cs_turbomachinery.h
1 #ifndef __CS_TURBOMACHINERY_H__
2 #define __CS_TURBOMACHINERY_H__
5  * Turbomachinery modeling features.
34 #include "cs_defs.h"
37  * Local headers
40 #include "cs_restart.h"
45
46 /*=============================================================================
47  * Local Type Definitions
49
50 /*----------------------------------------------------------------------------
51  * Local Structure Definitions
52  *----------------------------------------------------------------------------*/
53
54 /* Turbomachinery model type */
55
56 typedef enum {
57
58  CS_TURBOMACHINERY_NONE, /* No turbomachinery modeling */
59  CS_TURBOMACHINERY_FROZEN, /* Frozen rotor model */
60  CS_TURBOMACHINERY_TRANSIENT /* full transient simulation */
61
63
64 /*============================================================================
65  * Static global variables
66  *============================================================================*/
67
68 /*============================================================================
69  * Public function prototypes
70  *============================================================================*/
71
72 /*----------------------------------------------------------------------------
73  * Define rotor/stator model.
74  *----------------------------------------------------------------------------*/
75
76 void
78
79 /*----------------------------------------------------------------------------
80  * return rotor/stator model.
81  *----------------------------------------------------------------------------*/
82
85
87  * Define a rotor by its axis and cell selection criteria.
88  *
89  * parameters:
90  * cell_criteria <-- cell selection criteria string
91  * rotation_velocity <-- rotation velocity, in radians/second
92  * rotation_axis <-- rotation axis vector
93  * rotation_invariant <-- rotation invariant point
94  *----------------------------------------------------------------------------*/
95
96 void
97 cs_turbomachinery_add_rotor(const char *cell_criteria,
98  double rotation_velocity,
99  const double rotation_axis[3],
100  const double rotation_invariant[3]);
101
102 /*----------------------------------------------------------------------------
103  * Add a cs_join_t structure to the list of rotor/stator joinings.
104  *
105  * parameters:
106  * sel_criteria <-- boundary face selection criteria
107  * fraction <-- value of the fraction parameter
108  * plane <-- value of the plane parameter
109  * verbosity <-- level of verbosity required
110  * visualization <-- level of visualization required
111  *
112  * returns:
113  * number (1 to n) associated with new joining
114  *----------------------------------------------------------------------------*/
115
116 int
117 cs_turbomachinery_join_add(const char *sel_criteria,
118  float fraction,
119  float plane,
120  int verbosity,
121  int visualization);
122
123 /*----------------------------------------------------------------------------
124  * \brief Add a boundary coupling to the list of rotor/stator couplings.
125  *
126  * parameters:
127  * sel_criteria <-- boundary face selection criteria
128  * tolerance <-- value of the search tolerance
129  * verbosity <-- level of verbosity required
130  *
131  * returns:
132  * number (1 to n) associated with new coupling
133  *----------------------------------------------------------------------------*/
134
135 int
136 cs_turbomachinery_coupling_add(const char *sel_criteria,
137  float tolerance,
138  int verbosity);
139
140 /*----------------------------------------------------------------------------
141  * Definitions for turbomachinery computation.
142  *----------------------------------------------------------------------------*/
143
144 void
146
147 /*----------------------------------------------------------------------------
148  * Initializations for turbomachinery computation
149  *
150  * Note: this function should be called after the mesh is built,
151  * but before cs_post_init_meshes() so that postprocessing meshes are
152  * updated correctly in the transient case.
153  *----------------------------------------------------------------------------*/
154
155 void
157
158 /*----------------------------------------------------------------------------
159  * Free turbomachinery info
160  *----------------------------------------------------------------------------*/
161
162 void
164
165 /*----------------------------------------------------------------------------
166  * Update mesh for unsteady rotor/stator computation
167  *
168  * parameters:
169  * t_cur_mob <-- current rotor time
170  * t_elapsed --> elapsed computation time
171  *----------------------------------------------------------------------------*/
172
173 void
174 cs_turbomachinery_update_mesh(double t_cur_mob,
175  double *t_elapsed);
176
177 /*----------------------------------------------------------------------------
178  * Update mesh for unsteady rotor/stator computation in case of restart.
