Particle relaxation time and thermal relaxtion for the Lagrangian model
Calculation of the particle relaxation time
Modification of the calculation of the particle relaxation time with respect to the chosen formulation for the drag coefficient
This function is called in a loop on the particles, so be careful to avoid too costly operations.
$ \tau_c = \frac{m_p{C_p}_p}{PId_p^2h_e} $
$ \tau_c $ : Thermal relaxation time (value to be computed)
$ m_p $ : Particle mass
$ {C_p}_p $ : Particle specific heat
d_p : Particle diameter
h_e : Coefficient of thermal exchange
The coefficient of thermal exchange is calculated from a Nusselt number, itself evaluated by a correlation (Ranz-Marshall by default)
$ \nu = \frac{h_ed_p}{\lambda} = 2 + 0.55{\Re_e}_p^{0.5}P_{rt}^{0.33} $
$ \lambda $ : Thermal conductivity of the carrier field
$ {\Re_e}_p $ : Particle Reynolds number
P_{rt} : Prandtl number
In the next example we compute the relaxation time with two different formulations of the drag coefficient:
void
cs_real_t re_p,
cs_real_t uvwr,
cs_real_t rho_f,
cs_real_t rho_p,
cs_real_t nu_f,
cs_real_t taup[],
const cs_real_t dt[])
/* Particles management */
const cs_lagr_attribute_map_t *p_am = p_set->p_am;
unsigned char *particle = p_set->p_buffer + p_am->extents * id_p;
cs_real_t p_diam = cs_lagr_particle_get_real(particle, p_am, CS_LAGR_DIAMETER);
* Relaxation time with the standard (Wen-Yu) formulation of the drag coefficient
/* This example gives the standard relaxation time as an indication:*/
cs_real_t fdr;
cs_real_t cd1 = 0.15;
cs_real_t cd2 = 0.687;
if (re_p <= 1000)
fdr = 18.0 * nu_f * (1.0 + cd1 * pow(re_p, cd2)) / (p_diam * p_diam);
else
fdr = (0.44 * 3.0 / 4.0) * uvwr / p_diam;
taup[id_p] = rho_p / rho_f / fdr;
* Computation of the relaxation time with the drag coefficient of
* S.A. Morsi and A.J. Alexander, J. of Fluid Mech., Vol.55, pp 193-208 (1972)
cs_real_t rec1 = 0.1;
cs_real_t rec2 = 1.0;
cs_real_t rec3 = 10.0;
cs_real_t rec4 = 200.0;
cs_real_t dd2 = p_diam * p_diam;
if (re_p <= rec1)
fdr = 18.0 * nu_f / dd2;
else if (re_p <= rec2)
fdr = 3.0/4.0 * nu_f / dd2 * (22.73 + 0.0903 / re_p + 3.69 * re_p);
else if (re_p <= rec3)
fdr = 3.0/4.0 * nu_f / dd2 * (29.1667 - 3.8889 / re_p + 1.222 * re_p);
else if (re_p <=rec4)
fdr = 18.0 * nu_f / dd2 *(1.0 + 0.15 * pow(re_p, 0.687));
else
Computation of the thermal relaxation time of the particles
Modification of the computation of the thermal relaxation time of the particles with respect to the chosen formulation of the Nusselt number.
void
cs_real_t re_p,
cs_real_t uvwr,
cs_real_t rho_f,
cs_real_t rho_p,
cs_real_t nu_f,
cs_real_t cp_f,
cs_real_t k_f,
cs_real_t tauc[],
/* 1. Initializations: Particles management */
/* 2. Standard thermal relaxation time */
/* This example gives the standard thermal relaxation time
* as an indication.*/
cs_real_t prt = nu_f / k_f;
cs_real_t fnus = 2.0 + 0.55 * sqrt(re_p) * pow(prt, 1./3.);
cs_real_t diam = cs_lagr_particle_get_real(particle, p_am, CS_LAGR_DIAMETER);
cs_real_t cp_p = cs_lagr_particle_get_real(particle, p_am, CS_LAGR_CP);
tauc[id_p]= diam * diam * rho_p * cp_p / ( fnus * 6.0 * rho_f * cp_f * k_f);
