7.2
cs_mesh_extrude.h
1 #ifndef __CS_MESH_EXTRUDE_H__
2 #define __CS_MESH_EXTRUDE_H__
5  * Mesh extrusion.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_mesh.h"
36
38
42  * Macro definitions
46  * Type definitions
48
54 typedef struct {
55
71
78 typedef struct {
79
87  float *distribution;
93
94 /*=============================================================================
95  * Public function prototypes
96  *============================================================================*/
97
98 /*----------------------------------------------------------------------------*/
113
114 void
116  const cs_mesh_extrude_vectors_t *e,
117  bool interior_gc);
118
119 /*----------------------------------------------------------------------------*/
135 /*----------------------------------------------------------------------------*/
136
137 void
139  bool interior_gc,
140  cs_lnum_t n_layers,
141  double thickness,
142  double expansion_factor,
143  cs_lnum_t n_faces,
144  const cs_lnum_t faces[]);
145
154 /*----------------------------------------------------------------------------*/
155
158
159 /*----------------------------------------------------------------------------*/
166
167 void
169
170 /*----------------------------------------------------------------------------*/
183 /*----------------------------------------------------------------------------*/
184
185 void
187  int n_layers,
188  double distance,
189  float expansion_factor,
190  const cs_lnum_t n_faces,
191  const cs_lnum_t face_ids[]);
192
193 /*----------------------------------------------------------------------------*/
205 /*----------------------------------------------------------------------------*/
206
209
210 /*----------------------------------------------------------------------------*/
217 /*----------------------------------------------------------------------------*/
218
219 void
221
222 /*----------------------------------------------------------------------------*/
223
225
226 #endif /* __CS_MESH_EXTRUDE_H__ */
cs_real_t * thickness_e
Definition: cs_mesh_extrude.h:67
cs_lnum_t * n_layers
Definition: cs_mesh_extrude.h:56
void cs_mesh_extrude_constant(cs_mesh_t *m, bool interior_gc, cs_lnum_t n_layers, double thickness, double expansion_factor, cs_lnum_t n_faces, const cs_lnum_t faces[])
Extrude mesh boundary faces in the normal direction by a constant thickness.
Definition: cs_mesh_extrude.c:2206
cs_real_t * distance
Definition: cs_mesh_extrude.h:59
cs_coord_t cs_coord_3_t[3]
Definition: cs_defs.h:331
void cs_mesh_extrude(cs_mesh_t *m, const cs_mesh_extrude_vectors_t *e, bool interior_gc)
Extrude mesh boundary faces in the normal direction.
Definition: cs_mesh_extrude.c:1975
void cs_mesh_extrude_vectors_destroy(cs_mesh_extrude_vectors_t **e)
Destroy a mesh extrusion vectors definition.
Definition: cs_mesh_extrude.c:2392
cs_lnum_t * face_ids
Definition: cs_mesh_extrude.h:82
Definition: cs_defs.h:322
cs_lnum_t * distribution_idx
Definition: cs_mesh_extrude.h:86
Definition: cs_mesh.h:84
cs_real_t * thickness_s
Definition: cs_mesh_extrude.h:65
cs_lnum_t * vertex_ids
Definition: cs_mesh_extrude.h:83
cs_mesh_extrude_face_info_t * cs_mesh_extrude_face_info_create(const cs_mesh_t *m)
Create a mesh extrusion face information structure.
Definition: cs_mesh_extrude.c:2249
cs_lnum_t n_faces
Definition: cs_mesh_extrude.h:80
cs_lnum_t n_vertices
Definition: cs_mesh_extrude.h:81
cs_coord_3_t * coord_shift
Definition: cs_mesh_extrude.h:85
float * expansion_factor
Definition: cs_mesh_extrude.h:63
float * distribution
Definition: cs_mesh_extrude.h:87
Definition: cs_defs.h:316
cs_mesh_extrude_vectors_t * cs_mesh_extrude_vectors_create(const cs_mesh_extrude_face_info_t *efi)
Create and build a mesh extrusion vectors definition.
Definition: cs_mesh_extrude.c:2361
Definition: cs_mesh_extrude.h:84
Definition: cs_mesh_extrude.h:54
void cs_mesh_extrude_set_info_by_zone(cs_mesh_extrude_face_info_t *efi, int n_layers, double distance, float expansion_factor, const cs_lnum_t n_faces, const cs_lnum_t face_ids[])
Set face extrusion information by zone.
Definition: cs_mesh_extrude.c:2314
Definition: cs_mesh_extrude.h:78
void cs_mesh_extrude_face_info_destroy(cs_mesh_extrude_face_info_t **efi)
Destroy a mesh extrusion face information structure.
Definition: cs_mesh_extrude.c:2283
