1 #ifndef __CS_CDOVCB_SCALEQ_H__ 2 #define __CS_CDOVCB_SCALEQ_H__ 426 void *scheme_context);
442 void *scheme_context);
time step descriptor
Definition: cs_time_step.h:64
cs_real_t * cs_cdovcb_scaleq_get_vertex_values(void *context, bool previous)
Retrieve an array of values at mesh vertices for the variable field associated to the given context T...
Definition: cs_cdovcb_scaleq.c:2698
void cs_cdovcb_scaleq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdovcb_scaleq.c:945
void cs_cdovcb_scaleq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Read additional arrays (not defined as fields) but useful for the checkpoint/restart process...
Definition: cs_cdovcb_scaleq.c:3503
void * cs_cdovcb_scaleq_init_context(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdovcb_scaleq_t structure storing data useful for building and managing such a scheme...
Definition: cs_cdovcb_scaleq.c:1003
void cs_cdovcb_scaleq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Write additional arrays (not defined as fields) but useful for the checkpoint/restart process...
Definition: cs_cdovcb_scaleq.c:3556
void cs_cdovcb_scaleq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction eq...
Definition: cs_cdovcb_scaleq.c:1748
void cs_cdovcb_scaleq_solve_implicit(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equati...
Definition: cs_cdovcb_scaleq.c:1990
void cs_cdovcb_scaleq_boundary_diff_flux(const cs_real_t t_eval, const cs_equation_param_t *eqp, const cs_real_t *pot_v, const cs_real_t *pot_c, cs_equation_builder_t *eqb, void *context, cs_real_t *vf_flux)
Compute for each vertex of a boundary face, the portion of diffusive flux across the boundary face...
Definition: cs_cdovcb_scaleq.c:2764
void cs_cdovcb_scaleq_finalize_sharing(void)
Free buffers and generic structures related to CDO vertex+cell-based schemes.
Definition: cs_cdovcb_scaleq.c:967
void cs_cdovcb_scaleq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued CDO-VCb schemes.
Definition: cs_cdovcb_scaleq.c:1383
void cs_cdovcb_scaleq_diff_flux_dfaces(const cs_real_t *values, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux)
Cellwise computation of the diffusive flux across dual faces Case of scalar-valued CDO-VCb schemes...
Definition: cs_cdovcb_scaleq.c:3277
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
void cs_cdovcb_scaleq_diff_flux_in_cells(const cs_real_t *values, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux)
Cellwise computation of the diffusive flux in each cells. Case of scalar-valued CDO-VCb schemes...
Definition: cs_cdovcb_scaleq.c:3177
void * cs_cdovcb_scaleq_free_context(void *data)
Destroy a cs_cdovcb_scaleq_t structure.
Definition: cs_cdovcb_scaleq.c:1343
Definition: cs_restart.h:93
void cs_cdovcb_scaleq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to CDO vertex+cell-based schemes Set shared point...
Definition: cs_cdovcb_scaleq.c:895
Definition: cs_cdo_local.h:60
void cs_cdovcb_scaleq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovcb_scaleq.c:3630
void cs_cdovcb_scaleq_vtx_gradient(const cs_real_t *v_values, cs_equation_builder_t *eqb, void *context, cs_real_t *v_gradient)
Cellwise computation of the discrete gradient at vertices.
Definition: cs_cdovcb_scaleq.c:3380
cs_real_t * cs_cdovcb_scaleq_get_cell_values(void *context, bool previous)
Get the computed values at mesh cells from the inverse operation w.r.t. the static condensation (DoF ...
Definition: cs_cdovcb_scaleq.c:2731
void cs_cdovcb_scaleq_solve_theta(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovcb_scaleq.c:2303
void cs_cdovcb_scaleq_interpolate(const cs_mesh_t *mesh, const cs_real_t *cell_values, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a scalar steady-state equation with a CDO-VCb scheme...
Definition: cs_cdovcb_scaleq.c:1510
void cs_cdovcb_scaleq_flux_across_plane(const cs_real_t normal[], const cs_real_t *pdi, const cs_equation_param_t *eqp, int ml_id, cs_equation_builder_t *eqb, void *context, double *d_flux, double *c_flux)
Compute the diffusive and convective flux across a list of faces Case of scalar-valued CDO-Vcb scheme...
Definition: cs_cdovcb_scaleq.c:2985
void cs_cdovcb_scaleq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition: cs_cdovcb_scaleq.c:3598
bool cs_cdovcb_scaleq_is_initialized(void)
Check if the generic structures for building a CDO-vertex+cell based scheme are allocated.
Definition: cs_cdovcb_scaleq.c:874
