What if a calculation fails ?
The first things to do in case of a failure of the calculation are the following:
- First of all, check for messages in the terminal from which the code was launched, or if run under a batch system, in the job error and/or standard output files.
- These should either contain messages explaining the error, or (most often) indicate which other files should be checked for detailed messages.
- For example, when errors such as out of bounds arrays accesses are detected by the Fortran runtime, they will appear here instead before the code_saturne error detection and logging mechanism can catch them.
- If errors occur when importing a mesh, the file to check will be the
preprocessor.log
- If they occur during the computation, browse the indicated log files (especially
run_solver.log
) and error files if present (error*
- In general, the content of the main
error
file is also present at the end of the run_solver.log
file.
- For parallel runs, if
error_r*
files are present, they may contain more useful information than the main error
file or run_solver.log
When a fatal error occurs on a given MPI rank p, the matching process waits for a few seconds before generating an error_r
_p_ file and interrupting the whole computation (by calling MPI_Abort
), except for rank 0; which generates an error_r
file immediately.
So if no error had occurred on rank 0, it will simply report that is has been interrupted by the environment (initiated by the process generating the error), and the useful information will be in that rank's error file. If the initial error also occurs on rank 0 (such as an incorrect setting being detected), the only error file generated will be error
, for better readability.
This approach was chosen so as to try to generate as few as possible redundant error_r*
files, while still assuming that in the worst case, it is preferable to have extra error files than not have the required ones (for example if the delay is not adapted to a given machine).
- In most cases, the
error_r*
files should contain a stack trace, indicating at least approximately where the error occurred, and what type of error occurred.
- In some cases (such as incorrect boundary condition definitions), a postprocessing output (
postprocessing/error*
) output may be generated, so as to allow vissualization of the error location.
- Check that the version of the code is the expected one and that it is effectively accessible on the machine.
- Simplify the case: remove as many user-defined functions as possible to better identify the source of the failure (for example, the simulation should be checked with constant physical properties before applying variable values).
- If the code has not been used on this computer before, and errors seem to be related to the system, the case should be transferred to a machine that the user is more familiar with so as to avoid any cause associated with the operating system or with the installation of the code.
When the computation starts to run but diverges
If the computation starts to run but diverges, the following points should be checked:
- If a runaway (.i.e. diverging) computation error is reported, the code crashes at the first iteration, or field values in the log seem unexpected, increase the level of verbosity for the resolution of the various equations (in the GUI, in the Numerical parameters/Equation parameters section, and re-run the case. This should provide more info on convergence an possibly help identify the source of the problem.
- Check the Courant number in the logs. If it is significantly higher than 1, and increases from one time step to the next, reducing the time step value (or reference time step) may help.
- Check that the initial state is “reasonable”: it is not essential to prescribe an initial solution close to the solution that is searched for, however an non-physical initial estimate of the solution may lead to a failure of the computation.
- For example: initial velocity oriented in the opposite direction, initial turbulent variables incoherent between each other, too large initial density gradients, ...).
- Some difficulties can be associated with the choice of the initial state (they are normally characterized by a transient that can be evacuated through the outlet of the domain by setting a time step value corresponding to a large Courant number during the first few time steps (for example: the standard value of the time step may be multiplied by a factor of 10).
- If one suspects a difficulty associated with the mesh quality, or with meshes with strong non-orthogonality (such as tetrahedral meshes), one may use the gradient computations based on least-squared with extended cell neighbors (at least opposite adjacent cell centers).
- The most robust (but most costly) option is to use the full extended cell neighbors.
- Using a Green-Gauss based gradient (iterative or with least-squares based face values) is usually preferred, but pure least-squared gradients usually exhibit smoother behavior (better respecting th maximum principle) and may be more robust.
- With tetrahedral meshes, extruding the mesh to obtain at least one layer of prisms at the outlet, or using an imposed pressure outlet rather than a free outlet condition can improve behavior.
The following steps may also be taken if the above are not sufficient to solve the issue:
- If one observes oscillations on the advected variables, it is advised to modify the convective scheme (in the worst, most unstable case, a first-order upwind scheme should be used for all the advected variables).
- If one observes that the pressure iterative solver takes a long time to converge or that overshoots of the velocity occur locally where the quality of the mesh may be questionable, it is advised to under-relax the pressure increments (using 0.7 for the relaxation of pressure increase for example).
- If one observes that the convergence is difficult on a low quality mesh, the stability of a RANS computation with a turbulent viscosity model (k-epsilon et k-omega) may be improved by switching off the flux reconstruction for turbulence variables (k, epsilon, or omega).
- If spurious velocities appear in a region where the pressure gradient is discontinuous because of the presence of a stratification or of a head loss zone, make sure the "improved pressure interpolation" option (
iphydr = 1
) is used (it is activated by default).
Safe mode parameters
An example of a “safe mode” set of parameters is provided hereafter: with this choice, the priority is given to robustness and low computational cost over accuracy:
- Turbulence model: k-epsilon with linear production.
- Convective scheme: SOLU for the velocity, UPWIND for the turbulence and the scalars.
- No flux reconstruction for the turbulence variables (k and epsilon).
- Threshold for the convergence of the iterative solvers: 10-5.
- Least-squares gradient reconstruction with extended neighborhood.
- Pressure increments under-relaxation (0.7 instead of 1).
If the computation runs correctly with these options but not with default options, improving the mesh quality at least locally may be necessary to enable running with default, "higher-precision" options.
Some users also report success initializing a computation with “safe” options (also deactivating flux reconstruction an using an upwind convective scheme for all variables), and restoring the higher precision options progressively after 50 or more iterations.
