7.1
cs_sort_partition.h
1 #ifndef __FVM_SORT_PARTITION_H__
2 #define __FVM_SORT_PARTITION_H__
5  * Data partitioning for parallel sort or order operations.
30 #include "cs_defs.h"
36 #include <stdio.h>
39  * Local headers
42 #include "cs_defs.h"
44 /*----------------------------------------------------------------------------*/
45
49  * Macro and type definitions
51
65 /*----------------------------------------------------------------------------*/
66
67 typedef void
69  void *elt,
70  const void *input);
71
88 /*----------------------------------------------------------------------------*/
89
90 typedef int
91 (cs_sort_partition_compare_t) (const void *elt1,
92  const void *elt2,
93  const void *input);
94
95 /*============================================================================
96  * Public function definitions
97  *============================================================================*/
98
99 #if defined(HAVE_MPI)
100
101 /*----------------------------------------------------------------------------*/
119 /*----------------------------------------------------------------------------*/
120
121 void
123  size_t elt_size,
124  cs_lnum_t n_elts,
125  const void *elts,
126  const cs_lnum_t *weight,
127  const cs_lnum_t order[],
128  int dest_rank_id[],
131  const void *f_input,
132  MPI_Comm comm);
133
134 #endif /* if HAVE_MPI */
135
136 /*----------------------------------------------------------------------------*/
137
139
140 #endif /* __FVM_SORT_PARTITION_H__ */
int() cs_sort_partition_compare_t(const void *elt1, const void *elt2, const void *input)
function pointer for comparison of 2 elements.
Definition: cs_sort_partition.h:91
Definition: cs_defs.h:316
void cs_sort_partition_dest_rank_id(cs_lnum_t sampling_factor, size_t elt_size, cs_lnum_t n_elts, const void *elts, const cs_lnum_t *weight, const cs_lnum_t order[], int dest_rank_id[], cs_sort_partition_s_to_elt_t s_to_elt, cs_sort_partition_compare_t compare, const void *f_input, MPI_Comm comm)
Determine to which rank data elements should be sent for parallel sorting or ordering.
Definition: cs_sort_partition.c:722
void() cs_sort_partition_s_to_elt_t(double s, void *elt, const void *input)
function pointer for conversion of a double precision value in range [0, 1] to a given element...
Definition: cs_sort_partition.h:68
