Fuel example
Fuel example
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer iel, ige, mode
integer ioxy
double precision t1init, h1init, coefe(ngazem)
double precision t2init, h2init
double precision dmas, wmco2, wmh2o, wmn2, wmo2
double precision, dimension(:), pointer :: cvar_scalt, cvar_yco2
double precision, dimension(:), pointer :: cvar_hox
Initialization
The following initialization block needs to be added for the following examples:
! Variables initialization:
! ONLY when this is not a restarted computation
if (isuite.gt.0) return
! Control Print
write(nfecra,9001)
! All the domain is filled with air at TINITK
! Computation of H1INIT and H2INIT
t1init = 1000.0
t2init = 1000.0
! Transported variables for droplets
h2init = h02fol + cp2fol*(t2init-trefth)
! Transported variables for the mix (droplets and carrying gases)
do ige = 1, ngazem
coefe(ige) = zero
enddo
! Consider oxydant 1
coefe(io2) = wmole(io2)*oxyo2(1) &
/( wmole(io2) *oxyo2(1) +wmole(in2) *oxyn2(1) &
+wmole(ih2o)*oxyh2o(1)+wmole(ico2)*oxyco2(1))
coefe(ih2o) = wmole(ih2o)*oxyh2o(1) &
coefe(ico2) = wmole(ico2)*oxyco2(1) &
coefe(in2) = 1.d0-coefe(io2)-coefe(ih2o)-coefe(ico2)
mode = -1
call cs_fuel_htconvers1(mode, h1init, coefe, t1init)
call field_get_val_s(ivarfl(isca(iscalt)), cvar_scalt)
do iel = 1, ncel
cvar_scalt(iel) = h1init
enddo
! Transported variables for the mix (passive scalars, variance)
! Variables not present here are initialized to 0.
call field_get_val_s(ivarfl(isca(iyco2)), cvar_yco2)
call field_get_val_s(ivarfl(isca(ihox)), cvar_hox)
if (ieqco2 .ge. 1) then
ioxy = 1
wmo2 = wmole(io2)
wmco2 = wmole(ico2)
wmh2o = wmole(ih2o)
wmn2 = wmole(in2)
dmas = ( oxyo2(ioxy)*wmo2 +oxyn2(ioxy)*wmn2 &
+oxyh2o(ioxy)*wmh2o+oxyco2(ioxy)*wmco2)
do iel = 1, ncel
cvar_yco2(iel) = oxyco2(ioxy)*wmco2/dmas
enddo
endif
if (ieqnox .eq. 1) then
do iel = 1, ncel
cvar_hox(iel) = h1init
enddo
endif
! Formats
9001 format( /,&
' cs_user_initialization: settings for fuel', /,&
