7.2
cs_base_accel.h
1 #ifndef __CS_BASE_ACCEL_H__
2 #define __CS_BASE_ACCEL_H__
5  * Definitions, global variables, and base functions for accelerators.
30 #include "cs_defs.h"
36 #include <stdio.h>
39  * Local headers
42 #include "bft_mem.h"
45  * Macro definitions
48 /*
49  * Allocate memory for _ni items of type _type.
50  *
51  * This macro calls cs_malloc_hd(), automatically setting the
52  * allocated variable name and source file name and line arguments.
53  *
54  * If separate allocations are used on the host and device
55  * (mode == CS_ALLOC_HOST_DEVICE), the host pointer is returned.
56  *
57  * parameters:
58  * _ptr --> pointer to allocated memory.
59  * _ni <-- number of items.
60  * _type <-- element type.
61  * _mode <-- allocation mode.
62  */
63
64 #define CS_MALLOC_HD(_ptr, _ni, _type, _mode) \
65 _ptr = (_type *) cs_malloc_hd(_mode, _ni, sizeof(_type), \
66  #_ptr, __FILE__, __LINE__)
67
68 /*
69  * Reallocate memory for _ni items of type _type.
70  *
71  * This macro calls cs_realloc_hd(), automatically setting the
72  * allocated variable name and source file name and line arguments.
73  *
74  * If the allocation parameters are unchanged, no actual reallocation
75  * occurs.
76  *
77  * parameters:
78  * _ptr <-> pointer to allocated memory.
79  * _ni <-- number of items.
80  * _type <-- element type.
81  * _mode <-- allocation mode.
82  */
83
84 #define CS_REALLOC_HD(_ptr, _ni, _type, _mode) \
85 _ptr = (_type *) cs_realloc_hd(_ptr, _mode, _ni, sizeof(_type), \
86  #_ptr, __FILE__, __LINE__)
87
88 /*
89  * Free allocated memory.
90  *
91  * This macro calls cs_mem_free_any(), automatically setting the
92  * allocated variable name and source file name and line arguments.
93  *
94  * The freed pointer is set to NULL to avoid accidental reuse.
95  *
96  * If separate allocations are used on the host and device
97  * (mode == CS_ALLOC_HOST_DEVICE), the host pointer should be used with this
98  * function.
99  *
100  * parameters:
101  * _ptr <-> pointer to allocated memory.
102  */
103
104 #define CS_FREE_HD(_ptr) \
105 cs_free_hd(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL
106
107 /*
108  * Free allocated memory.
109  *
110  * This macro calls cs_mem_free(), automatically setting the
111  * allocated variable name and source file name and line arguments.
112  *
113  * The freed pointer is set to NULL to avoid accidental reuse.
114  *
115  * If separate allocations are used on the host and device
116  * (mode == CS_ALLOC_HOST_DEVICE), the host pointer should be used with this
117  * function.
118  *
119  * parameters:
120  * _ptr <-> pointer to allocated memory.
121  */
122
123 #define CS_FREE(_ptr) \
124 cs_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL
125
126 /*----------------------------------------------------------------------------*/
127
129
130 /*============================================================================
131  * Type definitions
132  *============================================================================*/
133
134 /*----------------------------------------------------------------------------
135  * Variable value type.
