1 #ifndef __FVM_IO_NUM_H__ 2 #define __FVM_IO_NUM_H__ 120 const size_t n_entities,
121 const int share_parent_global);
144 int share_parent_global);
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
fvm_io_num_t * fvm_io_num_create_from_scan(size_t n_entities)
Definition: fvm_io_num.c:2631
cs_gnum_t fvm_io_num_global_sub_size(const fvm_io_num_t *this_io_num, const cs_lnum_t n_sub_entities[])
Definition: fvm_io_num.c:2793
fvm_io_num_t * fvm_io_num_create_from_select(const cs_lnum_t parent_entity_id[], const cs_gnum_t parent_global_number[], size_t n_entities, int share_parent_global)
Definition: fvm_io_num.c:1971
cs_gnum_t fvm_io_num_get_global_count(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2752
fvm_io_num_sfc_t
Definition: fvm_io_num.h:76
double cs_coord_t
Definition: cs_defs.h:320
Definition: cs_defs.h:322
void fvm_io_num_dump(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2838
fvm_io_num_t * fvm_io_num_create_shared(const cs_gnum_t global_number[], cs_gnum_t global_count, size_t n_entities)
Definition: fvm_io_num.c:2074
fvm_io_num_t * fvm_io_num_create_from_adj_s(const cs_lnum_t parent_entity_id[], const cs_gnum_t adjacency[], size_t n_entities, size_t stride)
Definition: fvm_io_num.c:2174
fvm_io_num_t * fvm_io_num_create_from_real(const cs_real_t val[], size_t n_entities)
Definition: fvm_io_num.c:2435
fvm_io_num_t * fvm_io_num_destroy(fvm_io_num_t *this_io_num)
Definition: fvm_io_num.c:2688
const char * fvm_io_num_sfc_type_name[]
Definition: fvm_io_num.h:80
fvm_io_num_t * fvm_io_num_create_from_sfc(const cs_coord_t coords[], int dim, size_t n_entities, fvm_io_num_sfc_t sfc_type)
Definition: fvm_io_num.c:2391
Definition: fvm_io_num.h:78
Definition: cs_defs.h:316
fvm_io_num_t * fvm_io_num_create_from_sub(const fvm_io_num_t *base_io_num, const cs_lnum_t n_sub_entities[])
Definition: fvm_io_num.c:2109
struct _fvm_io_num_t fvm_io_num_t
Definition: fvm_io_num.h:72
fvm_io_num_t * fvm_io_num_create_from_adj_i(const cs_lnum_t parent_entity_id[], const cs_lnum_t index[], const cs_gnum_t adjacency[], cs_lnum_t n_entities)
Definition: fvm_io_num.c:2257
cs_gnum_t * fvm_io_num_transfer_global_num(fvm_io_num_t *this_io_num)
Definition: fvm_io_num.c:2709
const cs_gnum_t * fvm_io_num_get_global_num(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2771
cs_lnum_t fvm_io_num_get_local_count(const fvm_io_num_t *const this_io_num)
Definition: fvm_io_num.c:2733
fvm_io_num_t * fvm_io_num_create(const cs_lnum_t parent_entity_number[], const cs_gnum_t parent_global_number[], const size_t n_entities, const int share_parent_global)
Definition: fvm_io_num.c:1929
Definition: fvm_io_num.h:81
Definition: fvm_io_num.h:79