179  *
180  * Reads mesh from checkpoint when available.
181  *----------------------------------------------------------------------------*/
182
183 void
185
186 /*----------------------------------------------------------------------------
187  * Reinitialize interior face-based fields.
188  *----------------------------------------------------------------------------*/
189
190 void
192
193 /*----------------------------------------------------------------------------
194  * Resize cell-based fields.
195  *
196  * This function only handles fields owning their values.
197  *----------------------------------------------------------------------------*/
198
199 void
201
202 /*----------------------------------------------------------------------------
203  * Compute rotation matrix
204  *
205  * parameters:
206  * rotor_num <-- rotor number (1 to n numbering)
207  * theta <-- rotation angle, in radians
208  * matrix --> resulting rotation matrix
209  *----------------------------------------------------------------------------*/
210
211 void
213  double theta,
214  cs_real_t matrix[3][4]);
215
216 /*----------------------------------------------------------------------------
217  * Return number of rotors.
218  *
219  * Note that the number of associated rotations is n_rotors + 1, as the
220  * first rotation id is reserved for the fixed portion of the domain.
221  *
222  * return:
223  * number of rotors
224  *----------------------------------------------------------------------------*/
225
226 int
228
229 /*----------------------------------------------------------------------------
230  * Return cell rotor number.
231  *
232  * Each cell may be associated with a given rotor, or rotation, with 0
233  * indicating that that cell does not rotate.
234  *
235  * returns:
236  * array defining rotor number associated with each cell
237  * (0 for none, 1 to n otherwise)
238  *----------------------------------------------------------------------------*/
239
240 const int *
242
243 /*----------------------------------------------------------------------------
244  * Return rotation velocity
245  *
246  * parameters:
247  * rotor_num <-- rotor number (1 to n numbering)
248  *----------------------------------------------------------------------------*/
249
250 double
252
253 /*----------------------------------------------------------------------------*/
260 /*----------------------------------------------------------------------------*/
261
262 void
264  double omega);
265
266 /*----------------------------------------------------------------------------*/
276 /*----------------------------------------------------------------------------*/
277
278 cs_real_34_t *
280
281 /*----------------------------------------------------------------------------*/
293 /*----------------------------------------------------------------------------*/
294
295 void
296 cs_turbomachinery_set_rotation_retry(int n_max_join_retries,
297  double dt_retry_multiplier);
298
299 /*----------------------------------------------------------------------------
300  * Rotation of vector and tensor fields.
301  *
302  * parameters:
303  * dt <-- cell time step values
304  *----------------------------------------------------------------------------*/
305
306 void
308
309 /*----------------------------------------------------------------------------
310  * Compute velocity relative to fixed coordinates at a given point
311  *
312  * Deprecated:
313  * Use cs_rotation_velocity for more consistent naming of this reference
314  * frame velocity.
315  *
316  * parameters:
317  * rotor_num <-- associated rotor number (1 to n numbering)
318  * coords <-- point coordinates
319  * velocity --> velocity relative to fixed coordinates
320  *----------------------------------------------------------------------------*/
321
322 void
324  const cs_real_t coords[3],
325  cs_real_t velocity[3]);
326
327 /*----------------------------------------------------------------------------*/
335 /*----------------------------------------------------------------------------*/
336
337 void
339
340 /*----------------------------------------------------------------------------*/
348 /*----------------------------------------------------------------------------*/
349
350 void
352
353 /*----------------------------------------------------------------------------*/
354
356
357 #endif /* __CS_TURBOMACHINERY_H__ */
358
cs_turbomachinery_model_t
Definition: cs_turbomachinery.h:56
Definition: cs_turbomachinery.h:60
void cs_turbomachinery_rotation_matrix(int rotor_num, double theta, cs_real_t matrix[3][4])
Compute rotation matrix.
