1 #ifndef __CS_TURBULENCE_BC_H__ 2 #define __CS_TURBULENCE_BC_H__ Definition: cs_field_pointer.h:70
void cs_turbulence_model_init_bc_ids(void)
Initialize turbulence model boundary condition ids.
Definition: cs_turbulence_bc.c:688
void cs_turbulence_bc_inlet_hyd_diam(cs_lnum_t face_id, double uref2, double dh, double rho, double mu, double *rcodcl)
Definition: cs_turbulence_bc.c:913
double precision, dimension(ncharm), save alpha
Definition: cpincl.f90:99
void cs_turbulence_bc_rij_transform(int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[6][6])
Compute matrix used in the computation of the Reynolds stress tensor boundary conditions.
Definition: cs_turbulence_bc.c:1064
Definition: cs_defs.h:322
void cs_turbulence_bc_inlet_k_eps(cs_lnum_t face_id, double k, double eps, double *rcodcl)
Set inlet boundary condition values for turbulence variables based on given k and epsilon values...
Definition: cs_turbulence_bc.c:969
double precision, dimension(nozppm), save dh
hydraulic diameter
Definition: ppincl.f90:756
void cs_turbulence_bc_set_uninit_inlet_k_eps(cs_lnum_t face_id, double k, double eps, double vel_dir[], double shear_dir[], double *rcodcl)
Set inlet boundary condition values for turbulence variables based on given k and epsilon values only...
Definition: cs_turbulence_bc.c:993
void cs_turbulence_bc_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh, double *rcodcl)
Set inlet boundary condition values for turbulence variables based on a diameter , a turbulent intensity and the reference velocity for a circular duct flow with smooth wall.
Definition: cs_turbulence_bc.c:943
void cs_turbulence_bc_ke_turb_intensity(double uref2, double t_intensity, double dh, double *k, double *eps)
Calculation of and from a diameter , a turbulent intensity and the reference velocity for a circu...
Definition: cs_turbulence_bc.c:868
Definition: cs_defs.h:316
void cs_turbulence_model_free_bc_ids(void)
Free memory allocations for turbulence boundary conditions ids.
Definition: cs_turbulence_bc.c:782
Definition: cs_field_pointer.h:103
Definition: cs_field_pointer.h:71
void cs_turbulence_bc_ke_hyd_diam(double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps)
Calculation of , and from a diameter and the reference velocity for a circular duct flow with smo...
Definition: cs_turbulence_bc.c:836
