7.2
cs_join_post.h
1 #ifndef __CS_JOIN_POST_H__
2 #define __CS_JOIN_POST_H__
5  * Subroutines to manage post-treatment for joining operation
35  * Local headers
38 #include "fvm_nodal.h"
39 #include "fvm_writer.h"
41 #include "cs_join_mesh.h"
42 #include "cs_join_util.h"
43 #include "cs_mesh.h"
45 /*----------------------------------------------------------------------------*/
46
48
50  * Macro and type definitions
52
54  * Public function prototypes
56
58  * Create and define a writer to make post-treatment for the joining operation
59  *---------------------------------------------------------------------------*/
60
61 void
62 cs_join_post_init(void);
63
64 /*----------------------------------------------------------------------------
65  * Post-treatment of a cs_join_mesh_t structure.
66  *
67  * parameters:
68  * mesh_name <-- name of the mesh for the post-processing
69  * mesh <-- pointer to a cs_join_mesh_t structure to post
70  *---------------------------------------------------------------------------*/
71
72 void
73 cs_join_post_mesh(const char *mesh_name,
74  const cs_join_mesh_t *join_mesh);
75
76 /*----------------------------------------------------------------------------
77  * Post-process a subset of faces of a cs_join_mesh_t structure.
78  *
79  * parameters:
80  * mesh_name <-- name of the sub-set mesh
81  * mesh <-- pointer to the parent cs_join_mesh_t structure
82  * n_selected_faces <-- number of selected faces (size of the sub-set)
83  * selected_faces <-- list of local number in parent mesh
84  *---------------------------------------------------------------------------*/
85
86 void
87 cs_join_post_faces_subset(const char *mesh_name,
88  const cs_join_mesh_t *parent_mesh,
89  cs_lnum_t n_select_faces,
90  const cs_lnum_t selected_faces[]);
91
92 /*----------------------------------------------------------------------------
93  * Post-process mesh after the update following the fusion operation.
94  *
95  * parameters:
96  * join_param <-- set of parameters for the joining operation
97  * join_select <-- list of all implied entities in the joining operation
98  *---------------------------------------------------------------------------*/
99
100 void
102  const cs_join_select_t *join_select);
103
104
105 /*----------------------------------------------------------------------------
106  * Post-process mesh after the update following the split operation.
107  *
108  * parameters:
109  * n_old_i_faces <-- initial number of interior faces
110  * n_old_b_faces <-- initial number of border faces
111  * n_g_new_b_faces <-- global number of new border faces
112  * n_select_faces <-- number of selected faces
113  * mesh <-- pointer to a cs_mesh_t structure
114  * join_param <-- set of parameters for the joining operation
115  *---------------------------------------------------------------------------*/
116
117 void
118 cs_join_post_after_split(cs_lnum_t n_old_i_faces,
119  cs_lnum_t n_old_b_faces,
120  cs_gnum_t n_g_new_b_faces,
121  cs_lnum_t n_select_faces,
122  const cs_mesh_t *mesh,
123  cs_join_param_t join_param);
124
125 /*----------------------------------------------------------------------------
126  * Post-process mesh after the update following the split operation.
127  *
128  * parameters:
129  * n_i_clean_faces <-- number of interior faces cleaned
130  * i_clean_faces <-> list of interior face numbers (ordered on exit)
131  * n_b_clean_faces <-- number of border faces cleaned
132  * b_clean_faces <-> list of border face numbers (ordered on exit)
133  * param <-- set of parameters for the joining operation
134  *---------------------------------------------------------------------------*/
135
136 void
137 cs_join_post_cleaned_faces(cs_lnum_t n_i_clean_faces,
138  cs_lnum_t i_clean_faces[],
139  cs_lnum_t n_b_clean_faces,
140  cs_lnum_t b_clean_faces[],
141  cs_join_param_t param);
142
143 /*----------------------------------------------------------------------------
144  * Post and dump a cs_join_mesh_t according to the verbosity level.
145  *
146  * parameters:
147  * basename <-- generic name for the mesh to post
148  * mesh <-- fvm_join_mesh_t structure to post
149  * param <-- fvm_join_param_t structure
150  *---------------------------------------------------------------------------*/
151
152 void
153 cs_join_post_dump_mesh(const char *basename,
154  const cs_join_mesh_t *mesh,
155  cs_join_param_t param);
156
157 /*----------------------------------------------------------------------------*/
158
160
161 #endif /* __CS_JOIN_POST_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
void cs_join_post_after_merge(cs_join_param_t join_param, const cs_join_select_t *join_select)
Definition: cs_join_post.c:438
Definition: cs_mesh.h:84
void cs_join_post_faces_subset(const char *mesh_name, const cs_join_mesh_t *parent_mesh, cs_lnum_t n_select_faces, const cs_lnum_t selected_faces[])
Definition: cs_join_post.c:403
void cs_join_post_init(void)
Definition: cs_join_post.c:244
void cs_join_post_dump_mesh(const char *basename, const cs_join_mesh_t *mesh, cs_join_param_t param)
Definition: cs_join_post.c:686
Definition: cs_defs.h:316
void cs_join_post_cleaned_faces(cs_lnum_t n_i_clean_faces, cs_lnum_t i_clean_faces[], cs_lnum_t n_b_clean_faces, cs_lnum_t b_clean_faces[], cs_join_param_t param)
Definition: cs_join_post.c:628
Definition: cs_join_util.h:115
void cs_join_post_after_split(cs_lnum_t n_old_i_faces, cs_lnum_t n_old_b_faces, cs_gnum_t n_g_new_b_faces, cs_lnum_t n_select_faces, const cs_mesh_t *mesh, cs_join_param_t join_param)
Definition: cs_join_post.c:520
Definition: mesh.f90:26
void cs_join_post_mesh(const char *mesh_name, const cs_join_mesh_t *join_mesh)
Definition: cs_join_post.c:274
