7.2
cs_mesh_cartesian.h
1 #ifndef __CS_MESH_CARTESIAN_H__
2 #define __CS_MESH_CARTESIAN_H__
5  * Cartesian mesh generation
29  * Local headers
32 #include "cs_defs.h"
34 /*============================================================================
35  * Type definitions
36  *============================================================================*/
38 typedef enum {
45
48 typedef struct _cs_mesh_cartesian_params_t cs_mesh_cartesian_params_t;
49
51  * Public C function prototypes
53
54 /*----------------------------------------------------------------------------*/
60 /*----------------------------------------------------------------------------*/
61
62 cs_mesh_cartesian_params_t *
64
65 /*----------------------------------------------------------------------------*/
68 /*----------------------------------------------------------------------------*/
69
70 void
72
73 /*----------------------------------------------------------------------------*/
82 /*----------------------------------------------------------------------------*/
83
84 void
86  cs_real_t xyz[6]);
87
88 /*----------------------------------------------------------------------------*/
96 /*----------------------------------------------------------------------------*/
97
98 void
100  int ncells,
101  cs_real_t vtx_coord[]);
102
103 /*----------------------------------------------------------------------------*/
123
124 void
126  int n_parts,
127  const cs_real_t part_coords[],
128  const cs_lnum_t n_part_cells[],
129  const cs_real_t amp_factors[]);
130
131 /*----------------------------------------------------------------------------*/
147 /*----------------------------------------------------------------------------*/
148
149 void
150 cs_mesh_cartesian_define_from_csv(const char *csv_file_name);
151
152 /*----------------------------------------------------------------------------*/
164 /*----------------------------------------------------------------------------*/
165
166 void
169  int ncells,
170  cs_real_t smin,
171  cs_real_t smax,
172  cs_real_t progression);
173
174 /*----------------------------------------------------------------------------*/
179 /*----------------------------------------------------------------------------*/
180
181 int
183
184 /*----------------------------------------------------------------------------*/
191 /*----------------------------------------------------------------------------*/
192
193 int
195
196 /*----------------------------------------------------------------------------*/
203 /*----------------------------------------------------------------------------*/
204
205 void
207  cs_mesh_builder_t *mb,
208  long echo);
209
210 /*----------------------------------------------------------------------------*/
213 /*----------------------------------------------------------------------------*/
214
215 void
217
218 /*----------------------------------------------------------------------------*/
219
220 #endif /* __CS_MESH_CARTESIAN_H__ */
void cs_mesh_cartesian_define_dir_params(int idim, cs_mesh_cartesian_law_t law, int ncells, cs_real_t smin, cs_real_t smax, cs_real_t progression)
Define parameters for a given direction.
Definition: cs_mesh_cartesian.c:769
Definition: cs_mesh_builder.h:57
void cs_mesh_cartesian_define_simple(int ncells[3], cs_real_t xyz[6])
Define a simple cartesian mesh with a constant step in all directions.
Definition: cs_mesh_cartesian.c:494
Definition: cs_mesh_cartesian.h:41
int cs_mesh_cartesian_get_ncells(int idim)
Get number of cells in a given direction.
Definition: cs_mesh_cartesian.c:847
Definition: cs_defs.h:322
Definition: cs_mesh.h:84
void cs_mesh_cartesian_define_dir_geom_by_part(int idir, int n_parts, const cs_real_t part_coords[], const cs_lnum_t n_part_cells[], const cs_real_t amp_factors[])
Define direction parameters based on a piecewise definition. Each part follows a geometric (or unifor...
Definition: cs_mesh_cartesian.c:576
Definition: cs_mesh_cartesian.h:42
void cs_mesh_cartesian_params_destroy(void)
Destroy cartesian mesh parameters.
Definition: cs_mesh_cartesian.c:1028
void cs_mesh_cartesian_define_dir_user(int idir, int ncells, cs_real_t vtx_coord[])
Define directions parameters based on a user input.
Definition: cs_mesh_cartesian.c:524
int cs_mesh_cartesian_need_build(void)
Indicate if a cartesian mesh is to be built.
Definition: cs_mesh_cartesian.c:830
Definition: cs_defs.h:316
void cs_mesh_cartesian_create(void)
Create cartesian mesh structure.
Definition: cs_mesh_cartesian.c:475
integer(c_int), pointer, save smin
starting min
Definition: atincl.f90:196
Definition: cs_mesh_cartesian.h:43
cs_mesh_cartesian_params_t * cs_mesh_cartesian_get_params(void)
Return pointer to cartesian mesh parameters structure.
Definition: cs_mesh_cartesian.c:464
void cs_mesh_cartesian_connectivity(cs_mesh_t *m, cs_mesh_builder_t *mb, long echo)
Build unstructured connectivity needed for partitionning.
Definition: cs_mesh_cartesian.c:862
void cs_mesh_cartesian_define_from_csv(const char *csv_file_name)
Define a simple cartesian mesh based on a CSV file. CSV file needs to contain : (1) First line which ...
Definition: cs_mesh_cartesian.c:669
Definition: cs_mesh_cartesian.h:44
Definition: cs_mesh_cartesian.h:38
Definition: cs_mesh_cartesian.h:40