136  *----------------------------------------------------------------------------*/
137
142 typedef enum {
143
154
155 /*=============================================================================
156  * Global variable definitions
157  *============================================================================*/
158
159 #if defined(HAVE_ACCEL)
160
162
163 #else
164
165 #define cs_alloc_mode CS_ALLOC_HOST
166
167 #endif
168
169 /*=============================================================================
170  * Public function prototypes
171  *============================================================================*/
172
173 /*----------------------------------------------------------------------------*/
179 /*----------------------------------------------------------------------------*/
180
181 #if defined(HAVE_ACCEL)
182
183 int
184 cs_get_device_id(void);
185
186 #else
187
188 static inline int
190 {
191  return -1;
192 }
193
194 #endif
195
196 /*----------------------------------------------------------------------------*/
216
217 #if defined(HAVE_ACCEL)
218
219 void *
221  size_t ni,
222  size_t size,
223  const char *var_name,
224  const char *file_name,
225  int line_num);
226
227 #else
228
229 inline static void *
231  size_t ni,
232  size_t size,
233  const char *var_name,
234  const char *file_name,
235  int line_num)
236 {
237  CS_UNUSED(mode);
238  return bft_mem_malloc(ni, size, var_name, file_name, line_num);
239 }
240
241 #endif
242
243 /*----------------------------------------------------------------------------*/
271 /*----------------------------------------------------------------------------*/
272
273 #if defined(HAVE_ACCEL)
274
275 void *
276 cs_realloc_hd(void *ptr,
277  cs_alloc_mode_t mode,
278  size_t ni,
279  size_t size,
280  const char *var_name,
281  const char *file_name,
282  int line_num);
283
284 #else
285
286 inline static void *
287 cs_realloc_hd(void *ptr,
288  cs_alloc_mode_t mode,
289  size_t ni,
290  size_t size,
291  const char *var_name,
292  const char *file_name,
293  int line_num)
294 {
295  CS_UNUSED(mode);
296  return bft_mem_realloc(ptr, ni, size, var_name, file_name, line_num);
297 }
298
299 #endif
300
301 /*----------------------------------------------------------------------------*/
313 /*----------------------------------------------------------------------------*/
314
315 #if defined(HAVE_ACCEL)
316
317 void
318 cs_free_hd(void *ptr,
319  const char *var_name,
320  const char *file_name,
321  int line_num);
322
323 #else
324
325 inline static void
326 cs_free_hd(void *ptr,
327  const char *var_name,
328  const char *file_name,
329  int line_num)
330 {
331  bft_mem_free(ptr, var_name, file_name, line_num);
332 }
333
334 #endif
335
336 /*----------------------------------------------------------------------------*/
348 /*----------------------------------------------------------------------------*/
349
350 #if defined(HAVE_ACCEL)
351
352 void
353 cs_free(void *ptr,
354  const char *var_name,
355  const char *file_name,
356  int line_num);
357
358 #else
359
360 inline static void
361 cs_free(void *ptr,
362  const char *var_name,
363  const char *file_name,
364  int line_num)
365 {
366  bft_mem_free(ptr, var_name, file_name, line_num);
367 }
368
369 #endif
370
371 /*----------------------------------------------------------------------------*/
385 /*----------------------------------------------------------------------------*/
386
387 #if defined(HAVE_ACCEL)
388
389 void *
390 cs_get_device_ptr(void *ptr);
391
392 #else
393
394 inline static void *
396 {
397  return ptr;
398 }
399
400 #endif
401
402 /*----------------------------------------------------------------------------*/
416 /*----------------------------------------------------------------------------*/
417
418 #if defined(HAVE_ACCEL)
419
420 const void *
421 cs_get_device_ptr_const(const void *ptr);
422
423 #else
424
425 inline static const void *
426 cs_get_device_ptr_const(const void *ptr)
427 {
428  return ptr;
429 }
430
431 #endif
432
433 /*----------------------------------------------------------------------------*/
448 /*----------------------------------------------------------------------------*/
449
450 #if defined(HAVE_ACCEL)
451
452 const void *
453 cs_get_device_ptr_const_pf(const void *ptr);
454
455 #else
456
457 inline static const void *
459 {
460  return ptr;
461 }
462
463 #endif
464
465 /*----------------------------------------------------------------------------*/
474 /*----------------------------------------------------------------------------*/
475
476 #if defined(HAVE_ACCEL)
477
479 cs_check_device_ptr(const void *ptr);
480
481 #else
482
483 inline static cs_alloc_mode_t
484 cs_check_device_ptr(const void *ptr)
485 {
486  CS_UNUSED(ptr);
487  return CS_ALLOC_HOST;
488 }
489
490 #endif
491
492 /*----------------------------------------------------------------------------*/
506 /*----------------------------------------------------------------------------*/
