1 #ifndef __CS_PHYSICAL_PROPERTIES_H__ 2 #define __CS_PHYSICAL_PROPERTIES_H__ 81 const char *reference,
Definition: cs_physical_properties.h:57
Definition: cs_physical_properties.h:61
void cs_physical_property_create(const char *name, const int dim, const cs_real_t refval)
Create a physical property.
Definition: cs_physical_properties.c:967
cs_phys_prop_type_t
Definition: cs_physical_properties.h:52
void cs_thermal_table_set(const char *material, const char *method, const char *reference, cs_phys_prop_thermo_plane_type_t thermo_plane, int temp_scale)
Define thermal table.
Definition: cs_physical_properties.c:301
Definition: cs_physical_properties.h:45
void cs_physical_property_get_zone_values(const char *name, const char *zname, cs_real_t retval[])
Get property reference values for a given zone.
Definition: cs_physical_properties.c:914
void cs_phys_prop_compute(cs_phys_prop_type_t property, cs_lnum_t n_vals, cs_lnum_t var1_stride, cs_lnum_t var2_stride, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Compute a physical property.
Definition: cs_physical_properties.c:435
Definition: cs_physical_properties.h:59
void cs_physical_property_define_from_value(const char *name, const char *zname, const int dim, const cs_real_t val)
Add a property definition on a given zone using a single value.
Definition: cs_physical_properties.c:986
Definition: cs_defs.h:322
Definition: cs_physical_properties.h:63
void cs_physical_property_set_ref_value(const char *name, const cs_real_t val)
Set reference value for a physical property.
Definition: cs_physical_properties.c:891
Definition: cs_physical_properties.h:65
Definition: cs_physical_properties.h:60
Definition: cs_physical_properties.h:40
Definition: cs_physical_properties.h:44
Definition: cs_physical_properties.h:56
Definition: cs_physical_properties.h:64
void cs_phys_prop_freesteam(cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, const cs_real_t var1[], const cs_real_t var2[], cs_real_t val[])
Compute properties with Freesteam in a defined thermal plane.
Definition: cs_physical_properties.c:542
Definition: cs_defs.h:316
Definition: cs_physical_properties.h:62
void cs_physical_property_update_zone_values(const char *name, const char *zname, const cs_real_t vals[])
Update reference values for a property on a given zone.
Definition: cs_physical_properties.c:1113
cs_real_t cs_physical_property_get_ref_value(const char *name)
Get reference value of a physical property.
Definition: cs_physical_properties.c:867
Definition: cs_physical_properties.h:46
int cs_physical_property_field_id_by_name(const char *name)
Return id of field associated to property.
Definition: cs_physical_properties.c:1090
void cs_physical_property_define_from_field(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Add a property definition based on a cs_field_t.
Definition: cs_physical_properties.c:1062
Definition: cs_physical_properties.h:43
Definition: cs_physical_properties.h:48
void cs_physical_property_define_from_values(const char *name, const char *zname, const int dim, cs_real_t vals[])
Add a property multi-diemnsional definition on a given zone.
Definition: cs_physical_properties.c:1025
Definition: cs_physical_properties.h:42
Definition: cs_physical_properties.h:47
void cs_thermal_table_finalize(void)
finalize thermal table.
Definition: cs_physical_properties.c:391
Definition: cs_physical_properties.h:55
Definition: cs_physical_properties.h:66
Definition: cs_physical_properties.h:54
Definition: cs_physical_properties.h:58
