7.2
cs_gwf_physical_properties.h
1 #ifndef __CS_GWF_PHYSICAL_PROPERTIES_H__
2 #define __CS_GWF_PHYSICAL_PROPERTIES_H__
5  * Physical properties management for groundwater flow module.
34 #include <stdarg.h>
37  * Local headers
40 #include "cs_defs.h"
41 #include "cs_gwf_parameters.h"
46
48  * Public function prototypes
50
51 /*----------------------------------------------------------------------------
52  * Update delay of all transported species (user scalars)
53  *
54  * Species transport is delayed by retention in solid phase. This delay is
55  * computed as follows:
56  * R = 1 + rho K_d/theta
57  * where R is the delay factor, rho the soil density,
58  * K_d the contaminant distribution coefficient and theta the moisture content
59  * (saturation).
60  *---------------------------------------------------------------------------*/
61
62 void
64
65 /*----------------------------------------------------------------------------
66  * Add first-order decay to implicit part of source term array
67  *
68  * Corresponding EDO for decay phenomenon is:
69  * dc/dt = -decay_rate * c
70  *
71  * parameters:
72  * f_id --> field index of scalar on which decay is set
73  * ts_imp <-> implicit part of the source term
74  *----------------------------------------------------------------------------*/
75
76 void
77 cs_gwf_decay_rate(const int f_id,
78  cs_real_t *ts_imp);
79
80 /*----------------------------------------------------------------------------
81  * Update sorbed concentration for scalars with kinetic sorption.
82  *
83  * It is estimated by the following analytical expression :
84  * S^{n+1} = S^n exp(- (k^{-} + decay_rate) * dt)
85  * - C^n * k^{+}/(k^{-} + decay_rate)
86  * (exp(- (k^{-} + decay_rate) * dt) - 1)
87  *
88  * parameters:
89  * f_id --> field index of scalar which properties are updated
90  *----------------------------------------------------------------------------*/
91
92 void
94
95 /*----------------------------------------------------------------------------
96  * Clip liquid concentration to solubility index.
97  *
98  * parameters:
99  * f_id --> field index of scalar which properties are updated
100  *----------------------------------------------------------------------------*/
101
102 void
103 cs_gwf_precipitation(const int f_id);
104
105 /*----------------------------------------------------------------------------
106  * Take into account kinetic chemical reaction in evolution equation
107  * of total liquid concentration.
108  *
109  * parameters:
110  * f_id --> field index of scalar which properties are updated
111  * ts_imp <-> implicit part of the source term
112  * ts_exp <-> explicit part of the source term
113  *----------------------------------------------------------------------------*/
114
115 void
116 cs_gwf_kinetic_reaction(const int f_id,
117  cs_real_t *ts_imp,
118  cs_real_t *ts_exp);
119
120 /*----------------------------------------------------------------------------*/
121
123
124 #endif /* __CS_GWF_PHYSICAL_PROPERTIES_H__ */
void cs_gwf_decay_rate(const int f_id, cs_real_t *ts_imp)
Add first-order decay to implicit part of source term array.
Definition: cs_gwf_physical_properties.c:138
void cs_gwf_sorbed_concentration_update(const int f_id)
Definition: cs_gwf_physical_properties.c:169
Definition: cs_defs.h:322
void cs_gwf_delay_update(void)
Definition: cs_gwf_physical_properties.c:92
void cs_gwf_precipitation(const int f_id)
Update liquid concentration according to precipitation phenomenon.
Definition: cs_gwf_physical_properties.c:230
void cs_gwf_kinetic_reaction(const int f_id, cs_real_t *ts_imp, cs_real_t *ts_exp)
Take into account kinetic chemical reaction in evolution equation of total liquid concentration...
Definition: cs_gwf_physical_properties.c:280
