7.1
cs_pressure_correction.h
1 #ifndef __CS_PRESSURE_CORRECTION_H__
2 #define __CS_PRESSURE_CORRECTION_H__
5  * Pressure correction.
31  * Local headers
34 #include "cs_defs.h"
41  * Public function definitions
44 /*----------------------------------------------------------------------------*/
99 /*----------------------------------------------------------------------------*/
100
101 void
102 cs_pressure_correction(int iterns,
105  cs_lnum_t ifbpcd[nfbpcd],
106  cs_lnum_t ltmast[],
107  int isostd[],
108  cs_real_t vel[restrict][3],
109  cs_real_t da_uu[restrict][6],
110  cs_real_t coefav[restrict][3],
111  cs_real_t coefbv[restrict][3][3],
112  cs_real_t coefa_dp[restrict],
113  cs_real_t coefb_dp[restrict],
114  cs_real_t spcond[restrict],
115  cs_real_t svcond[restrict],
116  cs_real_t frcxt[restrict][3],
117  cs_real_t dfrcxt[restrict][3],
118  cs_real_t i_visc[restrict],
119  cs_real_t b_visc[restrict]);
120
121 /*----------------------------------------------------------------------------*/
122
124
125 #endif /* __CS_PRESSURE_CORRECTION_H__ */
double precision, dimension(:,:), allocatable spcond
value of the condensation source terms for pressure. For the other variables, eventual imposed specif...
Definition: pointe.f90:226
#define restrict
Definition: cs_defs.h:142
integer, save ncmast
number of the ncmast cells in which a condensation source terms is imposed. See lstmast list and the ...
Definition: pointe.f90:248
void cs_pressure_correction(int iterns, cs_lnum_t nfbpcd, cs_lnum_t ncmast, cs_lnum_t ifbpcd[nfbpcd], cs_lnum_t ltmast[], int isostd[], cs_real_t vel[restrict][3], cs_real_t da_uu[restrict][6], cs_real_t coefav[restrict][3], cs_real_t coefbv[restrict][3][3], cs_real_t coefa_dp[restrict], cs_real_t coefb_dp[restrict], cs_real_t spcond[restrict], cs_real_t svcond[restrict], cs_real_t frcxt[restrict][3], cs_real_t dfrcxt[restrict][3], cs_real_t i_visc[restrict], cs_real_t b_visc[restrict])
Perform the pressure correction step of the Navier-Stokes equations for incompressible or slightly co...
Definition: cs_pressure_correction.c:164
integer, dimension(:), allocatable ltmast
list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_...
Definition: pointe.f90:252
integer, save nfbpcd
number of the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user s...
Definition: pointe.f90:208
Definition: cs_defs.h:322
double precision, dimension(:,:), allocatable svcond
value of the condensation source terms for pressure associated to the metal structures modelling...
Definition: pointe.f90:268
integer, dimension(:), allocatable ifbpcd
list on the nfbpcd faces in which a condensation source terms is imposed. See ifbpcd and the user sub...
Definition: pointe.f90:212
Definition: cs_defs.h:316
