7.1
cs_file.h
1 #ifndef __CS_FILE_H__
2 #define __CS_FILE_H__
5  * File and directory operations, with parallel file I/O
30 #if defined(HAVE_MPI)
31 #include <mpi.h>
32 #endif
35  * Local headers
38 #include "cs_defs.h"
45  * Macro definitions
49  * Type definitions
51
52 /* File descriptor */
53
54 typedef struct _cs_file_t cs_file_t;
55
56 /* Helper structure for IO serialization */
57
58 #if defined(HAVE_MPI)
59 typedef struct _cs_file_serializer_t cs_file_serializer_t;
60 #endif
61
62 /* File modes */
63
64 typedef enum {
65
66  CS_FILE_MODE_READ, /* Read mode */
67  CS_FILE_MODE_WRITE, /* Write mode */
68  CS_FILE_MODE_APPEND /* Append mode */
69
71
72 /* Possibilities for the third argument of cs_file_seek() */
73
74 typedef enum {
75
76  CS_FILE_SEEK_SET, /* Seek from beginning of file */
77  CS_FILE_SEEK_CUR, /* Seek from current position */
78  CS_FILE_SEEK_END /* Seek from end of file */
79
81
82 /* File access methods */
83
84 typedef enum {
85
92
94
95 /* MPI-IO file positioning methods */
96
97 typedef enum {
98
101
103
104 /* Offset for file position indicator (int64_t in C99) */
105
106 #if defined(SIZEOF_LONG_LONG)
107 typedef long long cs_file_off_t;
108 #else
109 typedef long cs_file_off_t;
110 #endif
111
112 /*=============================================================================
113  * Global variables
114  *============================================================================*/
115
116 /* names associated with file access methods */
117
118 extern const char *cs_file_access_name[];
119
120 /* names associated with MPI-IO positioning */
121
122 extern const char *cs_file_mpi_positioning_name[];
123
124 /*=============================================================================
125  * Public function prototypes
126  *============================================================================*/
127
128 /*----------------------------------------------------------------------------
129  * Create a file descriptor and open the associated file.
130  *
131  * By default, data is written or read as native data. This behavior may be
132  * modified by cs_file_set_swap_endian().
133  *
134  * parameters:
135  * name <-- file name
136  * mode <-- file access mode: read, write, or append
137  * method <-- file access method
138  * hints <-- associated hints for MPI-IO, or MPI_INFO_NULL
139  * block_comm <-- handle to MPI communicator used for distributed file
140  * block access (may be a subset of comm if some ranks do
141  * not directly access distributed data blocks)
142  * comm <-- handle to main MPI communicator
143  *
144  * returns:
145  * pointer to cs_file_t file descriptor (NULL in case of failure);
146  * currently, errors are fatal.
147  *----------------------------------------------------------------------------*/
148
149 #if defined(HAVE_MPI)
150
151 cs_file_t *
152 cs_file_open(const char *name,
153  cs_file_mode_t mode,
154  cs_file_access_t method,
155  MPI_Info hints,
156  MPI_Comm block_comm,
157  MPI_Comm comm);
158
159 #else
160
161 cs_file_t *
162 cs_file_open(const char *name,
163  cs_file_mode_t mode,
164  cs_file_access_t method);
165
166 #endif
167
168 /*----------------------------------------------------------------------------
169  * Create a file descriptor and open the associated file, using the default
170  * file communicator and access method.
171  *
172  * By default, data is written or read as native data. This behavior may be
173  * modified by cs_file_set_swap_endian().
174  *
175  * parameters:
176  * name <-- file name
177  * mode <-- file access mode: read, write, or append
178  *
179  * returns:
180  * pointer to cs_file_t file descriptor (NULL in case of failure);
181  * currently, errors are fatal.
182  *----------------------------------------------------------------------------*/
183
184 cs_file_t *
185 cs_file_open_default(const char *name,
186  cs_file_mode_t mode);
187
188 /*----------------------------------------------------------------------------*/
202 /*----------------------------------------------------------------------------*/
203
204 cs_file_t *
205 cs_file_open_serial(const char *name,
206  cs_file_mode_t mode);
207
208 /*----------------------------------------------------------------------------
209  * Destroy a file descriptor and close the associated file.
