7.1
cs_matrix_priv.h
1 #ifndef __CS_MATRIX_PRIV_H__
2 #define __CS_MATRIX_PRIV_H__
5  * Private types for sparse matrix representation and operations.
31  * Local headers
34 #include "cs_defs.h"
36 #include "cs_matrix.h"
45  * Macro definitions
49  * Type definitions
51
52 /* Formats currently supported:
53  *
54  * - Native
55  * - Compressed Sparse Row (CSR)
56  * - Modified Compressed Sparse Row (MSR), with separate diagonal
57  */
58
59 /*----------------------------------------------------------------------------
60  * Function pointer types
61  *----------------------------------------------------------------------------*/
62
63 typedef void
64 (cs_matrix_set_coeffs_t) (cs_matrix_t *matrix,
65  bool symmetric,
66  bool copy,
67  cs_lnum_t n_edges,
68  const cs_lnum_2_t *restrict edges,
69  const cs_real_t *restrict da,
70  const cs_real_t *restrict xa);
71
72 typedef void
73 (cs_matrix_release_coeffs_t) (cs_matrix_t *matrix);
74
75 typedef void
76 (cs_matrix_destroy_struct_t) (void **ms);
77
78 typedef void
79 (cs_matrix_destroy_coeffs_t) (cs_matrix_t *matrix);
80
81 typedef void
82 (cs_matrix_copy_diagonal_t) (const cs_matrix_t *matrix,
83  cs_real_t *restrict da);
84
85 typedef const cs_real_t *
86 (cs_matrix_get_diagonal_t)(const cs_matrix_t *matrix);
87
89 (cs_matrix_assembler_values_create_t) (cs_matrix_t *matrix,
90  const cs_lnum_t *diag_block_size,
91  const cs_lnum_t *extra_diag_block_size);
92
93 /*----------------------------------------------------------------------------
94  * Function pointer for matrix-veector product (y = A.x).
95  *
96  * parameters:
97  * matrix <-- pointer to matrix structure
98  * exclude_diag <-- if true, compute (A-D).x instead of A.x
99  * sync <-- if true, synchronize ghost values
100  * x <-- x input vector (may be synchronized by this function)
101  * y <-- y output vector
102  *----------------------------------------------------------------------------*/
103
104 typedef void
105 (cs_matrix_vector_product_t) (const cs_matrix_t *matrix,
106  bool exclude_diag,
107  bool sync,
108  cs_real_t *restrict x,
109  cs_real_t *restrict y);
110
111 /*----------------------------------------------------------------------------
112  * Matrix types
113  *----------------------------------------------------------------------------*/
114
115 /* Native matrix structure representation */
116 /*----------------------------------------*/
117
118 /* Note: the members of this structure are already available through the top
119  * matrix structure, but are replicated here in case of future removal
120  * from the top structure (which would require computation/assignment of
121  * matrix coefficients in another form) */
122
123 typedef struct _cs_matrix_struct_native_t {
124
125  cs_lnum_t n_rows; /* Local number of rows */
126  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
127  cs_lnum_t n_edges; /* Local number of graph edges
128  (for extra-diagonal terms) */
129
130  /* Pointers to shared arrays */
131
132  const cs_lnum_2_t *edges; /* Edges (symmetric row <-> column)
133  connectivity */
134
135 } cs_matrix_struct_native_t;
136
137 /* Native matrix coefficients */
138 /*----------------------------*/
139
140 typedef struct _cs_matrix_coeff_native_t {
141
142  bool symmetric; /* Symmetry indicator */
143  int max_db_size; /* Current max allocated diag block size */
144  int max_eb_size; /* Current max allocated extradiag block size */
145
146  /* Pointers to possibly shared arrays */
147
148  const cs_real_t *da; /* Diagonal terms */
149  const cs_real_t *xa; /* Extra-diagonal terms */
150
151  /* Pointers to private arrays (NULL if shared) */
152
153  cs_real_t *_da; /* Diagonal terms */
154  cs_real_t *_xa; /* Extra-diagonal terms */
155
156 } cs_matrix_coeff_native_t;
157
158 /* CSR (Compressed Sparse Row) matrix structure representation */
159 /*-------------------------------------------------------------*/
160
161 typedef struct _cs_matrix_struct_csr_t {
162
163  cs_lnum_t n_rows; /* Local number of rows */
164  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
165
166  /* Pointers to structure arrays and info (row_index, col_id) */
167
168  bool have_diag; /* Has non-zero diagonal */
169  bool direct_assembly; /* True if each value corresponds to
170  a unique face ; false if multiple
171  faces contribute to the same
172  value (i.e. we have split faces) */
173
174  const cs_lnum_t *row_index; /* Pointer to row index (0 to n-1) */
175  const cs_lnum_t *col_id; /* Pointer to column id (0 to n-1) */
176
177  cs_lnum_t *_row_index; /* Row index (0 to n-1), if owner */
178  cs_lnum_t *_col_id; /* Column id (0 to n-1), if owner */
179
180 } cs_matrix_struct_csr_t;
181
182 /* CSR matrix coefficients representation */
183 /*----------------------------------------*/
184
185 typedef struct _cs_matrix_coeff_csr_t {
186
187  /* Pointers to possibly shared arrays */
188
189  const cs_real_t *val; /* Matrix coefficients */
190
191  /* Pointers to private arrays (NULL if shared) */
192
193  cs_real_t *_val; /* Diagonal matrix coefficients */
194
195  /* Pointers to auxiliary arrays used for queries */
196
197  const cs_real_t *d_val; /* Pointer to diagonal matrix
198  coefficients, if queried */
199  cs_real_t *_d_val; /* Diagonal matrix coefficients,
200  if queried */
201
202 } cs_matrix_coeff_csr_t;
203
204 /* MSR matrix coefficients representation */
