7.1
fvm_neighborhood.h
1 #ifndef __FVM_NEIGHBORHOOD_H__
2 #define __FVM_NEIGHBORHOOD_H__
5  * Search octrees and quadtrees of boxes.
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
43  * Macro definitions
45
47  * Type definitions
49
50 typedef struct _fvm_neighborhood_t fvm_neighborhood_t;
51
53  * Public function definitions
55
56 /*----------------------------------------------------------------------------
57  * Create a neighborhood_t structure and initialize it.
58  *
59  * parameters:
60  * comm <-- associated MPI communicator
61  *
62  * returns:
63  * pointer to an empty fvm_box_tree_t structure.
64  *----------------------------------------------------------------------------*/
65
66 #if defined(HAVE_MPI)
67
69 fvm_neighborhood_create(MPI_Comm comm);
70
71 #else
72
75
76 #endif
77
78 /*----------------------------------------------------------------------------
79  * Destroy a neighborhood_t structure.
80  *
81  * parameters:
82  * n <-> pointer to pointer to fvm_neighborhood_t structure to destroy.
83  *----------------------------------------------------------------------------*/
84
85 void
87
88 /*----------------------------------------------------------------------------
89  * Set non-default algorithm parameters for neighborhood management structure.
90  *
91  * parameters:
92  * n <-> pointer to neighborhood management structure
93  * max_tree_depth <-- maximum search tree depth
94  * leaf_threshold <-- maximum number of boxes which can be related to
95  * a leaf of the tree if level < max_tree_depth
96  * max_box_ratio <-- stop adding levels to tree when
97  * (n_linked_boxes > max_box_ratio*n_init_boxes)
98  * max_box_ratio_distrib <-- maximum box ratio when computing coarse
99  * tree prior to parallel distribution
100  *---------------------------------------------------------------------------*/
101
102 void
104  int max_tree_depth,
105  int leaf_threshold,
106  float max_box_ratio,
107  float max_box_ratio_distrib);
108
109 /*----------------------------------------------------------------------------
110  * Retrieve pointers to of arrays from a neighborhood_t structure.
111  *
112  * Arrays remain the property of the neighborhood_t structure, and must not
113  * be modified by the caller.
114  *
115  * parameters:
116  * n <-> pointer to fvm_neighborhood_t structure.
117  * n_elts --> number of elements with neighbors in block
118  * associated with local rank
119  * elt_num --> global element numbers in local block (size: n_elts)
120  * neighbor_index --> start index of neighbors (size: n_elts + 1)
121  * neighbor_num --> global element neighbor numbers
122  * (size: neighbor_index[n_elts])
123  *----------------------------------------------------------------------------*/
124
125 void
127  cs_lnum_t *n_elts,
128  cs_gnum_t **const elt_num,
129  cs_lnum_t **const neighbor_index,
130  cs_gnum_t **const neighbor_num);
131
132 /*----------------------------------------------------------------------------
133  * Transfer ownership of arrays from a neighborhood_t structure to the
134  * calling program.
135  *
136  * Arrays that are transferred are removed from the structure, so its
137  * use after calling this function is limited to querying timing information
138  * until a new neighborhood is computed.
139  *
140  * parameters:
141  * n <-> pointer to fvm_neighborhood_t structure.
142  * n_elts --> number of elements with neighbors in block
143  * associated with local rank
144  * elt_num --> global element numbers in local block (size: n_elts)
145  * neighbor_index --> start index of neighbors (size: n_elts + 1)
146  * neighbor_num --> global element neighbor numbers
147  * (size: neighbor_index[n_elts])
148  *----------------------------------------------------------------------------*/
149
150 void
152  cs_lnum_t *n_elts,
153  cs_gnum_t **elt_num,
154  cs_lnum_t **neighbor_index,
155  cs_gnum_t **neighbor_num);
156
157 /*----------------------------------------------------------------------------
158  * Determine intersecting boxes.
159  *
160  * Box global numbers and extents may be either copied for the structure's
161  * internal use from the caller, or transferred to the neighborhood management
162  * structure: both the box_gnum and extents arguments have an "assigned"
163  * variant, in which case a pointer to a pointer is provided, and the
164  * argument's property is transferred to the neighborhod management structure.
165  * The unused variant of an argument should be set to NULL.
166  *
167  * Boxes may be distributed among processors, so their intersections are
168  * determined using a block distribution, and defined using their
169  * global numbers.
170  *
171  * All global numbers appearing in box_gnum[] will have a matching entry in
172  * the neighborhod structure. To remove global numbers entries with no
173  * neighbors from the structure, the fvm_neighborhood_prune() function
174  * may be used.
175  *
176  * parameters:
177  * n <-> pointer to neighborhood management structure
178  * dim <-- spatial dimension
179  * n_boxes <-- local number of boxes
180  * box_gnum <-- global numbering of boxes
181  * extents <-- coordinate extents (size: n_boxes*dim*2, as
182  * xmin1, ymin1, .. xmax1, ymax1, ..., xmin2, ...)
183  * box_gnum_assigned <-> as box_gnum, ownership transferred (NULL on return)
184  * extents_assigned <-> as extents, ownership transferred (NULL on return)
185  *---------------------------------------------------------------------------*/
186
187 void
189  int dim,
190  cs_lnum_t n_boxes,
191  const cs_gnum_t *box_gnum,
192  const cs_coord_t *extents,
193  cs_gnum_t **box_gnum_assigned,
194  cs_coord_t **extents_assigned);
195
196 /*----------------------------------------------------------------------------
197  * Prune a neighborhood (remove entries with no neighbors).