210  *
211  * parameters:
212  * f <-> file descriptor to destroy
213  *
214  * returns:
215  * NULL pointer
216  *----------------------------------------------------------------------------*/
217
218 cs_file_t *
220
221 /*----------------------------------------------------------------------------
222  * Return a file's name.
223  *
224  * parameters:
225  * f <-- cs_file_t descriptor
226  *
227  * returns:
228  * pointer to the file's name.
229  *----------------------------------------------------------------------------*/
230
231 const char *
232 cs_file_get_name(const cs_file_t *f);
233
234 /*----------------------------------------------------------------------------
235  * Ensure that data is read or written in big-endian
236  * (network standard) format.
237  *
238  * parameters:
239  * f <-> cs_file_t descriptor
240  *----------------------------------------------------------------------------*/
241
242 void
244
245 /*----------------------------------------------------------------------------
246  * Return a file's byte-swapping behavior.
247  *
248  * parameters:
249  * f <-- cs_file_t descriptor
250  *
251  * returns:
252  * 0 if file's endianness is the same as the system's, 1 otherwise.
253  *----------------------------------------------------------------------------*/
254
255 int
257
258 /*----------------------------------------------------------------------------
259  * Set a file's byte-swapping behavior.
260  *
261  * Using this function assumes one is familiar with a file's coding
262  * or structure; use with caution.
263  *
264  * parameters:
265  * f <-> cs_file_t descriptor
266  * swap <-- 1 if bytes must be swapped, 0 otherwise
267  *----------------------------------------------------------------------------*/
268
269 void
271  int swap);
272
273 /*----------------------------------------------------------------------------
274  * Read global data from a file, distributing it to all processes
275  * associated with that file.
276  *
277  * parameters:
278  * f <-- cs_file_t descriptor
279  * buf --> pointer to location receiving data
280  * size <-- size of each item of data in bytes
281  * ni <-- number of items to read
282  *
283  * returns:
284  * the number of items (not bytes) sucessfully read; currently,
285  * errors are fatal.
286  *----------------------------------------------------------------------------*/
287
288 size_t
290  void *buf,
291  size_t size,
292  size_t ni);
293
294 /*----------------------------------------------------------------------------
295  * Write global data to a file.
296  *
297  * Under MPI, data is only written by the associated communicator's root
298  * rank. The buffers on other ranks are ignored, though the file offset
299  * is updated (i.e. the call to this function is collective).
300  *
301  * parameters:
302  * f <-- cs_file_t descriptor
303  * buf <-- pointer to location containing data
304  * size <-- size of each item of data in bytes
305  * ni <-- number of items to read
306  *
307  * returns:
308  * the number of items (not bytes) sucessfully written; currently,
309  * errors are fatal.
310  *----------------------------------------------------------------------------*/
311
312 size_t
314  const void *buf,
315  size_t size,
316  size_t ni);
317
318 /*----------------------------------------------------------------------------
319  * Read data to a buffer, distributing a contiguous part of it to each
320  * process associated with a file.
321  *
322  * Each process should receive a (possibly empty) block of the data,
323  * and we should have:
324  * global_num_start at rank 0 = 1
325  * global_num_start at rank i+1 = global_num_end at rank i.
326  * Otherwise, behavior (especially positioning for future reads) is undefined.
327  *
328  * parameters:
329  * f <-- cs_file_t descriptor
330  * buf --> pointer to location receiving data
331  * size <-- size of each item of data in bytes
332  * stride <-- number of (interlaced) values per block item
333  * global_num_start <-- global number of first block item (1 to n numbering)
334  * global_num_end <-- global number of past-the end block item
335  * (1 to n numbering)
336  *
337  * returns:
338  * the (local) number of items (not bytes) sucessfully read; currently,
339  * errors are fatal.
340  *----------------------------------------------------------------------------*/
341
342 size_t
344  void *buf,
345  size_t size,
346  size_t stride,
347  cs_gnum_t global_num_start,
348  cs_gnum_t global_num_end);
349
350 /*----------------------------------------------------------------------------
351  * Write data to a file, each associated process providing a contiguous part
352  * of this data.
353  *
354  * Each process should provide a (possibly empty) block of the data,
355  * and we should have:
356  * global_num_start at rank 0 = 1
357  * global_num_start at rank i+1 = global_num_end at rank i.
358  * Otherwise, behavior (especially positioning for future reads) is undefined.
