1 #ifndef __CS_POROSITY_FROM_SCAN_H__ 2 #define __CS_POROSITY_FROM_SCAN_H__
char * file_name
Definition: cs_porosity_from_scan.h:73
cs_real_t cs_real_34_t[3][4]
Definition: cs_defs.h:333
char * output_name
Definition: cs_porosity_from_scan.h:74
cs_porosity_from_scan_opt_t * cs_glob_porosity_from_scan_opt
cs_real_34_t transformation_matrix
Definition: cs_porosity_from_scan.h:80
Definition: cs_defs.h:495
bool compute_porosity_from_scan
Definition: cs_porosity_from_scan.h:72
void cs_porosity_from_scan_add_source(const cs_real_t source[3], bool transform)
This function add a scanner source point.
Definition: cs_porosity_from_scan.c:575
Definition: cs_defs.h:307
void cs_compute_porosity_from_scan(void)
This function computes the porosity which is equal to one from a source, radiating sphericaly...
Definition: cs_porosity_from_scan.c:637
int nb_sources
Definition: cs_porosity_from_scan.h:81
void cs_porosity_from_scan_set_output_name(const char *output_name)
This function sets the output name for the FVM writer of scan points.
Definition: cs_porosity_from_scan.c:549
bool postprocess_points
Definition: cs_porosity_from_scan.h:75
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:320
void cs_porosity_from_scan_set_file_name(const char *file_name)
This function set the file name of points for the computation of the porosity from scan...
Definition: cs_porosity_from_scan.c:524
Definition: cs_defs.h:301
Definition: cs_porosity_from_scan.h:71
Definition: cs_defs.h:496
cs_lnum_t * source_c_ids
Definition: cs_porosity_from_scan.h:83
cs_real_3_t * sources
Definition: cs_porosity_from_scan.h:82
