considered
168  * part_index <-- local index in general distribution
169  * part_val <-- numbers in general distribution
170  * (size: part_index[n_part_ents])
171  * block_index --> local index in block distribution
172  * block_val --> values in block distribution
173  * (size: block_index[n_block_ents])
174  *----------------------------------------------------------------------------*/
175
176 void
178  cs_datatype_t datatype,
179  const cs_lnum_t *part_index,
180  const void *part_val,
181  const cs_lnum_t *block_index,
182  void *block_val);
183
184 #endif /* defined(HAVE_MPI) */
185
186 /*----------------------------------------------------------------------------*/
187
189
190 #endif /* __CS_PART_TO_BLOCK_H__ */
cs_datatype_t
Definition: cs_defs.h:275
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
void cs_part_to_block_transfer_gnum(cs_part_to_block_t *d, cs_gnum_t global_ent_num[])
Definition: cs_part_to_block.c:621
Definition: cs_part_to_block.h:57
cs_part_to_block_t * cs_part_to_block_create_by_gnum(MPI_Comm comm, cs_block_dist_info_t bi, cs_lnum_t n_ents, const cs_gnum_t global_ent_num[])
Definition: cs_part_to_block.c:551
void cs_part_to_block_copy_indexed(cs_part_to_block_t *d, cs_datatype_t datatype, const cs_lnum_t *part_index, const void *part_val, const cs_lnum_t *block_index, void *block_val)
Definition: cs_part_to_block.c:727
void cs_part_to_block_copy_index(cs_part_to_block_t *d, const cs_lnum_t *part_index, cs_lnum_t *block_index)
Definition: cs_part_to_block.c:696
void cs_part_to_block_copy_array(cs_part_to_block_t *d, cs_datatype_t datatype, int stride, const void *part_values, void *block_values)
Definition: cs_part_to_block.c:662
Definition: cs_defs.h:316
cs_lnum_t cs_part_to_block_get_n_part_ents(cs_part_to_block_t *d)
Definition: cs_part_to_block.c:640
void cs_part_to_block_destroy(cs_part_to_block_t **d)
Definition: cs_part_to_block.c:589