359  *
360  * This function may require an internal copy of the data to ensure that
361  * the buffer contents are not modified, so if the buffer contents are
362  * temporary values, to be deleted after writing, using
363  * cs_file_write_block_buffer() instead may be used to avoid an unneeded
364  * memory allocation and copy.
365  *
366  * parameters:
367  * f <-- cs_file_t descriptor
368  * buf <-- pointer to location containing data
369  * size <-- size of each item of data in bytes
370  * stride <-- number of (interlaced) values per block item
371  * global_num_start <-- global number of first block item (1 to n numbering)
372  * global_num_end <-- global number of past-the end block item
373  * (1 to n numbering)
374  *
375  * returns:
376  * the (local) number of items (not bytes) sucessfully written; currently,
377  * errors are fatal.
378  *----------------------------------------------------------------------------*/
379
380 size_t
382  const void *buf,
383  size_t size,
384  size_t stride,
385  cs_gnum_t global_num_start,
386  cs_gnum_t global_num_end);
387
388 /*----------------------------------------------------------------------------
389  * Write data to a file, each associated process providing a contiguous part
390  * of this data.
391  *
392  * Each process should provide a (possibly empty) block of the data,
393  * and we should have:
394  * global_num_start at rank 0 = 1
395  * global_num_start at rank i+1 = global_num_end at rank i.
396  * Otherwise, behavior (especially positioning for future reads) is undefined.
397  *
398  * This function is intended to be used mainly data that is already a
399  * copy of original data (such as data that has been redistributed across
400  * processors just for the sake of output), or that is to be deleted after
401  * writing, so it may modify the values in its input buffer (notably to
402  * convert from little-endian to big-endian of vice-versa if necessary).
403  *
404  * parameters:
405  * f <-- cs_file_t descriptor
406  * buf <-> pointer to location containing data
407  * size <-- size of each item of data in bytes
408  * stride <-- number of (interlaced) values per block item
409  * global_num_start <-- global number of first block item (1 to n numbering)
410  * global_num_end <-- global number of past-the end block item
411  * (1 to n numbering)
412  *
413  * returns:
414  * the (local) number of items (not bytes) sucessfully written; currently,
415  * errors are fatal.
416  *----------------------------------------------------------------------------*/
417
418 size_t
420  void *buf,
421  size_t size,
422  size_t stride,
423  cs_gnum_t global_num_start,
424  cs_gnum_t global_num_end);
425
426 /*----------------------------------------------------------------------------
427  * Update the file pointer according to whence.
428  *
429  * parameters:
430  * f <-> cs_file_t descriptor.
431  * offset <-- add to position specified to whence to obtain new position,
432  * measured in characters from the beginning of the file.
433  * whence <-- beginning if CS_FILE_SEEK_SET, current if CS_FILE_SEEK_CUR,
434  * or end-of-file if CS_FILE_SEEK_END.
435  *
436  * returns:
437  * 0 upon success, nonzero otherwise; currently, errors are fatal.
438  *----------------------------------------------------------------------------*/
439
440 int
442  cs_file_off_t offset,
443  cs_file_seek_t whence);
444
445 /*----------------------------------------------------------------------------
446  * Return the position of the file pointer.
447  *
448  * In parallel, we consider the file pointer to be equal to the highest
449  * value of the individual file pointers.
450  *
451  * parameters:
452  * f <-- cs_file_t descriptor
453  *
454  * returns:
455  * current position of the file pointer
456  *----------------------------------------------------------------------------*/
457
460
461 /*----------------------------------------------------------------------------*/
473 /*----------------------------------------------------------------------------*/
474
475 char *
476 cs_file_gets(char *s,
477  const int size,
478  const cs_file_t *f,
479  int *line);
480
481 /*----------------------------------------------------------------------------*/
498 /*----------------------------------------------------------------------------*/
499
500 char *
501 cs_file_gets_try(char *s,
502  const int size,
503  const cs_file_t *f,
504  int *line);
505
506 /*----------------------------------------------------------------------------
507  * Dump the metadata of a file structure in human readable form
508  *
509  * parameters:
510  * f <-- pointer to file
511  *----------------------------------------------------------------------------*/
512
513 void
514 cs_file_dump(const cs_file_t *f);
515
516 /*----------------------------------------------------------------------------
517  * Free the default options for file access.
518  *----------------------------------------------------------------------------*/
519
520 void
522
523 /*----------------------------------------------------------------------------
524  * Get the default options for file access.
