1 #ifndef __CS_RANGE_SET_H__ 2 #define __CS_RANGE_SET_H__ cs_datatype_t
Definition: cs_defs.h:260
void cs_range_set_sync(const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, void *val)
Synchronize values elements associated with a range set, using either a halo or an interface set...
Definition: cs_range_set.c:930
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
cs_range_set_t * cs_range_set_create(const cs_interface_set_t *ifs, const cs_halo_t *halo, cs_lnum_t n_elts, bool balance, int tr_ignore, cs_gnum_t g_id_base)
Create a range set (with associated range and global ids) for the partitioning of data based on local...
Definition: cs_range_set.c:682
Definition: cs_defs.h:495
const cs_gnum_t * g_id
Definition: cs_range_set.h:65
void cs_range_set_zero_out_of_range(const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, void *val)
Set values of a given array to zero for indexes of elements outside the local range.
Definition: cs_range_set.c:810
void cs_range_set_define(const cs_interface_set_t *ifs, const cs_halo_t *halo, cs_lnum_t n_elts, bool balance, int tr_ignore, cs_gnum_t g_id_base, cs_gnum_t l_range[2], cs_gnum_t *g_id)
Define global ids and a partitioning of data based on local ranges for elements which may be shared a...
Definition: cs_range_set.c:578
cs_range_set_t * cs_range_set_create_from_shared(const cs_interface_set_t *ifs, const cs_halo_t *halo, cs_lnum_t n_elts, cs_gnum_t l_range[2], cs_gnum_t *g_id)
Create a range set (with associated range and global ids) from an existing partition of data based on...
Definition: cs_range_set.c:736
const cs_interface_set_t * ifs
Definition: cs_range_set.h:70
void cs_range_set_scatter(const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, const void *src_val, void *dest_val)
Scatter element values associated with a range set to the full set.
Definition: cs_range_set.c:1055
void cs_range_set_destroy(cs_range_set_t **rs)
Destroy a range set structure.
Definition: cs_range_set.c:782
Definition: cs_range_set.h:57
Definition: cs_interface.h:61
Definition: cs_defs.h:301
Definition: cs_defs.h:496
cs_gnum_t * _g_id
Definition: cs_range_set.h:67
void cs_range_set_gather(const cs_range_set_t *rs, cs_datatype_t datatype, cs_lnum_t stride, const void *src_val, void *dest_val)
Gather element values associated with a range set to a compact set.
Definition: cs_range_set.c:982
const cs_halo_t * halo
Definition: cs_range_set.h:71