507
508 #if defined(HAVE_ACCEL)
509
510 void *
511 cs_associate_device_ptr(void *host_ptr,
512  size_t ni,
513  size_t size);
514
515 #else
516
517 #define cs_associate_device_ptr(_host_ptr, _ni, _size);
518
519 #endif
520
521 /*----------------------------------------------------------------------------*/
530 /*----------------------------------------------------------------------------*/
531
532 #if defined(HAVE_ACCEL)
533
534 void
535 cs_disassociate_device_ptr(void *host_ptr);
536
537 #else
538
539 #define cs_disassociate_device_ptr(_host_ptr);
540
541 #endif
542
543 /*----------------------------------------------------------------------------*/
554 /*----------------------------------------------------------------------------*/
555
556 #if defined(HAVE_ACCEL)
557
558 void
559 cs_set_alloc_mode(void **host_ptr,
560  cs_alloc_mode_t mode);
561
562 #else
563
564 #define cs_set_alloc_mode(_host_ptr, mode);
565
566 #endif
567
568 /*----------------------------------------------------------------------------*/
584 /*----------------------------------------------------------------------------*/
585
586 #if defined(HAVE_ACCEL)
587
588 void
589 cs_sync_h2d(const void *ptr);
590
591 #else
592
593 static inline void
594 cs_sync_h2d(const void *ptr)
595 {
596  CS_UNUSED(ptr);
597 }
598
599 #endif
600
601 /*----------------------------------------------------------------------------*/
623 /*----------------------------------------------------------------------------*/
624
625 #if defined(HAVE_ACCEL)
626
627 void
628 cs_sync_h2d_future(const void *ptr);
629
630 #else
631
632 static inline void
633 cs_sync_h2d_future(const void *ptr)
634 {
635  CS_UNUSED(ptr);
636 }
637
638 #endif
639
640 /*----------------------------------------------------------------------------*/
657 /*----------------------------------------------------------------------------*/
658
659 #if defined(HAVE_ACCEL)
660
661 void
662 cs_sync_d2h(void *ptr);
663
664 #else
665
666 static inline void
667 cs_sync_d2h(void *ptr)
668 {
669  CS_UNUSED(ptr);
670 }
671
672 #endif
673
674 /*----------------------------------------------------------------------------*/
685 /*----------------------------------------------------------------------------*/
686
687 #if defined(HAVE_ACCEL)
688
689 void
690 cs_prefetch_h2d(void *ptr,
691  size_t size);
692
693 #else
694
695 static inline void
696 cs_prefetch_h2d(void *ptr,
697  size_t size)
698 {
699  CS_UNUSED(ptr);
700  CS_UNUSED(size);
701 }
702
703 #endif
704
705 /*----------------------------------------------------------------------------*/
716 /*----------------------------------------------------------------------------*/
717
718 #if defined(HAVE_ACCEL)
719
720 void
721 cs_prefetch_d2h(void *ptr,
722  size_t size);
723
724 #else
725
726 static inline void
727 cs_prefetch_d2h(void *ptr,
728  size_t size)
729 {
730  CS_UNUSED(ptr);
731  CS_UNUSED(size);
732 }
733
734 #endif
735
736 #if defined(HAVE_ACCEL)
737
738 /*----------------------------------------------------------------------------*/
749 /*----------------------------------------------------------------------------*/
750
751 void
752 cs_copy_h2d(void *dest,
753  const void *src,
754  size_t size);
755
756 /*----------------------------------------------------------------------------*/
767 /*----------------------------------------------------------------------------*/
768
769 void
770 cs_copy_d2h(void *dest,
771  const void *src,
772  size_t size);
773
774 /*----------------------------------------------------------------------------*/
785 /*----------------------------------------------------------------------------*/
786
787 void
788 cs_copy_d2d(void *dest,
789  const void *src,
790  size_t size);
791
792 #endif /* defined(HAVE_ACCEL) */
793
794 /*----------------------------------------------------------------------------*/
800 /*----------------------------------------------------------------------------*/
801
802 #if defined(HAVE_ACCEL)
803
804 int
806
807 #else
808
809 static inline int
811 {
812  return 0;
813 }
814
815 #endif
816
817 /*----------------------------------------------------------------------------*/
825 /*----------------------------------------------------------------------------*/
826
827 #if defined(HAVE_ACCEL)
828
829 size_t
830 cs_get_allocation_hd_size(void *host_ptr);
831
832 #else
833
834 static inline size_t
836 {
837  CS_UNUSED(host_ptr);
838  return 0;
839 }
840
841 #endif
842
843 #if defined(HAVE_OPENMP_TARGET)
844
845 /*----------------------------------------------------------------------------*/
854 /*----------------------------------------------------------------------------*/
855
856 int
857 cs_omp_target_select_default_device(void);
858
859 #endif /* defined(HAVE_OPENMP_TARGET) */
860
861 /*----------------------------------------------------------------------------*/
862
864
865 #endif /* __CS_BASE_ACCEL_H__ */
Detach device memory from a given host memory pointer.
