1 #ifndef __CS_LES_BALANCE_H__ 2 #define __CS_LES_BALANCE_H__ 48 #define CS_LES_BALANCE_RIJ (1 << 0) 51 #define CS_LES_BALANCE_RIJ_BASE (1 << 1) 54 #define CS_LES_BALANCE_RIJ_FULL (1 << 2) 57 #define CS_LES_BALANCE_TUI (1 << 3) 60 #define CS_LES_BALANCE_TUI_BASE (1 << 4) 63 #define CS_LES_BALANCE_TUI_FULL (1 << 5) cs_real_3_t * tpuip
Definition: cs_les_balance.h:107
cs_real_t * smagp2
Definition: cs_les_balance.h:76
Turbulent thermal flux vector (Tui) LES balance descriptor.
Definition: cs_les_balance.h:93
void cs_les_balance_create(void)
Create a LES balance descriptor.
Definition: cs_les_balance.c:2754
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
void cs_les_balance_compute_tui(void)
Compute Tui LES balance.
Definition: cs_les_balance.c:3282
cs_real_3_t * unstti
Definition: cs_les_balance.h:108
Reynolds tensor (Rij) LES balance descriptor.
Definition: cs_les_balance.h:72
cs_real_t * convvar
Definition: cs_les_balance.h:104
cs_real_3_t * phiti
Definition: cs_les_balance.h:111
cs_real_69_t * budsgsfullij
Definition: cs_les_balance.h:86
cs_real_t * difftvar
Definition: cs_les_balance.h:103
cs_real_t * tptp
Definition: cs_les_balance.h:100
cs_real_6_t * epsij
Definition: cs_les_balance.h:79
cs_real_3_t * prodtUi
Definition: cs_les_balance.h:109
void cs_les_balance_compute(void)
Compute the LES balance for Tui or Rij.
Definition: cs_les_balance.c:3874
cs_real_3_t * convti
Definition: cs_les_balance.h:115
cs_real_3_t * prodtTi
Definition: cs_les_balance.h:110
Definition: cs_defs.h:322
cs_real_t * difflamvar
Definition: cs_les_balance.h:105
void cs_les_balance_finalize(void)
Destroy the LES balance structure.
Definition: cs_les_balance.c:3837
cs_real_t * epsvar
Definition: cs_les_balance.h:102
cs_real_3_t * difftti
Definition: cs_les_balance.h:113
int i_les_balance
Definition: cs_les_balance.h:132
cs_real_t * unstvar
Definition: cs_les_balance.h:99
cs_les_balance_rij_t * brij
Definition: cs_les_balance.h:128
cs_real_6_t * budsgsvarfull
Definition: cs_les_balance.h:118
cs_real_3_t * budsgstui
Definition: cs_les_balance.h:117
cs_real_6_t * convij
Definition: cs_les_balance.h:83
cs_real_6_t * unstij
Definition: cs_les_balance.h:82
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
cs_les_balance_t * cs_get_glob_les_balance(void)
Provide access to cs_glob_les_balance.
Definition: cs_les_balance.c:2742
cs_real_6_t * budsgsij
Definition: cs_les_balance.h:85
cs_real_t * pp2
Definition: cs_les_balance.h:75
cs_real_t cs_real_69_t[6][9]
Definition: cs_defs.h:352
cs_real_6_t * difflamij
Definition: cs_les_balance.h:84
int type
Definition: cs_les_balance.h:134
int frequency_n
Definition: cs_les_balance.h:136
cs_real_t * budsgsvar
Definition: cs_les_balance.h:106
void cs_les_balance_write_restart(void)
Write the LES balance structure in the LES balance restart file.
Definition: cs_les_balance.c:3805
LES balance general options descriptor.
Definition: cs_les_balance.h:126
int f_id
Definition: cs_les_balance.h:96
void cs_les_balance_activate(int type_flag, int frequency_n)
Active the LES balance module.
Definition: cs_les_balance.c:3857
cs_les_balance_t * cs_glob_les_balance
Definition: cs_les_balance.c:229
cs_real_3_t ** budsgstuifull
Definition: cs_les_balance.h:119
cs_real_6_t * phiij
Definition: cs_les_balance.h:78
void cs_les_balance_update_gradients(void)
Update gradients needed in LES balance.
Definition: cs_les_balance.c:2838
cs_real_3_t * epsti
Definition: cs_les_balance.h:112
void cs_les_balance_compute_rij(void)
Compute Rij LES balance.
Definition: cs_les_balance.c:2850
cs_real_t * prodvar
Definition: cs_les_balance.h:101
cs_real_6_t * difftij
Definition: cs_les_balance.h:80
void cs_les_balance_create_fields(void)
Definition: cs_les_balance.c:2672
cs_les_balance_tui_t ** btui
Definition: cs_les_balance.h:130
cs_real_6_t * difftpij
Definition: cs_les_balance.h:81
cs_real_3_t * difflamti
Definition: cs_les_balance.h:116
cs_real_3_t * diffttpi
Definition: cs_les_balance.h:114
cs_real_6_t * prodij
Definition: cs_les_balance.h:77
