1 #ifndef __CS_VOLUME_MASS_INJECTION_H__ 2 #define __CS_VOLUME_MASS_INJECTION_H__ void cs_volume_mass_injection_flag_zones(void)
Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume ...
Definition: cs_volume_mass_injection.c:487
void cs_volume_mass_injection_get_arrays(const cs_field_t *f, cs_lnum_t *ncesmp, cs_lnum_t **icetsm, int **itpsmp, cs_real_t **smcelp, cs_real_t **gamma)
Return pointers to the mass source term arrays.
Definition: cs_volume_mass_injection.c:686
double precision, dimension(:,:), allocatable, target smacel
Definition: pointe.f90:200
Definition: cs_field.h:125
Definition: cs_defs.h:495
void * input
Definition: cs_volume_mass_injection.h:77
integer, dimension(:,:), allocatable, target itypsm
Definition: pointe.f90:194
Definition: cs_defs.h:307
void() cs_volume_mass_injection_eval_t(void *input, const cs_zone_t *z, cs_field_t *f, cs_real_t *val)
Function pointer to update cell values in a given zone for volume mass injection. ...
Definition: cs_volume_mass_injection.h:60
Definition: cs_field_pointer.h:227
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
cs_volume_mass_injection_eval_t * func
Definition: cs_volume_mass_injection.h:82
integer, dimension(:), allocatable, target icetsm
Definition: pointe.f90:184
Definition: cs_defs.h:301
Definition: cs_defs.h:496
void cs_volume_mass_injection_eval(int nvar, cs_lnum_t ncesmp, int itypsm[], cs_real_t smacel[])
Evaluate contributions to volume mass injection.
Definition: cs_volume_mass_injection.c:574
void cs_volume_mass_injection_build_lists(cs_lnum_t n_cells, cs_lnum_t cell_num[], int cell_zone_id[])
Build the list and zone ids of cells with volume mass injection.
Definition: cs_volume_mass_injection.c:530
Context structure associated to a mass injection inside a volume relying on a function.
Definition: cs_volume_mass_injection.h:71
