7.2
cs_cdovb_priv.h
1 #ifndef __CS_CDOVB_PRIV_H__
2 #define __CS_CDOVB_PRIV_H__
5  * Definition of cs_cdovb_scaleq_t and cs_cdovb_vecteq structures
29  * Local headers
32 #include "cs_defs.h"
33 #include "cs_hodge.h"
34 #include "cs_cdo_advection.h"
35 #include "cs_equation_bc.h"
36 #include "cs_equation_builder.h"
50  * Macro definitions
52
54  * Type definitions
56
57 /*----------------------------------------------------------------------------*/
68 /*----------------------------------------------------------------------------*/
69
70 typedef void
72  const cs_cell_mesh_t *cm,
73  const cs_hodge_t *mass_hodge,
74  const cs_equation_builder_t *eqb,
76  cs_cell_sys_t *csys);
77
78 /*----------------------------------------------------------------------------*/
91
92 typedef void
94  const cs_cell_mesh_t *cm,
95  const cs_hodge_t *mass_hodge,
96  const double inv_dtcur,
99  cs_cell_sys_t *csys);
100
101 /*=============================================================================
102  * Structure definitions
103  *============================================================================*/
104
105 /* Algebraic system for CDO vertex-based discretization */
106
107 struct _cs_cdovb_t {
108
109  /* Ids related to the variable field and to the boundary flux field */
110
113
114  /* System size */
115
117
118  /* Array storing the value arising from the contribution of all source
119  terms */
120
122
123  /* Array for extra-operations */
124
125  cs_real_t *cell_values; /* NULL if not requested */
126
127  /* Boundary conditions */
128
132
133  /* Only for vector-valued variables */
134
136
137  /* Pointer of function to build the diffusion term */
138
141
142  /* Pointer of function to build the advection term */
143
146
147  /* Pointer of function to build the unsteady term */
148
150
151  /* Pointer of function to build the unsteady term */
152
154
155  /* If one needs to build a local Hodge operator for the unsteady and/or the
156  reaction term(s) */
157
161
162 };
163
164 /* Scalar-valued and vector-valued equations rely on the same pattern */
165
166 typedef struct _cs_cdovb_t cs_cdovb_scaleq_t;
167 typedef struct _cs_cdovb_t cs_cdovb_vecteq_t;
168
169 /*============================================================================
170  * Public function prototypes
171  *============================================================================*/
172
173 /*----------------------------------------------------------------------------*/
174
176
177 #endif /* __CS_CDOVB_PRIV_H__ */
void() cs_cdovb_advection_bc_t(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the advection operator in CDO vertex-based (or vertex+cell-based) sch...
Definition: cs_cdo_advection.h:182
cs_cdovb_advection_bc_t * add_advection_bc
Definition: cs_cdovb_priv.h:145
cs_hodge_t ** diffusion_hodge
Definition: cs_cdovb_priv.h:139
void() cs_cdovb_advection_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme. The local matrix related to this operator is stored in cb->loc.
Definition: cs_cdo_advection.h:161
void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Enforcement of a boundary condition (Dirichlet, Robin, sliding...)
Definition: cs_equation_bc.h:89
cs_hodge_compute_t * get_mass_matrix
Definition: cs_cdovb_priv.h:160
Definition: cs_cdovb_priv.h:107
int var_field_id
Definition: cs_cdovb_priv.h:111
Definition: cs_hodge.h:186
cs_hodge_compute_t * get_stiffness_matrix
Definition: cs_cdovb_priv.h:140
cs_hodge_t ** mass_hodge
Definition: cs_cdofb_priv.h:104
cs_cdo_enforce_bc_t * enforce_sliding
Definition: cs_cdovb_priv.h:135
Definition: cs_defs.h:322
cs_hodge_param_t mass_hodgep
Definition: cs_cdovb_priv.h:158
Definition: cs_cdovb_priv.h:159
void() cs_cdovb_reaction_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_hodge_t *mass_hodge, const cs_equation_builder_t *eqb, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Add the reaction term for a CDO vertex-based scheme.
Definition: cs_cdovb_priv.h:71
cs_flag_t * vtx_bc_flag
Definition: cs_cdovb_priv.h:129
cs_lnum_t n_dofs
Definition: cs_cdovb_priv.h:116
int bflux_field_id
Definition: cs_cdovb_priv.h:112
cs_real_t * source_terms
Definition: cs_cdovb_priv.h:121
cs_cdovb_advection_t * get_advection_matrix
Definition: cs_cdovb_priv.h:144
cs_cdo_enforce_bc_t * enforce_robin_bc
Definition: cs_cdovb_priv.h:131
Definition: cs_cdo_local.h:60
cs_real_t * cell_values
Definition: cs_cdovb_priv.h:125
cs_cdovb_time_t * add_unsteady_term
Definition: cs_cdovb_priv.h:153
Definition: cs_defs.h:316
unsigned short int cs_flag_t
Definition: cs_defs.h:324
cs_cdovb_reaction_t * add_reaction_term
Definition: cs_cdovb_priv.h:149
bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell...
Definition: cs_hodge.h:221
void() cs_cdovb_time_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_hodge_t *mass_hodge, const double inv_dtcur, cs_equation_builder_t *eqb, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Apply the time scheme for a CDO vertex-based scheme.
Definition: cs_cdovb_priv.h:93
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator...
Definition: cs_hodge.h:154
cs_cdo_enforce_bc_t * enforce_dirichlet
Definition: cs_cdovb_priv.h:130
