cs_opts.h
1 #ifndef __CS_OPTS_H__
2 #define __CS_OPTS_H__
5  * Parsing of program arguments and associated initializations
31  * Local headers
34 #include "cs_base.h"
41  * Macro definitions
45  * Type definitions
48 /*----------------------------------------------------------------------------
49  * Code_Saturne base options structure
50  *----------------------------------------------------------------------------*/
51
52 typedef struct {
53
54  char *app_name; /* Application name */
55
56  /* Redirection of standard output */
57
58  bool trace; /* Trace progress to stdout */
59  bool logrp; /* Redirection for ranks > 0
60  (false: to "/dev/null", suppressed)
61  true: to "run_solver_n*.log" file) */
62
63  /* Signal handling */
64
65  bool sig_defaults; /* use default signal handlers */
66
67  /* Other options */
68
69  bool preprocess; /* Mesh preprocessing mode */
70  bool verif; /* Mesh quality verification mode */
71  int benchmark; /* Benchmark mode:
72  0: not used;
73  1: timing (CPU + Walltime) mode
74  2: MPI trace-friendly mode */
75
76 } cs_opts_t;
77
78 /*=============================================================================
79  * Public function prototypes
80  *============================================================================*/
81
82 /*----------------------------------------------------------------------------
83  * Define options and call some associated initializations
84  * based on command line arguments
85  *
86  * parameters:
87  * argc --> number of command line arguments
88  * argv --> array of command line arguments
89  * opts <-- options structure
90  *----------------------------------------------------------------------------*/
91
92 void
93 cs_opts_define(int argc,
94  char *argv[],
95  cs_opts_t *opts);
96
98
100
101 #endif /* __CS_OPTS_H__ */
void cs_opts_define(int argc, char *argv[], cs_opts_t *opts)
Definition: cs_opts.c:188
bool preprocess
Definition: cs_opts.h:69
int benchmark
Definition: cs_opts.h:71
Definition: cs_defs.h:495
bool trace
Definition: cs_opts.h:58
bool sig_defaults
Definition: cs_opts.h:65
bool verif
Definition: cs_opts.h:70
bool logrp
Definition: cs_opts.h:59
Definition: cs_opts.h:52
Definition: cs_defs.h:496
char * app_name
Definition: cs_opts.h:54