Definition: cs_base_accel.h:539
static size_t cs_get_allocation_hd_size(void *host_ptr)
Check if a given host pointer is allocated with associated with cs_alloc_hd or cs_realloc_hd.
Definition: cs_base_accel.h:835
void cs_copy_h2d(void *dest, const void *src, size_t size)
Copy data from host to device.
Definition: cs_base_accel.cxx:1363
static int cs_get_n_allocations_hd(void)
Return number of host-device allocations.
Definition: cs_base_accel.h:810
static void cs_sync_d2h(void *ptr)
Synchronize data from device to host.
Definition: cs_base_accel.h:667
#define CS_UNUSED(x)
Definition: cs_defs.h:496
Definition: cs_base_accel.h:144
static int cs_get_device_id(void)
Return currently associated device id.
Definition: cs_base_accel.h:189
static void cs_sync_h2d(const void *ptr)
Synchronize data from host to device.
Definition: cs_base_accel.h:594
Definition: cs_base_accel.h:146
void * bft_mem_realloc(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory for ni elements of size bytes.
Definition: bft_mem.c:899
Definition: cs_base_accel.h:145
Associate device memory with a given host memory pointer.
Definition: cs_base_accel.h:517
Definition: cs_base_accel.h:165
static void * cs_realloc_hd(void *ptr, cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory on host and device for ni elements of size bytes.
Definition: cs_base_accel.h:287
static cs_alloc_mode_t cs_check_device_ptr(const void *ptr)
Check if a pointer is associated with a device.
Definition: cs_base_accel.h:484
cs_alloc_mode_t
Definition: cs_base_accel.h:142
static void cs_prefetch_d2h(void *ptr, size_t size)
Prefetch data from device to host.
Definition: cs_base_accel.h:727
Set allocation mode for an already allocated pointer.
Definition: cs_base_accel.h:564
static void * cs_malloc_hd(cs_alloc_mode_t mode, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory on host and device for ni elements of size bytes.
Definition: cs_base_accel.h:230
Definition: cs_base_accel.h:149
static const void * cs_get_device_ptr_const(const void *ptr)
Return matching device pointer for a given constant pointer.
Definition: cs_base_accel.h:426
static void cs_free_hd(void *ptr, const char *var_name, const char *file_name, int line_num)
Free memory on host and device for a given host pointer.
Definition: cs_base_accel.h:326
void cs_copy_d2h(void *dest, const void *src, size_t size)
Copy data from device to host.
Definition: cs_base_accel.cxx:1393
void cs_copy_d2d(void *dest, const void *src, size_t size)
Copy data from device to device.
Definition: cs_base_accel.cxx:1423
Definition: cs_base_accel.h:151
void * bft_mem_free(void *ptr, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:1056
static void cs_prefetch_h2d(void *ptr, size_t size)
Prefetch data from host to device.
Definition: cs_base_accel.h:696
static void * cs_get_device_ptr(void *ptr)
Return matching device pointer for a given pointer.
Definition: cs_base_accel.h:395
static const void * cs_get_device_ptr_const_pf(const void *ptr)
Return matching device pointer for a given constant pointer, prefetching if applicable.
Definition: cs_base_accel.h:458
void * bft_mem_malloc(size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory for ni elements of size bytes.
Definition: bft_mem.c:815
static void cs_sync_h2d_future(const void *ptr)
Initiate synchronization of data from host to device for future access.
Definition: cs_base_accel.h:633
static void cs_free(void *ptr, const char *var_name, const char *file_name, int line_num)
Free memory on host and device for a given pointer.
Definition: cs_base_accel.h:361
