fvm_to_catalyst.h
1 #ifndef __FVM_TO_CATALYST_H__
2 #define __FVM_TO_CATALYST_H__
4 #if defined(HAVE_CATALYST)
5
6 /*============================================================================
7  * Write a nodal representation associated with a mesh and associated
8  * variables to Catalyst objects
9  *============================================================================*/
11 /*
12  This file is part of Code_Saturne, a general-purpose CFD tool.
13
14  Copyright (C) 1998-2021 EDF S.A.
15
16  This program is free software; you can redistribute it and/or modify it under
17  the terms of the GNU General Public License as published by the Free Software
18  Foundation; either version 2 of the License, or (at your option) any later
19  version.
20
21  This program is distributed in the hope that it will be useful, but WITHOUT
22  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
23  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
24  details.
25
26  You should have received a copy of the GNU General Public License along with
27  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
28  Street, Fifth Floor, Boston, MA 02110-1301, USA.
29 */
30
31 /*----------------------------------------------------------------------------*/
32
33 #include "cs_defs.h"
34
36  * Local headers
38
39 #include "fvm_defs.h"
40 #include "fvm_nodal.h"
41 #include "fvm_writer.h"
46
48  * Macro definitions
50
52  * Type definitions
54
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------
60  * Initialize FVM to Catalyst object writer.
61  *
62  * Options are:
63  * private_comm use private MPI communicator (default: false)
64  * names=<fmt> use same naming rules as <fmt> format
65  * (default: ensight)
66  * input_name=<name> define input name (default: writer name)
67  *
68  * parameters:
69  * name <-- base output case name.
70  * options <-- whitespace separated, lowercase options list
71  * time_dependecy <-- indicates if and how meshes will change with time
72  * comm <-- associated MPI communicator.
73  *
74  * returns:
75  * pointer to opaque Catalyst writer structure.
76  *----------------------------------------------------------------------------*/
77
78 #if defined(HAVE_MPI)
79
80 void *
81 fvm_to_catalyst_init_writer(const char *name,
82  const char *path,
83  const char *options,
84  fvm_writer_time_dep_t time_dependency,
85  MPI_Comm comm);
86
87 #else
88
89 void *
90 fvm_to_catalyst_init_writer(const char *name,
91  const char *path,
92  const char *options,
93  fvm_writer_time_dep_t time_dependency);
94
95 #endif
96
97 /*----------------------------------------------------------------------------
98  * Finalize FVM to Catalyst object writer.
99  *
100  * parameters:
101  * this_writer_p <-- pointer to opaque Catalyst writer structure.
102  *
103  * returns:
104  * NULL pointer.
105  *----------------------------------------------------------------------------*/
106
107 void *
108 fvm_to_catalyst_finalize_writer(void *this_writer_p);
109
110 /*----------------------------------------------------------------------------
111  * Associate new time step with a Catalyst geometry.
112  *
113  * parameters:
114  * this_writer_p <-- pointer to associated writer
115  * time_step <-- time step number
116  * time_value <-- time_value number
117  *----------------------------------------------------------------------------*/
118
119 void
120 fvm_to_catalyst_set_mesh_time(void *this_writer_p,
121  int time_step,
122  double time_value);
123
124 /*----------------------------------------------------------------------------
125  * Write nodal mesh to a a Catalyst object
126  *
127  * parameters:
128  * this_writer_p <-- pointer to associated writer.
129  * mesh <-- pointer to nodal mesh structure that should be written.
130  *----------------------------------------------------------------------------*/
131
132 void
133 fvm_to_catalyst_export_nodal(void *this_writer_p,
134  const fvm_nodal_t *mesh);
135
136 /*----------------------------------------------------------------------------
137  * Write data to the MultiBlock aimed to be CoProcessed
138  *
139  * parameters:
140  * this_writer_p <-- pointer to associated writer
141  * ugrid <-- pointer to the vtkUnstructuredGrid
142  *----------------------------------------------------------------------------*/
143
144 void
145 fvm_to_catalyst_export_field(void *this_writer_p,
146  const fvm_nodal_t *mesh,
147  const char *name,
148  fvm_writer_var_loc_t location,
149  int dimension,
150  cs_interlace_t interlace,
151  int n_parent_lists,
152  const cs_lnum_t parent_num_shift[],
153  cs_datatype_t datatype,
154  int time_step,
155  double time_value,
156  const void *const field_values[]);
157
158 /*----------------------------------------------------------------------------
159  * Flush files associated with a given writer.
160  *
161  * In this case, the effective call to coprocessing is done.
162  *
163  * parameters:
164  * this_writer_p <-- pointer to associated writer
165  *----------------------------------------------------------------------------*/
166
167 void
168 fvm_to_catalyst_flush(void *this_writer_p);
169
170 /*----------------------------------------------------------------------------*/
171
173
174 #endif /* defined(HAVE_CATALYST) */
175
176 #endif /* __FVM_TO_CATALYST_H__ */
cs_datatype_t
Definition: cs_defs.h:260
Definition: fvm_writer.h:69
cs_interlace_t
Definition: cs_defs.h:467
Definition: cs_defs.h:495
Definition: fvm_writer.h:57
Definition: cs_defs.h:301
Definition: cs_defs.h:496
Definition: mesh.f90:26