525  *
526  * parameters:
527  * mode <-- file mode for which the default is queried (write and
528  * append use the same method, and are interchangeable here)
529  * access --> default file access method, or NULL
530  * hints --> MPI-IO hints, or NULL
531  *----------------------------------------------------------------------------*/
532
533 #if defined(HAVE_MPI)
534
535 void
537  cs_file_access_t *method,
538  MPI_Info *hints);
539
540 #else
541
542 void
544  cs_file_access_t *method);
545
546 #endif
547
548 /*----------------------------------------------------------------------------
549  * Set the default options for file access.
550  *
551  * If the method given contains incompatible values, such as when setting
552  * MPI-IO methods when MPI-IO is not available, a "reasonable" default
553  * is used instead.
554  *
555  * parameters:
556  * mode <-- file mode for which the default is to be set (write and
557  * append use the same method, and are interchangeable here)
558  * method <-- default access method to set
559  * hints <-- MPI-IO hints, or MPI_INFO_NULL
560  *----------------------------------------------------------------------------*/
561
562 #if defined(HAVE_MPI)
563
564 void
566  cs_file_access_t method,
567  MPI_Info hints);
568
569 #else
570
571 void
573  cs_file_access_t method);
574
575 #endif
576
577 #if defined(HAVE_MPI)
578
579 /*----------------------------------------------------------------------------
580  * Get default MPI communicator values for file access.
581  *
582  * A block rank stepping value may be used, allowing the use of a reduced
583  * communicator for distributed block reads and writes.
584  * If this value is greater than 1, ranks not a multiple of this step must be
585  * guaranteed to be empty for block reads and writes with files opened using
586  * this default.
587  *
588  * parameters:
589  * block_rank_step --> MPI rank stepping between non-empty distributed blocks,
590  * or NULL
591  * block_comm --> Handle to MPI communicator used for distributed
592  * file block access, or NULL
593  * comm --> Handle to main MPI communicator, or NULL
594  *----------------------------------------------------------------------------*/
595
596 void
597 cs_file_get_default_comm(int *block_rank_step,
598  MPI_Comm *block_comm,
599  MPI_Comm *comm);
600
601 /*----------------------------------------------------------------------------
602  * Set default MPI communicator values for file access.
603  *
604  * A block rank stepping value may be used, allowing the use of a reduced
605  * communicator for distributed block reads and writes.
606  * If this value is greater than 1, ranks not a multiple of this step must be
607  * guaranteed to be empty for block reads and writes with files opened using
608  * this default.
609  *
610  * For each argument, an "out of range" value may be used to avoid modifying
611  * the previous default for that argument.
612  *
613  * parameters:
614  * block_rank_step <-- MPI rank stepping between non-empty blocks for
615  * file block reads and writes (not set if <= 0)
616  * comm <-- handle to main MPI communicator
617  * (not set if MPI_COMM_SELF)
618  *----------------------------------------------------------------------------*/
619
620 void
621 cs_file_set_default_comm(int block_rank_step,
622  MPI_Comm comm);
623
624 /*----------------------------------------------------------------------------
625  * Create an MPI communicator for distributed block parallel IO.
626  *
627  * parameters:
628  * block_rank_step <-- MPI rank stepping between non-empty blocks
629  * comm <-- Handle to main MPI communicator
630  *
631  * returns:
632  * communicator associated with IO, MPI_COMM_NULL for ranks not
633  * participating in parallel IO (including ranks participating in IO
634  * where communicator size would be 1)
635  *----------------------------------------------------------------------------*/
636
637 MPI_Comm
638 cs_file_block_comm(int block_rank_step,
639  MPI_Comm comm);
640
641 #endif /* defined(HAVE_MPI) */
642
643 /*----------------------------------------------------------------------------
644  * Get the positioning method for MPI-IO
645  *
646  * For details, see cs_file_set_mpi_io_positioning().
647  *
648  * returns:
649  * positioning method for MPI-IO
650  *----------------------------------------------------------------------------*/
651
654
655 /*----------------------------------------------------------------------------
656  * Set the positioning method for MPI-IO
657  *
658  * It is not always known whether a performance or robustness difference is
659  * to be expected using explicit file offsets or individual file pointers.
660  * Perusal of a sampling of ROMIO code would seem to indicate that no
661  * difference is to be expected, but this might change with MPI IO variants
662  * or file systems, so this advanced setting is made possible.
