7.2
cs_calcium.h
1 #ifndef __CS_CALCIUM_H__
2 #define __CS_CALCIUM_H__
5  * Basic CALCIUM-mappable functions for code coupling
31  * Local headers
34 #include "cs_base.h"
41  * Local Macro Definitions
45  * Type Definitions
51
52 /*----------------------------------------------------------------------------
53  * Read values, blocking until they are available.
54  *
55  * parameters:
56  * rank_id <-- communicating MPI rank id
57  * iteration <-> iteration number of read
58  * var_name <-- name of the variable to read
59  * n_val_max <-- maximum number of values to read
60  * n_val_read <-- maximum number of values to read
61  * val --> values read
62  *
63  * returns:
64  * 0 in case of success, error code otherwise
65  *----------------------------------------------------------------------------*/
66
67 int
68 cs_calcium_read_int(int rank_id,
69  int *iteration,
70  const char *var_name,
71  int n_val_max,
72  int *n_val_read,
73  int val[]);
74
75 int
76 cs_calcium_read_double(int rank_id,
77  int *iteration,
78  const char *var_name,
79  int n_val_max,
80  int *n_val_read,
81  double val[]);
82
83 /*----------------------------------------------------------------------------
84  * Write values.
85  *
86  * parameters:
87  * rank_id <-- communicating MPI rank id
88  * iteration <-- iteration number
89  * var_name <-- name of the variable to read
90  * n_val <-- number of values to read
91  * val <-- values written
92  *
93  * returns:
94  * 0 in case of success, error code otherwise
95  *----------------------------------------------------------------------------*/
96
97 int
98 cs_calcium_write_int(int rank_id,
99  int iteration,
100  const char *var_name,
101  int n_val,
102  const int val[]);
103
104 int
105 cs_calcium_write_double(int rank_id,
106  int iteration,
107  const char *var_name,
108  int n_val,
109  const double val[]);
110
111 /*----------------------------------------------------------------------------
112  * Set the CALCIUM-mappable function's verbosity
113  *
114  * parameters:
115  * n_echo <-- verbosity (none if -1, headers if 0,
116  * headers + n first and last elements if > 0.
117  *----------------------------------------------------------------------------*/
118
119 void
120 cs_calcium_set_verbosity(int n_echo);
121
123
125
126 #endif /* __CS_CALCIUM_H__ */
127
int cs_calcium_write_double(int rank_id, int iteration, const char *var_name, int n_val, const double val[])
Definition: cs_calcium.c:512
int cs_calcium_read_double(int rank_id, int *iteration, const char *var_name, int n_val_max, int *n_val_read, double val[])
Definition: cs_calcium.c:387
int cs_calcium_read_int(int rank_id, int *iteration, const char *var_name, int n_val_max, int *n_val_read, int val[])
Definition: cs_calcium.c:313
void cs_calcium_set_verbosity(int n_echo)
Definition: cs_calcium.c:559
int cs_calcium_write_int(int rank_id, int iteration, const char *var_name, int n_val, const int val[])
Definition: cs_calcium.c:458
