Gas Libby-Williams examples
Local variables to be added
integer ifac, izone, ii
integer ilelt, nlelt
double precision uref2, xkent, xeent, d2s3
integer, allocatable, dimension(:) :: lstelt
Example 1
Definition of a burned gas inlet (pilot flame) for each face of colour 11
call getfbr('11', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
! Type of pre-defined boundary condidition (see above)
itypfb(ifac) = ientre
! Zone number (arbitrary number between 1 and n)
izone = 1
! Allocation of the actual face to the zone
izfppp(ifac) = izone
! Indicating the inlet as a burned gas inlet
ientgb(izone) = 1
! The incoming burned gas flow refers to:
! a) a massflow rate -> iqimp() = 1
iqimp(izone) = 0
qimp(izone) = zero
! b) an inlet velocity -> iqimp() = 0
rcodcl(ifac,iu,1) = 0.d0
rcodcl(ifac,iv,1) = 0.d0
rcodcl(ifac,iw,1) = 21.47d0
! ATTENTION: If iqimp() = 1 the direction vector of the massfow has
! to be given here.
! Mean Mixture Fraction at Inlet
fment(izone) = 1.d0*fs(1)
! Inlet Temperature in K
tkent(izone) = 2000.d0
! Boundary Conditions of Turbulence
icalke(izone) = 1
! - If ICALKE = 0 the boundary conditions of turbulence at
! the inlet are calculated as follows:
if(icalke(izone).eq.0) then
uref2 = rcodcl(ifac,iu,1)**2 &
+rcodcl(ifac,iv,1)**2 &
+rcodcl(ifac,iw,1)**2
uref2 = max(uref2,1.d-12)
xkent = epzero
xeent = epzero
if (itytur.eq.2) then
rcodcl(ifac,ik,1) = xkent
rcodcl(ifac,iep,1) = xeent
elseif(itytur.eq.3) then
rcodcl(ifac,ir11,1) = d2s3*xkent
rcodcl(ifac,ir22,1) = d2s3*xkent
rcodcl(ifac,ir33,1) = d2s3*xkent
rcodcl(ifac,ir12,1) = 0.d0
rcodcl(ifac,ir13,1) = 0.d0
rcodcl(ifac,ir23,1) = 0.d0
elseif (iturb.eq.50) then
rcodcl(ifac,iphi,1) = d2s3
rcodcl(ifac,ifb,1) = 0.d0
elseif (iturb.eq.60) then
rcodcl(ifac,iomg,1) = xeent/cmu/xkent
elseif (iturb.eq.70) then
rcodcl(ifac,inusa,1) = cmu*xkent**2/xeent
endif
endif
! - If ICALKE = 1 the boundary conditions of turbulence at
! the inlet refer to both, a hydraulic diameter and a
! reference velocity.
dh(izone) = 0.032d0
! - If ICALKE = 2 the boundary conditions of turbulence at
! the inlet refer to a turbulence intensity.
xintur(izone) = 0.d0
enddo
Example 2
Definition of an unburned gas inlet for each face of colour 12
call getfbr('12', nlelt, lstelt)
do ilelt = 1, nlelt
izone = 2
! Indicating the inlet as an unburned gas inlet
ientgf(izone) = 1
! The incoming unburned gas flow refers to:
iqimp(izone) = 0
qimp(izone) = zero
rcodcl(ifac,iu,1) = 60.d0
rcodcl(ifac,iw,1) = 0.d0
! to be given here.
fment(izone) = 8.d-1*fs(1)
tkent(izone) = 600.d0
icalke(izone) = 1
dh(izone) = 0.08d0
xintur(izone) = 0.1d0
enddo
Example 3
Definition of a wall for each face of colour 51 and 5
call getfbr('51 or 5', nlelt, lstelt)
do ilelt = 1, nlelt
! Type de condition aux limites pour les variables standard
itypfb(ifac) = iparoi
izone = 4
enddo
Example 4
Definition of an exit for each face of colour 91 and 9
call getfbr('91 or 9', nlelt, lstelt)
do ilelt = 1, nlelt
itypfb(ifac) = isolib
izone = 5
! Allocation of the actual face to the zone 9
enddo
Example 5
Definition of symmetric boundary conditions for each face of colour 41 and 4.
call getfbr('41 or 4', nlelt, lstelt)
do ilelt = 1, nlelt
itypfb(ifac) = isymet
izone = 6
! Allocation of the actual face to the zonec
enddo