663  *
664  * This setting is not available on a per-file basis, though this could be
665  * done in the future in the unexpected case of performance results
666  * showing this would be useful.
667  *
668  * parameters:
669  * positioning <-- chosen positioning method for MPI-IO
670  *----------------------------------------------------------------------------*/
671
672 void
674
675 /*----------------------------------------------------------------------------
676  * Print information on default options for file access.
677  *----------------------------------------------------------------------------*/
678
679 void
681
682 #if defined(HAVE_MPI)
683
684 /*----------------------------------------------------------------------------
685  * Create a cs_file_serializer_t structure.
686  *
687  * The buf_block_size argument is optional, and may be used when the buffer
688  * on rank 0 is larger than (global_num_end - global_num_start)*size*stride
689  * bytes. If zero, a block size of (global_num_end - global_num_start) on
690  * rank 0 is assumed; a buffer may not be smaller than this, as it must
691  * initially contain all data on rank 0's block.
692  *
693  * parameters:
694  * size <-- size of each item of data in bytes
695  * stride <-- number of (interlaced) values per block item
696  * global_num_start <-- global number of first block item (1 to n numbering)
697  * global_num_end <-- global number of past-the end block item
698  * (1 to n numbering)
699  * buf_block_size <-- Local data buffer block size, or 0 for default
700  * global_num_end - global_num_start
701  * (only useful on rank 0)
702  * buf <-- pointer to local block data buffer
703  * comm <-- associated MPI communicator
704  *
705  * returns:
706  * pointer to new serializer structure
707  *----------------------------------------------------------------------------*/
708
710 cs_file_serializer_create(size_t size,
711  size_t stride,
712  cs_gnum_t global_num_start,
713  cs_gnum_t global_num_end,
714  size_t buf_block_size,
715  void *buf,
716  MPI_Comm comm);
717
718 /*----------------------------------------------------------------------------
719  * Destroy a cs_file_serializer_t structure.
720  *
721  * parameters:
722  * s <-> pointer to pointer structure that should be destroyed
723  *----------------------------------------------------------------------------*/
724
725 void
727
728 /*----------------------------------------------------------------------------
729  * Advance a cs_file_serializer_t structure.
730  *
731  * Data from the buffer of the next communicating rank is copied
732  * to rank 0 (this is a no-op the first time this function is called,
733  * as rank 0 already has its data).
734  *
735  * On rank 0, the return value may point to the buffer defined when
736  * initializing the serializer, or to an aditional buffer if the former is
737  * too small to receive data from all ranks.
738  *
739  * Note also that for ranks > 0, this function always returns NULL,
740  * as only one call is needed for those ranks.
741  *
742  * parameters:
743  * s <-- pointer to serializer structure
744  * cur_range --> optional start and past-the end global numbers for the
745  * current block (size: 2), or NULL; only on rank 0
746  *
747  * returns:
748  * a pointer to the buffer containing new data (first call counts as new),
749  * or NULL if we are finished; always NULL on ranks > 0
750  *----------------------------------------------------------------------------*/
751
752 void *
754  cs_gnum_t cur_range[2]);
755
756 #endif /* defined(HAVE_MPI) */
757
758 /*----------------------------------------------------------------------------
759  * Create a new directory using default permissions.
760  *
761  * This function is similar to the POSIX function mkdir(), except that
762  * it has no "mode" argument: by default, on a POSIX type system,
763  * permissions include read, write, and execute access for the user,
764  * group and others, modified by the users umask value (so with a
765  * typical configuration, the user will have read, write, and execute
766  * pemission, the group and others will only have read and execute
767  * permission, but this behavior may be modified).
768  *
769  * Also, contrary to the usual mkdir(), if the directory already
770  * exists (and is truly a directory), this is considered a success
771  * and not a failure, and 0 is returned: the aim of this function
772  * is to make a directory available, so if it already exists,
773  * this is considered acceptable.
774  *
775  * parameters:
776  * path: <-- name of new directory.
777  *
778  * returns:
779  * 0 on success, -1 if an error occured (in which case errno
780  * contains the appropriate error code). If the underlying
781  * system has no mkdir() function or it was not detected
782  * upon BFT configuration, 1 is returned.
783  *----------------------------------------------------------------------------*/
784
785 int
786 cs_file_mkdir_default(const char *path);
787
788 /*----------------------------------------------------------------------------
789  * Check if a file exists and is a regular file.
