7.1
cs_medcoupling_remapper.h
1 #ifndef __CS_MEDCOUPLING_REMAPPER_HXX__
2 #define __CS_MEDCOUPLING_REMAPPER_HXX__
5  * Interpolation using MEDCoupling Remapper.
35  * MED library headers
41  * Structure definitions
44 typedef struct _cs_medcoupling_remapper_t cs_medcoupling_remapper_t;
45
47  * Public C function prototypes
49
50 /*----------------------------------------------------------------------------*/
58 /*----------------------------------------------------------------------------*/
59
62
63 /* -------------------------------------------------------------------------- */
71 /*----------------------------------------------------------------------------*/
72
74 cs_medcoupling_remapper_by_name_try(const char *name);
75
76 /*----------------------------------------------------------------------------*/
91 /*----------------------------------------------------------------------------*/
92
93 int
94 cs_medcoupling_remapper_initialize(const char *name,
95  int elt_dim,
96  const char *select_criteria,
97  const char *medfile_path,
98  int n_fields,
99  const char **field_names,
100  int iteration,
101  int order);
102
103 /*----------------------------------------------------------------------------*/
111 /*----------------------------------------------------------------------------*/
112
113 void
115  int iteration,
116  int order);
117
118 /*----------------------------------------------------------------------------*/
132 /*----------------------------------------------------------------------------*/
133
134 void
136  const char key[],
137  const char value[]);
138
139 /*----------------------------------------------------------------------------*/
145 /*----------------------------------------------------------------------------*/
146
147 void
149
150 /*----------------------------------------------------------------------------*/
162 /*----------------------------------------------------------------------------*/
163
164 cs_real_t *
166  int field_id,
167  double default_val);
168
169 /*----------------------------------------------------------------------------*/
176 /*----------------------------------------------------------------------------*/
177
178 void
180  cs_real_t translation[3]);
181
182 /*----------------------------------------------------------------------------*/
191 /*----------------------------------------------------------------------------*/
192
193 void
195  cs_real_t invariant[3],
196  cs_real_t axis[3],
197  cs_real_t angle);
198
199 /*----------------------------------------------------------------------------*/
212 /*----------------------------------------------------------------------------*/
213
214 void
216  cs_real_t t,
217  int *id1,
218  int *id2);
219
220 /*----------------------------------------------------------------------------*/
232 /*----------------------------------------------------------------------------*/
233
234 void
236  int id,
237  cs_real_t *t);
238
239 /*----------------------------------------------------------------------------*/
253
254 void
256  int id,
257  int *it,
258  int *order);
259
260 /*----------------------------------------------------------------------------*/
266 /*----------------------------------------------------------------------------*/
267
268 void
270  int id);
271 /*----------------------------------------------------------------------------*/
275 /*----------------------------------------------------------------------------*/
276
277 void
279
280 /*----------------------------------------------------------------------------*/
281
283
284 #endif /* __CS_MEDCOUPLING_REMAPPER_HXX__ */
void cs_medcoupling_remapper_get_iter_order_from_index(cs_medcoupling_remapper_t *r, int id, int *it, int *order)
Retrieve the two closest time steps indexes.
Definition: cs_medcoupling_remapper.cxx:1001
cs_medcoupling_remapper_t * cs_medcoupling_remapper_by_name_try(const char *name)
get a remapper by its name
Definition: cs_medcoupling_remapper.cxx:619
Definition: cs_medcoupling_remapper.h:44
void cs_medcoupling_remapper_translate(cs_medcoupling_remapper_t *r, cs_real_t translation[3])
translate the mesh using a given vector
Definition: cs_medcoupling_remapper.cxx:869
void cs_medcoupling_remapper_set_options(cs_medcoupling_remapper_t *r, const char key[], const char value[])
set non-default options for a remapper
Definition: cs_medcoupling_remapper.cxx:733
void cs_medcoupling_remapper_update_time_value(cs_medcoupling_remapper_t *r, int id)
Load the time value corresponding to id.
Definition: cs_medcoupling_remapper.cxx:1040
void cs_medcoupling_remapper_set_iteration(cs_medcoupling_remapper_t *r, int iteration, int order)
set and load a given time iteration from the MED file
Definition: cs_medcoupling_remapper.cxx:698
Definition: cs_defs.h:322
void cs_medcoupling_remapper_find_time_index(cs_medcoupling_remapper_t *r, cs_real_t t, int *id1, int *id2)
Definition: cs_medcoupling_remapper.cxx:927
void cs_medcoupling_remapper_rotate(cs_medcoupling_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
Rotate the mesh using a center point, axis and angle.
Definition: cs_medcoupling_remapper.cxx:895
cs_real_t * cs_medcoupling_remapper_copy_values(cs_medcoupling_remapper_t *r, int field_id, double default_val)
Interpolate values for a given field.
Definition: cs_medcoupling_remapper.cxx:838
void cs_medcoupling_remapper_destroy_all(void)
Destroy all remappers.
Definition: cs_medcoupling_remapper.cxx:1023
void cs_medcoupling_remapper_setup(cs_medcoupling_remapper_t *r)
update the interpolation matrix of the remapper
Definition: cs_medcoupling_remapper.cxx:795
int cs_medcoupling_remapper_initialize(const char *name, int elt_dim, const char *select_criteria, const char *medfile_path, int n_fields, const char **field_names, int iteration, int order)
initialize a remapper based on a set of given arguments
Definition: cs_medcoupling_remapper.cxx:658
cs_medcoupling_remapper_t * cs_medcoupling_remapper_by_id(int r_id)
get a remapper by its id
Definition: cs_medcoupling_remapper.cxx:592
void cs_medcoupling_remapper_get_time_from_index(cs_medcoupling_remapper_t *r, int id, cs_real_t *t)
Definition: cs_medcoupling_remapper.cxx:972