Definition: cs_turbomachinery.c:1606
void cs_turbomachinery_set_model(cs_turbomachinery_model_t model)
Definition: cs_turbomachinery.c:1199
void cs_turbomachinery_relative_velocity(int rotor_num, const cs_real_t coords[3], cs_real_t velocity[3])
Compute velocity relative to fixed coordinates at a given point.
Definition: cs_turbomachinery.c:1848
void cs_turbomachinery_rotate_fields(const cs_real_t dt[])
Definition: cs_turbomachinery.c:1753
cs_real_t cs_real_34_t[3][4]
Definition: cs_defs.h:333
Definition: cs_turbomachinery.h:59
double precision, dimension(ncharm), save omega
Definition: cpincl.f90:99
Definition: cs_defs.h:495
void cs_turbomachinery_initialize(void)
Initializations for turbomachinery computation.
Definition: cs_turbomachinery.c:1434
int cs_turbomachinery_join_add(const char *sel_criteria, float fraction, float plane, int verbosity, int visualization)
Definition: cs_turbomachinery.c:1284
Definition: cs_turbomachinery.h:58
const int * cs_turbomachinery_get_cell_rotor_num(void)
Definition: cs_turbomachinery.c:1651
void cs_turbomachinery_restart_read(cs_restart_t *r)
Read turbomachinery metadata from restart file.
Definition: cs_turbomachinery.c:1873
double cs_turbomachinery_get_rotation_velocity(int rotor_num)
Return rotation velocity.
Definition: cs_turbomachinery.c:1665
void cs_turbomachinery_update_mesh(double t_cur_mob, double *t_elapsed)
Update mesh for unsteady rotor/stator computation.
Definition: cs_turbomachinery.c:1366
Definition: cs_defs.h:307
Definition: cs_matrix_building.c:112
cs_turbomachinery_model_t cs_turbomachinery_get_model(void)
Return rotor/stator model.
Definition: cs_turbomachinery.c:1220
void cs_turbomachinery_resize_cell_fields(void)
Definition: cs_turbomachinery.c:1550
int cs_turbomachinery_n_rotors(void)
Definition: cs_turbomachinery.c:1628
void cs_turbomachinery_set_rotation_velocity(int rotor_num, double omega)
Set rotation velocity.
Definition: cs_turbomachinery.c:1682
void cs_turbomachinery_add_rotor(const char *cell_criteria, double rotation_velocity, const double rotation_axis[3], const double rotation_invariant[3])
Definition: cs_turbomachinery.c:1240
Definition: cs_restart.h:93
void cs_turbomachinery_restart_mesh(void)
Definition: cs_turbomachinery.c:1381
double precision, dimension(:,:,:), allocatable theta
Definition: atimbr.f90:123
void cs_turbomachinery_finalize(void)
Free turbomachinery structure.
Definition: cs_turbomachinery.c:1496
int cs_turbomachinery_coupling_add(const char *sel_criteria, float tolerance, int verbosity)
Definition: cs_turbomachinery.c:1332
void cs_turbomachinery_reinit_i_face_fields(void)
Definition: cs_turbomachinery.c:1527
void cs_turbomachinery_set_rotation_retry(int n_max_join_retries, double dt_retry_multiplier)
Set turbomachinery joining retry parameters.
Definition: cs_turbomachinery.c:1705
Definition: cs_defs.h:496
void cs_turbomachinery_restart_write(cs_restart_t *r)
Write turbomachinery metadata to checkpoint file.
Definition: cs_turbomachinery.c:1918
cs_real_34_t * cs_turbomachinery_get_rotation_matrices(double dt)
Build rotation matrices for a given time interval.
Definition: cs_turbomachinery.c:1727
void cs_turbomachinery_define(void)
Definition: cs_turbomachinery.c:1402