790  *
791  * parameters:
792  * path <-- file name.
793  *
794  * returns:
795  * 1 if file exists and is a regular file, 0 otherwise.
796  *----------------------------------------------------------------------------*/
797
798 int
799 cs_file_isreg(const char *path);
800
801 /*----------------------------------------------------------------------------
802  * Check if a directory exists.
803  *
804  * parameters:
805  * path <-- directory name.
806  *
807  * returns:
808  * 1 if directory exists, 0 otherwise.
809  *----------------------------------------------------------------------------*/
810
811 int
812 cs_file_isdir(const char *path);
813
814 /*----------------------------------------------------------------------------
815  * List files inside a directory.
816  *
817  * The array returned must be freed by the caller using BFT_FREE,
818  * as well as the individual entries in the array.
819  *
820  * parameters:
821  * path <-- name of directory.
822  *
823  * returns:
824  * an array of file names in a directory. The last entry is set to NULL.
825  * If no means to list the directory or an error occured, the return
826  * value is simply NULL.
827  *----------------------------------------------------------------------------*/
828
829 char **
830 cs_file_listdir(const char *path);
831
832 /*----------------------------------------------------------------------------
833  * Return the size of a file.
834  *
835  * If the file does not exist, 0 is returned.
836  *
837  * Note that for some special files, such as files in the Linux /proc
838  * directory, this may return 0.
839  *
840  * parameters
841  * path <-- file path.
842  *
843  * returns:
844  * size of file.
845  *----------------------------------------------------------------------------*/
846
848 cs_file_size(const char *path);
849
850 /*----------------------------------------------------------------------------
851  * Remove a file if it exists and is a regular file or an empty directory.
852  *
853  * parameters
854  * path <-- file path.
855  *
856  * returns:
857  * 0 in case of success or if file does not exist, not 0 otherwise.
858  *----------------------------------------------------------------------------*/
859
860 int
861 cs_file_remove(const char *path);
862
863 /*----------------------------------------------------------------------------
864  * Check if a file name ends with a specific string (extension)
865  *
866  * parameters
867  * path <-- file path.
868  * end <-- string to compare
869  *
870  * returns:
871  * 1 if the path ends with the given string, 0 otherwise.
872  *----------------------------------------------------------------------------*/
873
874 int
875 cs_file_endswith(const char *path,
876  const char *end);
877
878 /*----------------------------------------------------------------------------*/
879
881
882 #endif /* __CS_FILE_H__ */
void cs_file_get_default_access(cs_file_mode_t mode, cs_file_access_t *method, MPI_Info *hints)
Definition: cs_file.c:3666
size_t cs_file_write_block_buffer(cs_file_t *f, void *buf, size_t size, size_t stride, cs_gnum_t global_num_start, cs_gnum_t global_num_end)
Write data to a file, each associated process providing a contiguous part of this data...
Definition: cs_file.c:3242
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
Definition: cs_file.h:90
void cs_file_set_swap_endian(cs_file_t *f, int swap)
Set a file&#39;s byte-swapping behavior.
Definition: cs_file.c:2742
char ** cs_file_listdir(const char *path)
Definition: cs_file.c:4503
Definition: cs_file.h:59
void cs_file_defaults_info(void)
Definition: cs_file.c:4029
void cs_file_set_default_comm(int block_rank_step, MPI_Comm comm)
Definition: cs_file.c:3873
cs_file_serializer_t * cs_file_serializer_create(size_t size, size_t stride, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t buf_block_size, void *buf, MPI_Comm comm)
Definition: cs_file.c:4138
void cs_file_serializer_destroy(cs_file_serializer_t **s)
Definition: cs_file.c:4170
Definition: cs_file.h:86
void * cs_file_serializer_advance(cs_file_serializer_t *s, cs_gnum_t cur_range[2])
Definition: cs_file.c:4203
cs_file_seek_t
seek semantics (third argument of cs_file_seek)
Definition: cs_file.h:74
int cs_file_get_swap_endian(const cs_file_t *f)
Return a file&#39;s byte-swapping behavior.