198  *
199  * parameters:
200  * n <-> pointer to neighborhood management structure
201  *----------------------------------------------------------------------------*/
202
203 void
205
206 /*----------------------------------------------------------------------------
207  * Get global statistics relative to the search structures used
208  * by fvm_neighborhood_by_boxes().
209  *
210  * All fields returned are optional: if their argument is set to NULL,
211  * the corresponding information will not be returned.
212  *
213  * For each field not set to NULL, 3 values are always returned:
214  * the mean on all ranks (rounded to the closest integer), the minimum,
215  * and the maximum value respectively.
216  *
217  * In serial mode, the mean, minimum, and maximum will be identical for most
218  * fields, but all 3 values are returned nonetheless.
219  *
220  * Note that the final memory use is only relative to the final search
221  * structure, and the comparison of the total (or average) with the minima
222  * and maxima may give an indication on load balancing.
223
224  * The mem_required field only takes into account the theoretical maximum
225  * memory footprint of the main search structure during its construction phase,
226  * and of that of temporary structures before load balancing in parallel mode,
227  * but does not include minor work arrays or buffers used during the algorithm.
228  *
229  * Neither of the 2 memory fields include the footprint of the arrays
230  * containing the query results.
231  *
232  * parameters:
233  * n <-- pointer to neighborhood management structure
234  * depth --> tree depth (max level used)
235  * n_leaves --> number of leaves in the tree
236  * n_boxes --> number of boxes in the tree
237  * n_threshold_leaves --> number of leaves where n_boxes > threshold
238  * n_leaf_boxes --> number of boxes for a leaf
239  * mem_final --> theoretical memory for final search structure
240  * mem_required --> theoretical maximum memory for main structures
241  * used during the algorithm
242  *
243  * returns:
244  * the spatial dimension associated with the box tree layout (3, 2, or 1)
245  *----------------------------------------------------------------------------*/
246
247 int
249  int depth[3],
250  cs_lnum_t n_leaves[3],
251  cs_lnum_t n_boxes[3],
252  cs_lnum_t n_threshold_leaves[3],
253  cs_lnum_t n_leaf_boxes[3],
254  size_t mem_final[3],
255  size_t mem_required[3]);
256
257 /*----------------------------------------------------------------------------
258  * Return timing information.
259  *
260  * parameters:
261  * n <-- pointer to neighborhood management structure
262  * build_wtime --> initialization Wall-clock time (or NULL)
263  * build_cpu_time --> initialization CPU time (or NULL)
264  * query_wtime --> query Wall-clock time (or NULL)
265  * query_cpu_time --> query CPU time (or NULL)
266  *----------------------------------------------------------------------------*/
267
268 void
270  double *build_wtime,
271  double *build_cpu_time,
272  double *query_wtime,
273  double *query_cpu_time);
274
275 /*----------------------------------------------------------------------------
276  * Dump a neighborhood management structure.
277  *
278  * parameters:
279  * n <-- pointer to neighborhood management structure
280  *----------------------------------------------------------------------------*/
281
282 void
284
285 /*----------------------------------------------------------------------------*/
286
288
289 #endif /* __FVM_NEIGHBORHOOD_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
void fvm_neighborhood_get_data(const fvm_neighborhood_t *n, cs_lnum_t *n_elts, cs_gnum_t **const elt_num, cs_lnum_t **const neighbor_index, cs_gnum_t **const neighbor_num)
Definition: fvm_neighborhood.c:738
Definition: fvm_neighborhood.h:50
int fvm_neighborhood_get_box_stats(const fvm_neighborhood_t *n, int depth[3], cs_lnum_t n_leaves[3], cs_lnum_t n_boxes[3], cs_lnum_t n_threshold_leaves[3], cs_lnum_t n_leaf_boxes[3], size_t mem_final[3], size_t mem_required[3])
Definition: fvm_neighborhood.c:1088
void fvm_neighborhood_set_options(fvm_neighborhood_t *n, int max_tree_depth, int leaf_threshold, float max_box_ratio, float max_box_ratio_distrib)
Definition: fvm_neighborhood.c:706
fvm_neighborhood_t * fvm_neighborhood_create(void)
Definition: fvm_neighborhood.c:618
void fvm_neighborhood_destroy(fvm_neighborhood_t **n)
Definition: fvm_neighborhood.c:675
void fvm_neighborhood_prune(fvm_neighborhood_t *n)
Definition: fvm_neighborhood.c:1003
void fvm_neighborhood_get_times(const fvm_neighborhood_t *n, double *build_wtime, double *build_cpu_time, double *query_wtime, double *query_cpu_time)
Definition: fvm_neighborhood.c:1140
double cs_coord_t
Definition: cs_defs.h:320
Definition: cs_defs.h:316
void fvm_neighborhood_transfer_data(fvm_neighborhood_t *n, cs_lnum_t *n_elts, cs_gnum_t **elt_num, cs_lnum_t **neighbor_index, cs_gnum_t **neighbor_num)
Definition: fvm_neighborhood.c:779
void fvm_neighborhood_dump(const fvm_neighborhood_t *n)
Definition: fvm_neighborhood.c:1168
void fvm_neighborhood_by_boxes(fvm_neighborhood_t *n, int dim, cs_lnum_t n_boxes, const cs_gnum_t *box_gnum, const cs_coord_t *extents, cs_gnum_t **box_gnum_assigned, cs_coord_t **extents_assigned)
Definition: fvm_neighborhood.c:836
