Atmospheric example
Atmospheric example
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer iel
double precision d2s3
double precision zent,xuent,xvent,xkent,xeent,tpent
double precision, dimension(:,:), pointer :: cvar_vel
double precision, dimension(:), pointer :: cvar_k, cvar_ep, cvar_phi, cvar_fb
double precision, dimension(:), pointer :: cvar_omg, cvar_nusa
double precision, dimension(:), pointer :: cvar_r11, cvar_r22, cvar_r33
double precision, dimension(:), pointer :: cvar_r12, cvar_r13, cvar_r23
double precision, dimension(:), pointer :: cvar_scalt
Allocation
Before user initialization, work arrays lstelt must be allocated, like in basic example.
Initialization
The following initialization block needs to be added for the following examples:
! Map field arrays
call field_get_val_v(ivarfl(iu), cvar_vel)
d2s3 = 2.d0/3.d0
! Initialize variables using an input meteo profile
! (only if we are not doing a restart)
if (isuite.eq.0) then
if (itytur.eq.2) then
call field_get_val_s(ivarfl(ik), cvar_k)
call field_get_val_s(ivarfl(iep), cvar_ep)
elseif (itytur.eq.3) then
call field_get_val_s(ivarfl(ir11), cvar_r11)
call field_get_val_s(ivarfl(ir22), cvar_r22)
call field_get_val_s(ivarfl(ir33), cvar_r33)
call field_get_val_s(ivarfl(ir12), cvar_r12)
call field_get_val_s(ivarfl(ir13), cvar_r13)
call field_get_val_s(ivarfl(ir23), cvar_r23)
elseif (iturb.eq.50) then
call field_get_val_s(ivarfl(iphi), cvar_phi)
call field_get_val_s(ivarfl(ifb), cvar_fb)
elseif (iturb.eq.60) then
call field_get_val_s(ivarfl(iomg), cvar_omg)
elseif (iturb.eq.70) then
call field_get_val_s(ivarfl(inusa), cvar_nusa)
endif
do iel = 1, ncel
zent = xyzcen(3,iel)
call intprf(nbmetd, nbmetm, zdmet, tmmet, umet, zent, ttcabs, xuent)
call intprf(nbmetd, nbmetm, zdmet, tmmet, vmet, zent, ttcabs, xvent)
call intprf(nbmetd, nbmetm, zdmet, tmmet, ekmet, zent, ttcabs, xkent)
call intprf(nbmetd, nbmetm, zdmet, tmmet, epmet, zent, ttcabs, xeent)
cvar_vel(1,iel) = xuent
cvar_vel(2,iel) = xvent
cvar_vel(3,iel) = 0.d0
! Initiliation of turbulence variables
cvar_k(iel) = xkent
cvar_ep(iel) = xeent
cvar_r11(iel) = d2s3*xkent
cvar_r22(iel) = d2s3*xkent
cvar_r33(iel) = d2s3*xkent
cvar_r12(iel) = 0.d0
cvar_r13(iel) = 0.d0
cvar_r23(iel) = 0.d0
cvar_k(iel) = xkent
cvar_phi(iel) = d2s3
cvar_fb(iel) = 0.d0
cvar_k(iel) = xkent
cvar_omg(iel) = xeent/cmu/xkent
cvar_nusa(iel) = cmu*xkent**2/xeent
endif
if (iscalt.ge.0) then
! Assume the scalar is a potential temperature
call intprf(nbmett, nbmetm, ztmet, tmmet, tpmet, zent, ttcabs, tpent)
call field_get_val_s(ivarfl(isca(iscalt)), cvar_scalt)
cvar_scalt(iel) = tpent
endif
enddo
endif
Finalization
At the end of the subroutine, it is recommended to deallocate the work array lstelt, like in basic example.