Definition: cs_file.c:2725
void cs_file_free_defaults(void)
Definition: cs_file.c:3621
size_t cs_file_write_block(cs_file_t *f, const void *buf, size_t size, size_t stride, cs_gnum_t global_num_start, cs_gnum_t global_num_end)
Definition: cs_file.c:3131
size_t cs_file_read_block(cs_file_t *f, void *buf, size_t size, size_t stride, cs_gnum_t global_num_start, cs_gnum_t global_num_end)
Read data to a buffer, distributing a contiguous part of it to each process associated with a file...
Definition: cs_file.c:2994
cs_file_t * cs_file_open(const char *name, cs_file_mode_t mode, cs_file_access_t method, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_file.c:2414
int cs_file_isdir(const char *path)
Definition: cs_file.c:4456
Definition: cs_file.h:76
Definition: cs_file.h:88
cs_file_t * cs_file_free(cs_file_t *f)
Definition: cs_file.c:2644
void cs_file_dump(const cs_file_t *f)
Dump the metadata of a file structure in human readable form.
Definition: cs_file.c:3555
cs_file_mode_t
File acces modes.
Definition: cs_file.h:64
#define MPI_Info
Definition: cs_defs.h:93
MPI_Comm cs_file_block_comm(int block_rank_step, MPI_Comm comm)
Definition: cs_file.c:3927
const char * cs_file_get_name(const cs_file_t *f)
Return a file&#39;s name.
Definition: cs_file.c:2674
const char * cs_file_access_name[]
Definition: cs_file.h:91
Definition: cs_file.h:107
int cs_file_mkdir_default(const char *path)
Definition: cs_file.c:4335
cs_file_mpi_positioning_t
MPI-IO positioning methods.
Definition: cs_file.h:97
void cs_file_set_mpi_io_positioning(cs_file_mpi_positioning_t positioning)
Set the positioning method for MPI-IO.
Definition: cs_file.c:4017
Definition: cs_file.h:78
int cs_file_remove(const char *path)
Definition: cs_file.c:4615
Definition: cs_file.h:68
Definition: cs_file.h:66
int cs_file_seek(cs_file_t *f, cs_file_off_t offset, cs_file_seek_t whence)
Definition: cs_file.c:3374
char * cs_file_gets_try(char *s, const int size, const cs_file_t *f, int *line)
Formatted input from a text file if possible (as fgets()).
Definition: cs_file.c:3538
int cs_file_endswith(const char *path, const char *end)
Check if file name/path ends with a specific string.
Definition: cs_file.c:4683
size_t cs_file_write_global(cs_file_t *f, const void *buf, size_t size, size_t ni)
Definition: cs_file.c:2864
cs_file_off_t cs_file_size(const char *path)
Definition: cs_file.c:4562
int cs_file_isreg(const char *path)
Definition: cs_file.c:4410
cs_file_t * cs_file_open_serial(const char *name, cs_file_mode_t mode)
Create a file descriptor and open the associated file, using the serial IO on the root rank...
Definition: cs_file.c:2614
cs_file_access_t
Shared file access methods.
Definition: cs_file.h:84
size_t cs_file_read_global(cs_file_t *f, void *buf, size_t size, size_t ni)
Read global data from a file, distributing it to all processes associated with that file...
Definition: cs_file.c:2766
cs_file_off_t cs_file_tell(cs_file_t *f)
Definition: cs_file.c:3463
Definition: cs_file.h:100
Definition: cs_file.h:87
Definition: cs_file.h:54
Definition: cs_file.h:67
void cs_file_get_default_comm(int *block_rank_step, MPI_Comm *block_comm, MPI_Comm *comm)
Definition: cs_file.c:3821
Definition: cs_file.h:99
const char * cs_file_mpi_positioning_name[]
char * cs_file_gets(char *s, const int size, const cs_file_t *f, int *line)
Formatted input from a text file (as fgets()).
Definition: cs_file.c:3510
Definition: cs_file.h:89
cs_file_mpi_positioning_t cs_file_get_mpi_io_positioning(void)
Get the positioning method for MPI-IO.
Definition: cs_file.c:3993
Definition: cs_file.h:77
cs_file_t * cs_file_open_default(const char *name, cs_file_mode_t mode)
Create a file descriptor and open the associated file, using the default file communicator and access...
Definition: cs_file.c:2560
void cs_file_set_default_access(cs_file_mode_t mode, cs_file_access_t method, MPI_Info hints)
Definition: cs_file.c:3732
void cs_file_set_big_endian(cs_file_t *f)
Ensure that data is read or written in big-endian (network standard) format.
Definition: cs_file.c:2691
