7.2
cs_interpolate.h
1 #ifndef __CS_INTERPOLATE_H__
2 #define __CS_INTERPOLATE_H__
5  * Interpolation function handling.
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_mesh_location.h"
36
38
41 /*=============================================================================
42  * Macro definitions
46  * Type definitions
48
49 /*----------------------------------------------------------------------------
50  * Field values interpolation type
51  *----------------------------------------------------------------------------*/
52
53 /*----------------------------------------------------------------------------*/
68 /*----------------------------------------------------------------------------*/
69
70 typedef void
72  cs_datatype_t datatype,
73  int val_dim,
74  cs_lnum_t n_points,
75  const cs_lnum_t point_location[],
76  const cs_real_3_t point_coords[],
77  const void *location_vals,
78  void *point_vals);
79
80 /*=============================================================================
81  * Public function prototypes
82  *============================================================================*/
83
84 /*----------------------------------------------------------------------------*/
103
104 void
106  cs_datatype_t datatype,
107  int val_dim,
108  cs_lnum_t n_points,
109  const cs_lnum_t point_location[],
110  const cs_real_3_t point_coords[],
111  const void *location_vals,
112  void *point_vals);
113
114 /*----------------------------------------------------------------------------*/
142 /*----------------------------------------------------------------------------*/
143
144 void
146  cs_datatype_t datatype,
147  int val_dim,
148  cs_lnum_t n_points,
149  const cs_lnum_t point_location[],
150  const cs_real_3_t point_coords[],
151  const void *location_vals,
152  void *point_vals);
153
154 /*----------------------------------------------------------------------------*/
155
157
158 #endif /* __CS_INTERPOLATE_H__ */
cs_datatype_t
Definition: cs_defs.h:275
void cs_interpolate_from_location_p1(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals)
Interpolate values defined on a mesh location at a given set of points using a P1 interpolation...
Definition: cs_interpolate.c:228
void() cs_interpolate_from_location_t(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals)
Function pointer for interpolatation of values defined on a mesh location at a given set of points...
Definition: cs_interpolate.h:71
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
void cs_interpolate_from_location_p0(void *input, cs_datatype_t datatype, int val_dim, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], const void *location_vals, void *point_vals)
Interpolate values defined on a mesh location at a given set of points using a P0 interpolation...
Definition: cs_interpolate.c:122
Definition: cs_defs.h:316
