pulverized_coal example
As usual, one can access any field using the field_get_val_s_by_name function. cvar_*(iel) is the value of this variable in cell number iel. ONLY done if there is no restart computation
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer iel, ige, mode, icha
integer ioxy
double precision t1init, h1init, coefe(ngazem)
double precision t2init
double precision f1mc(ncharm), f2mc(ncharm)
double precision dmas, wmco2, wmh2o, wmn2, wmo2
double precision, dimension(:), pointer :: cvar_scalt, cvar_yco2
double precision, dimension(:), pointer :: cvar_hox
Initialization
The following initialization block allows setting some variable values (variables not set here keep their GUI-defined or default values):
! Variables initialization:
! ONLY when this is not a restarted computation
if (isuite.gt.0) return
! Control Print
write(nfecra,9001)
! All the domain is filled with the first oxidizer at TINITK
! Computation of H1INIT and T2INIT
t1init = t0
t2init = t0
! Transported variables for the mix (solid+carrying gas)^2
do ige = 1, ngazem
coefe(ige) = zero
enddo
! Oxidizers are mix of O2, N2 (air), CO2 and H2O (recycled exhaust)
! the composition of the fisrt oxidiser is taken in account
coefe(io2) = wmole(io2)*oxyo2(1) &
/( wmole(io2) *oxyo2(1) +wmole(in2) *oxyn2(1) &
+wmole(ih2o)*oxyh2o(1)+wmole(ico2)*oxyco2(1))
coefe(ih2o) = wmole(ih2o)*oxyh2o(1) &
coefe(ico2) = wmole(ico2)*oxyco2(1) &
coefe(in2) = 1.d0-coefe(io2)-coefe(ih2o)-coefe(ico2)
do icha = 1, ncharm
f1mc(icha) = zero
f2mc(icha) = zero
enddo
mode = -1
call cs_coal_htconvers1(mode, h1init, coefe, f1mc, f2mc, t1init)
call field_get_val_s(ivarfl(isca(iscalt)), cvar_scalt)
do iel = 1, ncel
cvar_scalt(iel) = h1init
enddo
! Transported variables for the mix (passive scalars, variance)
! Variables not present here are initialized to 0.
call field_get_val_s(ivarfl(isca(iyco2)), cvar_yco2)
call field_get_val_s(ivarfl(isca(ihox)), cvar_hox)
if (ieqco2 .ge. 1) then
ioxy = 1
wmo2 = wmole(io2)
wmco2 = wmole(ico2)
wmh2o = wmole(ih2o)
wmn2 = wmole(in2)
dmas = ( oxyo2(ioxy)*wmo2 +oxyn2(ioxy)*wmn2 &
+oxyh2o(ioxy)*wmh2o+oxyco2(ioxy)*wmco2)
xco2 = oxyco2(ioxy)*wmco2/dmas
do iel = 1, ncel
cvar_yco2(iel) = oxyco2(ioxy)*wmco2/dmas
enddo
endif
if (ieqnox .eq. 1) then
do iel = 1, ncel
cvar_hox(iel) = h1init
enddo
endif
! Formats
9001 format( /,&
' cs_user_initialization: settings for pulverized coal', /,&