205 /*----------------------------------------*/
206
207 typedef struct _cs_matrix_coeff_msr_t {
208
209  int max_db_size; /* Current max allocated block size */
210  int max_eb_size; /* Current max allocated extradiag
211  block size */
212
213  /* Pointers to possibly shared arrays */
214
215  const cs_real_t *d_val; /* Diagonal matrix coefficients */
216  const cs_real_t *x_val; /* Extra-diagonal matrix coefficients */
217
218  /* Pointers to private arrays (NULL if shared) */
219
220  cs_real_t *_d_val; /* Diagonal matrix coefficients */
221  cs_real_t *_x_val; /* Extra-diagonal matrix coefficients */
222
223 } cs_matrix_coeff_msr_t;
224
225 /* Matrix structure (representation-independent part) */
226 /*----------------------------------------------------*/
227
228 struct _cs_matrix_structure_t {
229
230  cs_matrix_type_t type; /* Matrix storage and definition type */
231
232  cs_lnum_t n_rows; /* Local number of rows */
233  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
234
235  void *structure; /* Matrix structure */
236
237  /* Pointers to shared arrays from mesh structure
238  (face->cell connectivity for coefficient assignment,
239  local->local cell numbering for future info or renumbering,
240  and halo) */
241
242  const cs_halo_t *halo; /* Parallel or periodic halo */
243  const cs_numbering_t *numbering; /* Vectorization or thread-related
244  numbering information */
245
246  const cs_matrix_assembler_t *assembler; /* Associated matrix assembler */
247 };
248
249 /* Structure associated with Matrix (representation-independent part) */
250 /*--------------------------------------------------------------------*/
251
252 struct _cs_matrix_t {
253
254  cs_matrix_type_t type; /* Matrix storage and definition type */
255
256  const char *type_name; /* Pointer to matrix type name string */
257  const char *type_fname; /* Pointer to matrix type
258  full name string */
259
260  cs_lnum_t n_rows; /* Local number of rows */
261  cs_lnum_t n_cols_ext; /* Local number of columns + ghosts */
262
263  cs_matrix_fill_type_t fill_type; /* Matrix fill type */
264
265  bool symmetric; /* true if coefficients are symmetric */
266
267  cs_lnum_t db_size[4]; /* Diag Block size, including padding:
268  0: useful block size
269  1: vector block extents
270  2: matrix line extents
271  3: matrix line*column extents */
272
273  cs_lnum_t eb_size[4]; /* Extradiag block size, including padding:
274  0: useful block size
275  1: vector block extents
276  2: matrix line extents
277  3: matrix line*column extents */
278
279  /* Pointer to shared structure */
280
281  const void *structure; /* Possibly shared matrix structure */
282  void *_structure; /* Private matrix structure */
283
284  /* Pointers to arrays possibly shared from mesh structure
285  (graph edges: face->cell connectivity for coefficient assignment,
286  rows: local->local cell numbering for future info or renumbering,
287  and halo) */
288
289  const cs_halo_t *halo; /* Parallel or periodic halo */
290  const cs_numbering_t *numbering; /* Vectorization or thread-related
291  numbering information */
292
293  const cs_matrix_assembler_t *assembler; /* Associated matrix assembler */
294
295  /* Pointer to shared arrays from coefficient assignment from
296  "native" type. This should be removed in the future, but requires
297  removing the dependency to the native structure in the multigrid
298  code first. */
299
300  const cs_real_t *xa; /* Extra-diagonal terms */
301
302  /* Pointer to private data */
303
304  void *coeffs; /* Matrix coefficients */
305
306  /* Function pointers */
307
308  cs_matrix_set_coeffs_t *set_coefficients;
309  cs_matrix_release_coeffs_t *release_coefficients;
310  cs_matrix_copy_diagonal_t *copy_diagonal;
311  cs_matrix_get_diagonal_t *get_diagonal;
312
313  cs_matrix_destroy_struct_t *destroy_structure;
314  cs_matrix_destroy_coeffs_t *destroy_coefficients;
315
316  cs_matrix_assembler_values_create_t *assembler_values_create;
317
318  /* Function pointer arrays, with CS_MATRIX_N_FILL_TYPES variants:
319  fill_type*2 + exclude_diagonal_flag */
320
321  cs_matrix_vector_product_t *vector_multiply[CS_MATRIX_N_FILL_TYPES][2];
322
323 };
324
325 /* Structure used for tuning variants */
326 /*------------------------------------*/
327
328 struct _cs_matrix_variant_t {
329
330  char name[2][32]; /* Variant names */
331
332  cs_matrix_type_t type; /* Matrix storage and definition type */
333  cs_matrix_fill_type_t fill_type; /* Matrix storage and definition type */
334
335  /* Function pointer arrays, with and without exclude_diagonal_flag */
336
337  cs_matrix_vector_product_t *vector_multiply[2];
338 };
339
342 /*=============================================================================
343  * Semi-private function prototypes
344  *============================================================================*/
345
346 /*----------------------------------------------------------------------------*/
347
349
350 #endif /* __CS_MATRIX_PRIV_H__ */
#define restrict
Definition: cs_defs.h:142
Definition: cs_matrix.h:83
Definition: cs_halo.h:77
Definition: cs_defs.h:322
Definition: cs_matrix.h:93
cs_matrix_type_t
Definition: cs_matrix.h:55
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:328
Definition: cs_defs.h:316
Definition: cs_numbering.h:83
Definition: cs_matrix.h:70
