7.1
cs_notebook.h
1 #ifndef __CS_NOTEBOOK_H__
2 #define __CS_NOTEBOOK_H__
5  * Notebook management.
29  * Local headers
32 #include "cs_defs.h"
34 /*----------------------------------------------------------------------------*/
44 void
46
47 /*----------------------------------------------------------------------------*/
56 /*----------------------------------------------------------------------------*/
57
58 int
59 cs_notebook_parameter_is_present(const char *name,
60  int *editable);
61
73
75 cs_notebook_parameter_value_by_name(const char *name);
76
77 /*----------------------------------------------------------------------------*/
86 /*----------------------------------------------------------------------------*/
87
88 void
89 cs_notebook_parameter_set_value(const char *name,
90  cs_real_t val);
91
92 /*----------------------------------------------------------------------------*/
106 /*----------------------------------------------------------------------------*/
107
108 int
110
111 /*----------------------------------------------------------------------------*/
119 /*----------------------------------------------------------------------------*/
120
121 const char *
123
124 /*----------------------------------------------------------------------------*/
130 /*----------------------------------------------------------------------------*/
131
132 void
134
135 /*----------------------------------------------------------------------------*/
139 /*----------------------------------------------------------------------------*/
140
141 void
142 cs_notebook_log(void);
143
144 /*----------------------------------------------------------------------------*/
152 /*----------------------------------------------------------------------------*/
153
154 void
156
157 /*----------------------------------------------------------------------------*/
158
160
161 #endif /* __CS_NOTEBOOK_H__ */
cs_real_t cs_notebook_parameter_value_by_name(const char *name)
Return a parameter value (real).
Definition: cs_notebook.c:397
void cs_notebook_load_from_file(void)
Initialize the notebook object (based on cs_tree_node_t).
Definition: cs_notebook.c:291
const char * cs_notebook_parameter_get_description(char *name)
Returns the description of the parameter (GUI defined).
Definition: cs_notebook.c:462
Definition: cs_defs.h:322
int cs_notebook_parameter_is_present(const char *name, int *editable)
Check if a parameter value is present.
Definition: cs_notebook.c:365
void cs_notebook_log(void)
Output the notebook info to the setup log.
Definition: cs_notebook.c:507
int cs_notebook_parameter_get_openturns_status(char *name)
Indicate whether the parameter is used for a study with openturns.
Definition: cs_notebook.c:445
void cs_notebook_parameter_set_value(const char *name, cs_real_t val)
Set a parameter value (real) for an editable parameter.
Definition: cs_notebook.c:415
void cs_notebook_uncertain_output(void)
Write uncertain values to output file.
Definition: cs_notebook.c:546
void cs_notebook_destroy_all(void)
Destroy the notebook structure.
Definition: cs_notebook.c:477
